Question about Sharp Televison & Video
AQUOS LC-65D64U 65'' LCD TV will not turn on. Green lights flashes
I receive my LCD above and the first time I turned it on, I saw a black screen with a box in the upper right hand corner that said input one. After trying to find the correct input the screen went blank. Now all I get is a green flashing or blinking light. The LCD is a 120 volt 60 Hz unit. I live in Germany that has 220 volt 50 Hz. I did use a step down 220 volt to 120 volt, 1000 watt transformer. I was told the TV may have been too sensitive to voltage. This does not make sense to me. HELP!!. When I purchased the TV I asked for 100-240 volt, 50/60 Hz unit. As you can see, this is not what I received, however, I did verify the need for the transformer before I plugged it in. If you can provide a technical repair manual or access to one this would be great. One last note, the TV may have been cold since the movers brought in my house from 32 degree Fahrenheit weather, so I am hoping maybe a fuse blew. HOPE YOU CAN HELP!!
  • cwebb77 Feb 05, 2009
    Send the LCD back to the store is not an option since the store went out of business. To complicate this problem, the TV and I are in Germany. What I would like to know, is the problem worth correcting, and if so, can a 100-240 volt transformer be installed in the TV along with a 50/60 Hz rectifier? Also, if this can be done, is it worth it?
  • 81 Answers
Heres a link to your actual manual. Check the link below. Hope this helped.
http://www.sharpusa.com/files/tel_man_LC65D64U.pdf
Posted on Feb 05, 2009
  • 1,800 Answers
It sounds like it may be your power supply.
  • 10,594 Answers
Since you saw input one display that means TV was fine at that time.
step down transformer 240 to 110 is OK for this TV.
Please unplug TV from AC outlet for couple of minutes and replgg back in and check again.
Service manual of LCD TV has no detailed schematics yet it has info about blink error codes.
    Brigadier General:
  • 8,619 Answers
Hi!
You used a step up transformer or a step down?
  • Rylee Smith
    Rylee Smith Feb 05, 2009
    There is a in/out button on the transformer, please select the in and then try to switch it on.
  • Sharp Master
  • 13,433 Answers
Service - repair manual is for sale on this website below
http://www.manualsparadise.com/ShowProductsForModel.do?model=M86179753
    Genius:
  • 2,920 Answers
I would get hold of the store and ask them to send you the right tv and tell them that this one is not working as it is supposed to.dont take no for an answer!!! tell them you want a working tv and that not what you got!!!
  • Ronnie Houston Feb 05, 2009
    it can be done and yes it would probably be worth it. it wouldnt take much to convert it over and make it work like it should. call your nearest repqair shop and askthem the best way to do it and they should even have what you need to do it.
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
The upper left quadrant of my Sharp Aquos LC-65D64U does not display.
Check the connections of the flat cables that connects the T'Con board to LCD pane for any loose contact. Re-seat them. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by type in the brand name of the device in the "Search Box", at the top right of the display window.
Dec 05, 2012 | Sharp Aquos 65" LC-65D64U LCD TV
Sharp Loud popping noise tv
The power supply regulator board should be replaced as card basis.
Aug 20, 2012 | Sharp Aquos 65" LC-65D64U LCD TV
My TV LCD Sharp LC-65D64U had no power ON/OFF, the Power LED blinking, Could you let me know what is the problem?
Hello
This fault on that TV was with its power supply that feeds the LCD screen drive. The unit knows if it hasn't got an ouput to the screen from the power supply and flashes to indicate the problem. I'd suggest to try unplugging and leaving for 10 minutes before trying again. Then see if you can get any menu functions to appear as you trun it on.
However, then it'll need repairing by qulified technician.
Good luck
Dec 24, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
We cant turn on the Sharp Aquos TV and the power and opc buttons are flashing.
Ur power light stable green first turn on?Then awhile click,POWER and OPC flashes.Tries on/off couple time,will work.Not then ur backlight video board is dead.
Dec 25, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Aquos screen blacks out with xbox 360 using Component Cables
Downloaded the updated firmware from the sharp website to a usb drive. Placed the drive in the TV and went to the update software option on the TV menu. Since the update, I no longer get the black-outs on the screen. I also put the resolution on the 360 back up to 1080p and it works great, even through the component cables.
Jun 29, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Oct 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
63 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
