Question about Dell 926 All-In-One InkJet Printer
Dell AIO Photo 926 will not operated at all
My printer will not print at all. It does not respond when I tell it to "copy" or "scan", though it will let me fix the settings for copying, scanning, etc. When I tell it to copy, it responds about 5 minutes later, but does not copy. Instead, it sits at the screen "printing" indefinitely; I have not waited this out, and have turned the machine off. Another thing is when I open the lid, the cartridges do not move to where I can reach them and change them. My friend pulled the cord to force the cartridges to where we could reach them, which was probably not a good idea. When I try to print from the computer the computer simply says there is no communication with the printer, and nothing is messed up on my computer. I have no idea what to do. Before this happened, there was paper jam, because two tacs had fallen into the paper feeder, both of which I removed, and then this happened.
Is this problem fixable? or do I just need to get a new printer (this one was only $50 and I have used it A LOT since I got it a year and a half ago)?
  • Anonymous Feb 06, 2009
    I can't help you, but i got the same problem about 30 minutes ago tonight...weird...
  • Anonymous Apr 12, 2009
    Printer will not print from Adobe format
  • 3 Answers
Try changing your firewall, it worked for me. I got my 926 a year ago with my Dell and had no problems until I replaced my expired Norton w/a freebe I downloaded then the problems started. Would not comunicate sometiimes and when it did it printed once than froze. Would not delete printed doc or print the next. I remembered that McAfee made my old Emachine freeze or crash. Put Norton back on and no more problems. Hope this helps you.
Posted on Feb 07, 2009
4 Suggested Answers
john_yap
  • 51 Answers
SOURCE: printer aio 926 communication error
hi aweintra,
you can do the following steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just send me an update if the issue won't be fixed. have a great day.
Posted on Oct 19, 2009
pineworks
  • 4041 Answers
SOURCE: Error 1203 for Dell Printer AIO 926
Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted on Apr 25, 2010
SOURCE: printer status window interface stopped working dell AIO 926
I know this sounds too simple, but get a new USB cord. I had the exact same problem and it was driving me crazy. I followed all the advice about uninstalling, reinstalling and updating multiple times and it never fixed the problem. Finally, my husband made the simple suggestion that maybe it was a problem with the connectivity of the USB cord. I didn't have much faith in it, but I bought a new USB cord and hooked it up - and I have never had a problem with the printer since then. My original USB cord (the one replaced) was the one that came with the Dell printer - perhaps there is a flaw in the cord somewhere. ?
Posted on May 14, 2010
What mode does 926 Printer must be in to print?
For printing from the computer, I beleive it is 'copy' mode.
Mar 30, 2014 | Dell 926 All-In-One InkJet Printer
I'm tryin g to scan a photo with my Dell AIO 926 Printer, connected to my Dell Inspiron 1525 laptop. But the laptop doesnt seem to be bringing up the AIO 926 printer file folder/menu, and when I request...
Did you figure this out? You should have a "Dell All-In-One Center" that was installed with the drivers for the printer. Try searching for it by pasting that phrase in the box in your "Start" button. When you locate it, drag the shortcut to your desktop or up in the top of the programs in the Start location. When you click on the Dell All-In-One Center icon, you should find some options for scanning.
Nov 12, 2010 | Dell Photo 926 All-in-One Printer
Deleted the whole Dell photo aio 926 program in error. Try to run the orig cd that came with printer but it won't run. How can I get it back? Went to search and came up with 'google icon' and 'folder' but...
Try reinstalling the printer using the instructions located at....
926 Photo All-In-One Printer owners thread (W7)
You'll need to disconnect the printer. Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer.
Install the proper drivers. You'll get the message, the printer is not connected. Connect the printer at this time.
Rick
May 21, 2010 | Dell 926 All-In-One InkJet Printer
or
Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
Printer status window interface stopped working dell AIO 926
Jan 16, 2010 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer scanning problems
Go to Control Panel, then Programs and Features. Uninstall the Dell printer software.
Then, go to Control Panel, then Device Manager. Locate the printer, right click on it, and select uninstall.
Disconnect the printer from your PC.
Go to the Support section of Dell's web site, download the latest driver for your printer.
Restart your PC.
Install the software. Connect your printer when instructed to, or after the software install has completed.
Let me know if you still have issues :)
Apr 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of the driver which has some known issues. Few steps will be required to fix this.
  1. Unplug the printer
  2. Goto control panel -> Add/Remove programs (or) Programs & features (Vista), uninsuatll the Dell Printer software if listed.
  3. Download the Driver from the Dell Support Website
XP Driver
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=195205
XP Printer Application
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=205258
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
Nov 30, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell Photo 926 - unable to scan
1. try to make a copy.
if it copy fine, then its an issue with software.
2. Try to scan with MS Paint,
Click on Start > All Programs > Accessories > Paint
Click on file > from scanners and camera > scan
It should scan if its not the windows issue...
3. Try different computer if it does not scan with Paint\
4. If it works with Paint, try to open Dell AIO center and try to fax from that too...
5. Turn the printer off, take the power brick out from back of the printer where power cable goes in , wait for 15 seconds to connect it back and turn on and try again to print, it should work fine
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Dell AIO 962 can't send scanned info
Try reinstalling the printer software by downloading the latest version from support.dell.com.Also try using the printer with a different system if avialable.
Dec 27, 2007 | Dell 962 Photo All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
436 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
