Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Leaking dishwasher i have an 8yr old hoover dishwasher & it leaks on the rinse cycle. It's coming from underneath on the left hand side as you look at it. I've checked the hoses & clips on hoses, which seem ok. It only leaks as the water is coming into the machine on the rinse cyle. Never any other time, not even when it's filling for the wash cycle!
    Novelist:
  • 166 Answers
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
HOOVER HOD6615 DISHWASHER CONTINUAL BEEPING AFTER INITIAL RINSE & REFUSES TO PROCEED TO WASH CYCLE WHATS THE PROBLEM?
This could be a safety trigger due to bottom water leak. A anti flood device (polystireen float and micro switch) that switches washer in shut off mode and does not continue until the water leak (pipe or hose clamp) that causes the float to trigger the device. Check the bottom of the washer for traces of water and rectify any leak before the washer will continue.
Jun 01, 2010 | Hoover 24 in. HD83M Free-standing...
Dishwasher leaking from the door
Might want to change the door seal if its coming from the door.
Dec 30, 2009 | Hoover 24 in. HD83M Free-standing...
Leaking from the lower right hand side during rinse cycle.
I had the problem with dribbles of water from the right side lower edge of the door, causing puddles across the floor.
Found there was a RECALL on MDB6000AWW models. The door inside panel was replaced by the dealer for free. No more puddles.
Aug 27, 2009 | Maytag MDB6000 Dishwasher
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
Hobart HD-20 home dishwasher that leaks occasionaly
ck the vac. brkr. on the back of the unit, if no vac. brkr. ck the air gap on the side of the mach. let me know how you make out.sounds like the leak occurs when mach. goes into the rinse cycle dont forget to vote thanks monomoy
Jun 22, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Danby dishwasher leaking from underneath
It is still under warantee-contact the company you bought it from. If you fix it yourself you could void the warantee.
Jun 14, 2009 | Danby 22 in. DDW399 Free-standing...
My frigidare diswasher is leaking from a left side black hose
Check the hose first - it could be split or damaged esprcially if it's old. Check all the clamps to be sure they are tight. Chack all connections to the dishwasher and drain spur under the sink. Check the drain trap fro any leaks.
Mar 27, 2009 | Frigidaire Dishwashers
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
418 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
