Question about Yamaha RX-V663 Receiver
DTS Master HD audio problem
I have 7.1 setup hooked up to my rx v663 and it is not playing DTS HD Master audio's 5.1 surround channels into the surround back speakers. I have the extended surround speakers set on, so it should mix the surround into the surround back. It does it with Dolby true hd, dd and dts, but it's not working for dts hd master audio. I'm starting to think it just won't work with dts hd ma audio or somethings wrong with the receiver. Anyone else notice this problem
  • 1 more comment
  • radbon Feb 19, 2009
    I just hooked up two new speakers to the rear surround terminals on the back of the receiver for 7.1 surround.  I ran the auto set-up but the receiver did not recognize the rear speakers.  The receiver output sound through the rear speakers as if they were hooked up to the front right and left speakers.  I reset the receiver as yamaha says and the auto set-up recognized the rear surrounds.  After all this, even though the receiver sends tone during the set up test to the rear surrounds, during blueray movie playback, or dvd, or tv, it does not put any sound out !  The display on the receiver that shows active speakers only shows the rear surrounds during set-up!  The display showing rear speakers disappears during playback.  Please Help!
  • Anonymous Mar 14, 2014
    I am having problems hooking up my surround sound to this47 inch LED SEIKI Tv When I connect red and white audio to back of Tv it does nothing but humming noise come through speakers also trying to hook my laptop to listen to music
  • 3 Answers
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Posted on Jul 26, 2009
    New Friend:
Make sure you have your zone 2 turned off also. My rxa810 utilizes my rear surrounds even when it's only a dts hd ma 5.1- fooling around with your settings onscreen is the best way to learn your rec--- also go into the options menu and check you have the ext speaker setting to extended and not off. Lots of settings to play with
Posted on Nov 25, 2012
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
Yamaha rx-v663 is there a firmware update to get hdmi 1.4a support ?
Unfortunatly there is not any firmware to upgrade your unit to a higher HDMI format. There is a firmware though that corrects the following symptoms.
1. In case of playback of some DTS-HD Master Audio stream, pop noise may be generated.
2. Test tone may not be output under specific YPAO condition.
3. When test tone is output from presence channel, surround R channel is simultaneously output when speaker settings are PRESENCE SP "EXIST" and SWFR "NONE".
4. Multi channel input setting will be reset after power off the unit, in case of setting "INPUT CH" to "8CH" and "FRONT" to "VCR" or "V-AUX".
Apr 10, 2012 | Yamaha RX-V663 Receiver
I have a Yamaha RX-V663. I recently upgraded to 7.1, but the 6th and 7th speakers do not activate on DTS HD Master Audio Blu rays. The 6th and 7th speakers do activate on DTS True HD, DTS EX - ES,...
It is unclear to me as to what you mean when you say they do not activate. Does that mean that they just don't play, or does it mean that your receiver doesn't show them on the display? If your not hearing the sound from the speakers, are you sure your dvd movie is capable of outputting 7.1 or is it only 5.1?
If the receiver doesn't show the speakers on the display, try running through the speaker setup again to make sure you selected both sides and rears for the setup.
Good Luck
Jan 06, 2011 | Yamaha RX-V663 Receiver
I have a Yamaha RX-V663 I have speakers connected to both the Front A L & R and the Surround L & R for now only because i am in the process of getting more. I have my iPod connected through...
I imagine your FM and any other sources suffer from the same lack of a front speaker function.
Page 43: "Press the A Speakers on the front panel repeatedly to turn on or off the set of front speakers...."
Jun 15, 2010 | Yamaha RX-V663 Receiver
YAMAHA RX-V2700
This receiver does not support DTS HD Master audio and/or Dolby TrueHD
which is true blu ray audio.But it will allow the full HD quality of 1080p video to pass through to your tv...meaning if your TV is capable of FULL HD(1080P) then you will get bluray video but audio will only be Dolby digital.That is still really good and the difference will be felt only if you have a dedicated Home therater system with 5 or 7 channels of speakers in your room and separate subwoofer.
Anyways this is a good network receiver and you should be enjoying a lot of internet radio.
HTH
Aug 12, 2009 | Onkyo TX-SR803 Receiver
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
Decoder problems
OK, use the down mix function on your blue ray player. this will decode for your receiver. the down mix feature should be located in the audio options on the blue ray menu screen.
Mar 16, 2009 | Yamaha RX-V663 Receiver
Cannot get yamaha rx-v663 to play DDTrueHD or DTS HD audio
If your Blu-Ray player has TrueHD or DTS-MA decoding, then it will send a already-decoded audio signal to your receiver. The receiver should then just recognize this as "Straight" decoding, because it isn't actually doing any decoding.
Hope this helps.
Mar 01, 2009 | Yamaha RX-V663 Receiver
Want to add all of my video components to my rxv 663 reciever
The rx-v663 has 2 hdmi inputs, and 1 HDMI Outputs, The way I would run is 1 HDMI in dedicated to the Blu-ray, This will do the audio HD True digital, DTS-HD , then video out to the TV for HD 1080p resolution, On the cable box out do you have an HDMI 1.3? If so sport it to the other available receiver HDMI IN, net the same in/out as the blue ray, minus a 1080p result video which will only happen Blu-ray, cable will result 1080i HD and audio HD will vary with the signal broadcast format.
Feb 01, 2009 | Yamaha RX-V663 Receiver
Rear Surround speakers
Best thing to do is to put the unit in 5 channel or 7 channel mode. That will send left ch information to the front left and rear left speakers ( both will get the same information). Ditto with the right channel. The center channel will get centre channel information.
If all the speakers work, go out and rent TOP GUN. ( yes its old), BUT there are a few extreme scenes , one of which is the elevator scene, where the camera changes perspective and suddenly you hear the elevator doors close BEHIND you through only the surround speakers ( have the unit in surround mode....NOT 5 or 7 ch mode ). If this works ok, then you have no problems.
Remember, surround sound only produces information in the rear channels when the information is there. To check out the digital and DTS decoders, get an action flick. If you can, get a remote too, because that will unlock many features about the receiver that you cant get to with the front panel controls. Also go to yamaha and download the owners manual ( its free !!).....that should get you going.....
best of luck...
Rob
Jun 08, 2008 | JVC RX-880V
Yamaha RX-V663 Receiver Logo
1,511 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
