Question about Ricoh CL4000DN Laser Printer
SC 366 on CL4000DN
I am using a ricoh Aficio CL4000DN, and i get the SC366 error each time i print. When i get the mentioned error i am unable to print anything. could someone please advise me on what can be done to solve this problem.
  • 161 Answers
Cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Posted on May 06, 2009
  • 903 Answers
SC366 is a cyan toner density error. Is your cyan toner low? You can try installing a new cyan toner, but if that doesn't do anything you'll probably need to replace the cyan PCU (photoconductor unit) or have a service technician do it.
Posted on Jun 05, 2010
SC 491 error message
sc 491 is error signal is detected for 0.2 seconds when charging the drum or development.
• High voltage leak
• Broken harness
• Defective drum unit or development unit
• Defective high voltage supply unit
Oct 19, 2016 | Ricoh Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
My Ricoh Aficio SP C420DN Laser Printer shows color tone SC366 and some time SC365, any ideas?
You just have a problem with colour PCU (SC 365 - magenta, SC366 - cyan). The main reason is that toner density is abnormal. Sometimes, when you replace toners, printer receive to much toner for a short time, and after that you have an abnormal toner density (higher). You can check in service mode (hold up and down arrows for 6-7 sec, release them and press ok button) following thing :
choose 2. engine
then with arrows choose 3. process
then choose Vt display,
for each color by default there should by somewhere arround 2.4V. If you see for some colors, for example 0.02V, then this is a problem(to much toner). In this case the only thing that you can do is to restart printer and try to print enough pages, filled with problem color. Usually you can print max 3 pages. Then restart printer and try another 3 pages. Print until the you will be able to print at least 4 pages continuously.
Good luck and remember that this is a technical problem and you should ask someone qualified for the job. I am sure that 80% of service engineers can't repair this issue. But I can.
Apr 17, 2015 | Ricoh Aficio SP C420DN Laser Printer
My ricoh aficio code a 990 how to fix them ?
An SC990 is usually an error indicating maintenance is overdue. The only way to verify that is by printing out the SMC report and seeing the subcodes. In the case of this model when is the last time the drum and developer was replaced?
Nov 15, 2014 | Ricoh Aficio 1015 All-In-One Laser Printer
Factional parablems ricoh aficio 400
it really need to be wrote which specific functional problem is showing, as example SC 541.
Feb 19, 2014 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
I m using ricoh aficio 551 and i gat the sc 366can advise me please
SC 366 - the problem is with the hard disc, it has t many bad sectors, you can try to format the hard disc, but it looks like it will need to be replaced
Dec 02, 2013 | Ricoh CL4000DN Laser Printer
Error sc 366
TD sensor: Output minimum error [C]
Defective connector connection
Decreasing toner density
1. Replace the CYAN PCU.
Apr 14, 2013 | Ricoh Aficio SP C410DN Laser Printer
Code error 307 ricoh CL4000DN
sc 307 is a charge bias error having to do with the yellow photoconductor unit (PCU). Replacing the yellow PCU should resolve your problem. If the problem persists even with a new PCU, you will likely need to have either the high voltage supply board or the drum positioning plate replaced.
Thanks for using FixYa!
Nov 24, 2010 | Ricoh CL4000DN Laser Printer
Ricoh Aficio 551 w/ sc366
sc 366 is hard disk drive bad sector will need to call in a engineer to fix this problem might need a new hard disk if he cant format it make sure you always shut the machine down correctly switching it off in correctly causes this fault to occur
Jul 14, 2009 | Ricoh Office Equipment & Supplies
SC366 on CL4000DN
I just came across this post, you've likely solved it by now; However it is a "Toner density" error related to your cyan photoconductor. It is a defective connector. Replacing the cyan photoconductor should solve problem.
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
Ricoh CL4000DN Laser Printer Logo
1,547 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
