Question about Nikon FE 35mm SLR Camera
Nikon FE film winder jammed.
The film winder jammed part way through a roll of film. Nothing will move it.
  • 2 more comments
  • Peter S Feb 05, 2009
    Thank you for responding so quickly. You are right, there is no image in the viewfinder and the shutter doesn't release. I removed the lens. But the mirror did not return to its place. It's going to be a repair shop job. Thank you for your help.
    Peter S, Ireland
  • Ketzer Apr 21, 2009
    I HAD the same problem an solwed it by turning the speed knob to the manual speed ( 1/125 ) and then the shutter was reactivated and the camera back to nominal state.
    Besides that the guy from my prefered Nikon Shop told me to avoid using any winder with an FE or FM. He should know !
  • apricklypear Apr 25, 2009
    I'm having a problem with my film winder. Sometimes after taking a picture, the advance lever gets stuck. If I turn the camera off and on a couple times, it usually unsticks.
    Also, the more important problem is that I can't rewind a finished roll of film without shredding it. The winder on the left side is moving fine but the winders on the right side wont spin backwards to let the film rewind.
    PLEASE help!
    I'm taking a class right now and this is a really urgent need.
    Thanks so much for any help!
  • David Shaub May 11, 2010
    If you're still using the manual film winder, you possibly broke a tooth off in the top of the camera. If you have the optional film winder, you will probably have to have it removed and repaired. If you mean the rewinder, pressing the release button in with a pen should help.
    Scholar:
  • 170 Answers
Is it the viewfinder or the film advance lever? If the viewfinder is not showing any image and the shutter is not getting released, then it could be a problem with the mirror box.To confirm, remove the lens and see if it gets released. To align the lens, you have to take it to the nearest service center (or repair shop).
Posted on Feb 05, 2009
Tip
Stuck Film Advance in Manual or Auto Wind 35mm Cameras
I've been seeing a great number of posts from people requesting help with a stuck film advance feature on their 35mm film cameras (you remember "film", right?) Normally, there are just a couple of things you can try to fix this issue before you'll need to find a professional to repair your camera - if it's even worth it. On that note, a lot of people still have film cameras for nostalgia purposes but there are still some hold outs that enjoy film. Finding a repair shop for an older camera isn't impossible but they are getting scarcer. Google "FILM CAMERA REPAIR" and see what pops up in your area!
MANUAL ADVANCE CAMERAS:
There's a complex number of actions that must work properly in order for you to advance the film in your camera using the manual advance lever. Gears, shafts, bearings and springs come into play and like a clock, they need to mesh together or the advance mechanism comes to a screeching halt. Well, you'll be the only one screeching, most likely but you get the point. If any of those parts break or become unaligned, or if some foreign matter like dust or dirt gets into them, the same thing happens. However, there are sometimes a few things you can try that might prevent you from sending in your camera for professional repair. I caution you about opening your camera yourself unless it has no real value to you because the interior of a 35mm SLR camera is pretty complex, even more so that a clock. Chances are you'll do more bad than good. With that said, try these options:
Film Jammed - Won't Advance
Sometimes the film will jam in the canister, or in rare instances, isn't actually as long as it's supposed to be and can reach the end of the roll before the camera indicates it has. If you suspect this has occurred then push the film release button and try to wind the film back into the canister before opening the camera. If you don't care if the film gets exposed feel free to do this in the light. It's much easier!
At times the film may also pull lose from the canister and roll completely on the take-up reel. If this happens you'll need to take the camera into a completely dark room with the light-proof film container, remove the film manually from your camera, roll the film up and put it into the light-proof container, close it tight and then seal it with electrical or duct tape. Also let the lab know this has happened so they don't pop up the container and expose your film thinking it is still in the canister.
Advance Lever Stuck
If the actual film advance lever is stuck and won't move, about the only option you have is to open the back of the camera and be sure nothing has jammed in the gears or sprockets of the take up reel or film path. If that doesn't fix the problem try pressing the film release button, wind the rewind lever a bit and see if the advance lever engages again.
If the lever just flips back and forth with no tension at all then something inside has broken and your chances of repairing it yourself are almost none. Most film cameras are getting on in years and will just naturally begin to break down over time. There may be no option to even fix your camera unless you find a similar model for parts and send that along to the repair shop. Make sure you get the parts camera back as you may need it later! If you like tinkering and the camera isn't one you'd miss if you couldn't fix it, then you could always give it a shot yourself. You can pick up a set of jeweler's screwdrivers and pliers from the web or Radio Shack for under $20 and find old film cameras on EBay or Craigslist at a decent price. Just be sure they don't have the same problem as your current camera does!
Grinding Noise When Advancing Film
This is most often caused either by a broken part, metal shavings or dirt/debris in the winding mechanism. Again, if you feel comfortable doing it yourself and it's not an expensive collector's model, you can try to repair it yourself. Hunt down a PDF service manual for your camera on the using Google web (a lot of collectors share them) and it should show you how to remove the cover to see the winding mechanism area. Look for debris in the gears and springs and remove it with short blasts of canned air but be sure you hold the camera so any debris falls out and not further into the camera. You can also use Q-tips dipped in alcohol to remove any debris, but don't use water, and let the area dry completely. Once you've done this, you'll need to apply a light lubricant to the area but only if it was lubricated before you cleaned. Use thin white lithium grease or an oil or grease used by clock repair shops and apply it with a toothpick as you don't need much. DON'T USE WD-40! It will do more damage than help.
MANUAL ADVANCE CAMERAS WITH MOTORDRIVE ATTACHMENTS:
These are manual wind cameras like the Minolta X-700 or Nikon FM2 that have an attachable motor drive that winds the film for you. Pretty much the same suggestions previously noted can be tried with a couple of exceptions:
Check the batteries and contacts in the winder making sure they're clean and not bent or broken. You can clean battery contacts with a CLEAN pencil eraser or alcohol and a Q-tip. Blow any dust and debris out of the compartment afterwards.If you still experience problems remove the winder and be sure the coupling that locks into the bottom of the camera to wind the film is not jammed or damaged. With batteries in the winder and the power turned on, look for a series of contacts on the top of the winder that mate with your camera. Be sure these aren't dirty or broken as well. Using a paper clip, you should be able to short one or more of them to another to activate the winder to make sure it works properly.
When All Else Fails - A Bigger Hammer
If none of the previous suggestions work and if, ONLY if you don't value the camera for collector's value a firm tap might work as a last ditch effort. I once had an old Minolta SRT that locked up solid. I didn't want to bother with trying to open it up as I only used it for a shelf display so I took the lens off, used a wad of very clean, soft foam to hold the mirror steady and wacked it twice on the counter. Not enough to damage the camera body (or the counter!) but a good smack. Whatever was jammed came loose and the advanced began to work. As I said, I only use it for display so I don't know if it affected the shutter speeds, etc. but it worked and cost me nothing but time.
AUTO/POWER ADVANCE CAMERAS:
Newer "old" 35mm film cameras used a power winder motor to advance the film and **** the shutter. If you experience a jammed advance on these cameras, check the film path, sprockets and make sure they are clear and move freely, as I described previously. Try the film release button and see if that will release the drive as well. Another option that has worked at times is to remove the film, lens and all batteries from the camera (including any date/time battery) for at least a day or two to see if the camera will reset itself. This worked for me once with a Nikon N70.
As a last ditch effort, the table smack might work as well, but I make no promises and it's all your fault if you damage the camera beyond repair... or your furniture!
on Jan 06, 2015 | Photography
My film advance seems to be stuck. I took the film out of the camera and it still will not move. Does this have anything to do with the battery?
No, the only thing that the FE uses the battery for is the light meter and shutter. You can operate it completely without the battery using the M90 and BULB shutter speed settings.
Your film advance problem is a mechanical problem - check for any small objects that may be jammed into the film transport mechanism. If nothing is obviously causing a blockage, then the camera will need to be serviced.
Nov 14, 2010 | Nikon FE 35mm SLR Camera
Help with minolta x-300s, i cant seem to move the film winder
Well, here's the most likely things going on:
1. dead battery. Your X-300 has an electronic shutter that needs battery power to work. Try fresh batteries and check the battery contact wires for corrosion.
2. End of roll. If you have film in it, try the silver button on the bottom. rewind film and try another roll of film. Before you put in the new film, try the advance, click, advance, click thing.
3. Not all rolls of film are perfect. Some are shorter than they should be, some hang up in the canister.
4. The Minolta X-series were well known to have a problem. Two cheap capacitors on the later models would die, locking up the camera. One is under the top plate and the other under the bottom plate. These caps need to be replaced. I suggest you send it to a repair shop for that. Check prices. Garry's camera repair in Niles, IL does a very economical repair on these. It runs about $50 and $8 for return ship. He will also Clean, Lubricate and adjust it.
You could also buy another 300/370 on Ebay, as they're inexpensive these days.
Best of luck. Hope its just the film or batteries. You might also consider joining the Yahoo Minolta groups.
Jan 19, 2010 | Minolta Photography
How to change film in Nikon N 2020
Press the R1 and R2 release buttons. Pull up on winder handle until the back of the camera opens. Continue the pressure on winder handle until you have removed the film canister. Insert new film canister. Pull leader across winder assembly. Close camera back. Press exposure button. Press winder handle in towards camera b
Oct 13, 2009 | Nikon Photography
Shutter won't open and film won't advance
You might have a dead battery. Check that.
Philip
Sep 28, 2008 | Nikon FE 35mm SLR Camera
Film winder is loose and meter is not accurate.
It is absolutely OK, my dad too has one (not older than urs). make it tighter, but u need some screws drivers (specially for cameras). Open the camera and tighten the screw holding the winder arm. Try this only if u have experience otherwise u may end up with a scramble of camera. About the F-Stop, i have no idea why this is so... might be the technology is gone too advanced compared to the 1978.
Aug 14, 2008 | Nikon FE 35mm SLR Camera
FRame Counter does not move beyond the 26th Frame even in a 36 roll Film
Simple, the film counter unit has plastic gears underneath. the gear position or gear has worned out. simply replace the counter unit and adjust. This can be performed by any local repair shop for less than $100. -James. for further assistance email, go to www.camerarepairjapan.com
Jul 01, 2008 | Nikon FE 35mm SLR Camera
Nikon FE- Winder return position
YES, THE PROBABLE CAUSE IS THAT AFTER 25 YEARS OF USE YOUR POOR NIKON PROBABLY JUST NEEDS A GOOD CLEANING! I DON'T THINK IT IS ANYTHING A GOOD CLEANING CAN'T CURE. I HAVE INCLUDED A COUPLE OF SHOPS THAT REPAIR NIKONS AND GIVE FREE ESTIMATES. WHILE I DON'T ENDORSE ANY REPAIR SHOP PERSONNALLY, I PASS THESE ALONG FOR YOUR INFORMATION. I HOPE THIS HELPS. I REALLY BELIEVE THIS WILL TAKE CARE OF YOUR PROBLEMS. ALSO, BY THE WAY, I ALSO HAVE A NIKON FE AND IT'S A GREAT CAMERA. ENJOY!
www.keh.com
www.camerarepair.com/camera/repairs/264-NIKON-FE
THESE ARE HOTLINKS AND WILL TAKE YOU TO THE PAGE.
May 13, 2008 | Nikon FE 35mm SLR Camera
Nikon FE 35mm SLR Camera Logo
885 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
