Question about Philips Magnavox DVD/VCR Dual Player
My combo will shut off a few seconds after you turn it on
I have a magnavox dvd/vcr combo and everytime i turn it on it turns its self off within a few seconds. im pretty good at fixing things but this one is new for me. i have already taken it apart and found the ir diode bulb but i need to know how to take it out without damaging anything.
    President:
  • 2,976 Answers
Get a very small hemostat, or heat sink clamp and clip it onto the wires coming out of the diode, batween the diode and the board. Use a small soldering pencil so you don't generate too much heat and use solder remover braid or a ****** to remove the solder. When you replace it, use the clamp again to protect the new one and make sure the polarity is the same or it won't work at all.
Posted on Feb 05, 2009
How can i get a greenbrier 6 in 1 (dollar tree) remote to program to my Magnavox DV220MW9 DVD Player VCR Combo
been there... time better spent driving to walmart/target/sears and buying a name brand univerasal remote and saving your self 5 hours and lot of aggervation this is coming from someone who like yourself who refuses to give in GOOD LUCK
Mar 10, 2013 | Magnavox DV220MW9 DVD Player VCR
Magnavox vcr/dvd combo the vcr part only plays for 8 seconds
What you have is called a transport problem in the VCR unit--the mechanism is either jammed or something in it that loads the tape is bad.
Every time it is used it cycles to self check the mechanism--if it fails it is usually a belt bad or a gear assembly not working.
Someone would have to open unit to see what is happening.
May 28, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox ZV450MW8 shuts off within 10 seconds of being turned on
The problem is in the power supply, one or two capacitors fail and sometimes have a slight puff at the top, need to be replaced.
Mar 18, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
Sylvania MTS/SAP tv/vcr/dvd combo turning itself off
could be that either the dvd or the vcr are malfunctioning, usually it is the vcr that creates the problem. If you turn tv on and set vol to low see if you can hear the noise of the motor loading or trying to load,with out a tape inside. It may be a good idea to have a qualified tech repair it, these units are difficult to work on and further problems may come up if you are not familiar with the tv.
Dec 31, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
I have a magnavox mwd2205 dvd/vcr combo with no remote. I've tried programming it to my Charter cable remote and to a GE universal remote, but can't get it to do anything but turn the machine on and off....
This DVD/VCR isn't compatible with the GE Universal remote. Sorry.
I would recommend contacting Magnavox (actually FUNAI CORP.) at www. magnavox.com, and seeing if they would be willing to send you a remote that was compatible with your player. There was another Magnavox player remote that also worked with Magnavox MWD2205. So it's possible that a number of remotes would work for you. Good luck! :)
Dec 28, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Progressive scan mode
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox DV200MW8
The tape player section has some safety sensors inside that will shutdown the system when there is a problem. The most common cause of this is either a bad belt or "idler". If the tape is not moving or the take up side is not moving, this will happen. This is a simple repair for any shop and should runfrom $5-$25 for parts (belt - idler) plus the local labor rate.
Dan
Apr 09, 2008 | Philips Magnavox 20MC4304 20 in....
Dvd door won't open
Mine just did the same thing about 1/2 hour ago. Found this site and tried advice of gopackgo - worked perfectly!
Jan 20, 2008 | Philips Magnavox DVD/VCR Dual Player
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Philips Magnavox DVD/VCR Dual Player Logo
118 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
