Vcr dropped after i dropped the vcr there was a burning smell, and the power would not stay on..there are burnt marks above the silver casing above where the power cord goes into the vcr. the power will stay on until i push the play button or the eject button...well any button really....what do i need to change or is it even worth fixing?
  • 3 Answers
VCR's are cheap enough to buy a new one.
Posted on Feb 05, 2009
M-Audio AV20 smells like burnt
Yes, it is possible to burn an IC and not the fuse, because of Safety standards, the fuse has the function to avoid a possible fire, but it should deliver all the power needed by the circuit it is protecting, and that amount of power can burn, in this case, the IC.
From my technical point of view, there should not be a problem to connect the speaker to 110 V instead of 220 V, all that might happen is to have less power available at output, I have no idea about the reason of the burnt IC, but, as we all know, they (the IC's), don't need a reason to burn themselves whenever they decide to.
So, the next step, will be to replace the burnt IC, and that is not a simple task, you need a SMD station and some experience in doing such jobs.
Good luck and best wishes.
Apr 11, 2013 | M-Audio AV20 STUDIOPHILE
I tried hooking up an old polk sub to my yamaha rx-v659 av receiver. smelled wires burning smell. before i could unplug it, receiver shut down. now it will power up for about 5 seconds and shut off. manual...
If a fuse was blown, it likely would have no power. However if the power board has overheated, the capacitors may have swelled up and burnt out and will only allow it to power on for a few seconds, then shut down. The capacitors can look swelled up or burnt or have burn marks on the power circuit board. You can test them with a continuity meter. Each component has a printed number of it's voltage and ohm resistance so you can test them.
Jul 26, 2010 | Yamaha RX-V661 Receiver
SamSung S4253 not turn on. Power light on with burning smell.
You have burnt out capacitors on the power board, to check this you will have to remove the back cover, follow the cable into the television to find the power board, the caps are round with silver tops, check for any liquid coming from them, and make sure the are'nt bulging or petruding, if there are any they will need to be changed.
Feb 18, 2010 | Televison & Video
Burning smell came out of the Tom Tom 910. Now does not boot up on mains or car cigar lighter socket
The power supply or voltage transformer or possibly capacitor is burnt out. You will have to visually inspect the main control board for burn marks and swelled up capacitors. You can use an ohmmeter to test them as well.
Dec 04, 2009 | GPS
Smells like burnt wires
It is very possible it may have burnt wire or burnt capacitor. Remove unit, remove top cover and look inside to see if you see any burn marks or burnt wires. Also check fuse to see if it is good or not.
Aug 07, 2009 | Whirlpool MH1141XM Microwave Oven
I just replace convergence board on my akai tv and
There is a burnt capacitor somewhere in the unit. Look for any burnt or swelled up capacitors. You can also usually locate a bad cap if there is burn marks on the system board. Also test power supply with voltmmeter to make sure it is a constant volt reading.
Jul 11, 2009 | Akai PDP-42TD1 42 in. EDTV-Ready Plasma...
GDM-12 Refrigerator smells burnt. Any suggesstions?
It could be smelling burnt for a few reasons. The best case scenario would be that the condensor fan is stuck which is causing the compressor to get hot and burn, in this case you would just find the obstruction and remove it. Or the condensor's fan motor could be bad, causing the fan to spin slowly which would also cause the compressor to get hot and burn, in this case you would replace the fan motor. Or the cooler has a restriction in the refrigeration lines causing the compressor to work harder which causes the compressor to get hot and burn. In this case call a refrigeration technicion to clear the lines.
Mar 21, 2009 | True GDM-12 Refrigerator Commercial
EXTERNAL HARDDRIVE 160GB
Open the drive and see whats burns, if the case circut is burnt put the driv in a new case. the the harddrive is burnt your out of luck.
Sep 05, 2008 | SimpleTech SimpleDrive 160 GB External USB...
SAMSUNG HT-X50
Do you smell anything burning. This happened to me and I cut it back on. It stayed on for 30 secs or so and did the same thing. After doing this 2-3 times, I smelled a burning. Being a member of the Fire Dept, I didn't want to see my buddy's coming to the house, so I unplugged it. The next day, I took it apart and there was a burnt resistor or something under neath the fan. I took it back and they gave me a new receiver, but I'm expecting the same with this one.
May 16, 2008 | Samsung HT-X50 System
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
