Question about Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 7520 numeric keypad problem
The numeric keyboard does not work at all.
Any suggestions on how to fix please?
Thanks.
  • hjdrimmc Mar 29, 2009
    i press de num lock and the numeric key board not work acer aspire 7520 soluction?
  • 2,229 Answers
Try pressing the numlock key in the upper right part of your keyboard. Chances are it's turned off and therefore the numeric keypad will not work.
Posted on Feb 06, 2009
NUMERIC KEYPAD NOT SUPPORTED
Might give this a try-right click on your Computer icon-click on Properties-then click on Device Manager. The keyboard is listed there. If it has a yellow exclamation point, or a yellow question mark, then there is a problem. Click on the arrow in front of Keyboards, then right click on the drop down named keyboard. There you can click on update drivers. That should solve the problem.
May 07, 2014 | Acer Aspire 7720 Notebook
How do I get the pound symbol on my keyboard ?
If your Operating System is MS Windows, go to Start / Control panel / Regional Settings (or Region and Language for Win7) / Keyboards and Languages then add the English/UK keyboard or simply hold the ALT key and type 0163 from the numeric keyboard.
Mar 04, 2011 | Acer Black Acer Aspire Keyboard...
Number keypad on right hand side of acer travejmate 7520 not working
you must press the number lock key to make them work. (please rate if this helps Thank you)
Dec 22, 2010 | Aspire Acer 7520-5071 Notebook
I have an acer aspire one and the keypad is not working its typing the wrong letters any suggestions why. It is not a year old yet
This is either a keyboard or setting problem. If the operating system is told the keyboard is a different type or the wrong location (language) you get weird results. Can even be a stuck key or even a function setting. Laptops use the FN-F7 key (usually) to turn on the numeric pad that is in the keyboard. That will also give you strange results.
If the keyboard doesn't have a stuck key and actually is the problem then it can only be replaced.
If its just a setting then you need to look under control panel for the keybaord setup and make sure it is set to the correct location language and type. A standard laptop keyboard is a 84 key and I believe the ones with number pads are 101 key.
Nov 08, 2010 | Acer A2909.001 Aspire 1800 Aspire 9500...
I NEED A MANUAL TO SHOW HOW TO GET MULTIFUNCTION KEYS TO WORK. FOR EXAMPLE HOW DO I GET THE ALTERNATE USE OF THE "NUMERIC 6 "KEY ie THE" QUESTION MARK" FUNCTION
You must have a different keyboard selected other than the standard US keyboard My numeral 6 has ^ on it and the numeric keypad 6 has a right arrow. One generally uses the SHIFT key to access symbols that are written above the main alpha or numeric key. The numeric keypad on side of PC has a button labeled key marked NUMLOCK that is engaged to allow use of the numerals as a calculator or to also be inserted into text.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Acer NSK8458AN Keyboard
The Numeric keypad on my Acer Aspire 7720 doesn't work. When I press Num Lock key the indicator light doesn't come on. The main keyboard works fine. I am using Vista.
try to access command prompt outside of windows using the operating system disc. (by booting to cd and go to repair your computer options then select command prompt) if the keyboard works fine on command prompt, there's no issue with the hardware. but if it still doesnt work, you will need to replace the keyboard.
Dec 03, 2009 | Acer Aspire 7720 Notebook
Changing keyboard
viewing the user manual ... the semi colon is located beside the L on the right hand side.
to use the numeric keypad .. the num lock must be ON
download and view the manual here ... http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/ece0d9956f1de86048256f79000a4810/$FILE/Extensa%202300_3000_EN.pdf
Mar 12, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
857 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
