Question about KitchenAid K45SS Classic Stand Mixer
Paddle beater won't push up and turn to release
The paddle mixes fine, then when I go to remove it, it won't push up. The spring seems fine. I had to use a hammer to make it go up and a screwdriver to make it move over. I have a lift head standard KitchenAid 5 qt. mixer. The mixer is four years old. I use it a few times a month.
    President:
  • 2,976 Answers
When you are able to remove the paddle, feel the opposite side of the spindle. It should be smooth. The pin should not stick out the back at all. Carefully, tap it in until it is even with the spindle. That will fix you up, unless the pin itself is also damaged. If so, get a small file and remove any burrs from where the paddle mounts.
Posted on Feb 05, 2009
Mixing paddle slips off pin
We have never heard of this problem before. I spoke with our KitchenAid technician as well and he has never seen this problem in the over 20 years of working on KitchenAid mixers.
Are you sure that the beater is hooked on all of the way, and there isn't anything in the beater stopping it from turning and clicking into place? Is the pin stuck? If the pin is not sticking out all of the way, or the spring is bad/damanged it is possible the beater could come loose. You would want to replace the agitator shaft.
Agitator Shaft: http://www.mendingshed.com/kacentershaft.html
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 03, 2013 | KitchenAid K45SS Classic Stand Mixer
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
I can't get the beater released from the shaft. I did exactly what the book said, push up as far as it goes and turn to the left, but it doesn't seem to go far enough.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Constant pushing of the beater onto the Agitator shaft (40) can cause
it to be pushed in too far into the Planetary (33). With the beater in place,
use a rubber mallet to slightly tap the edges of the beater and push the
shaft out until you can see the retaining clip.
Now you have enough clearance on the shaft to push the beater upward
and twist it to remove it.
Aug 05, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I received my mixer as a gift for my birthday in October. The bowl gets stuck and does not release from the base. I have to hit it a number of times with a rubber mallet to get it to release. Also when...
If that is the bowl that came with the machine it is not wrong. What happens from time to time is that the head on the mixer automatically adjusts causing the beater to not operate as it should. To adjust the head on the mixer place a dime at the bottom of the bowl, attatch the beater to the mixer and make as if you are going to start mixing. The beater should JUST touch the dime. If it doesn't touch it at all or is pressing it against the bowl, tilt the head of the mixer up to locate the adjustment screw located inside the shaft. Take a flat head screw driver, turn the screw clockwise (to lower the head) or counter clockwise (to raise the head). Place the beater back on the mixer, turn the machine on and see if it moves the dime moves. Once it is properly adjusted the dime should move ever so slightly.
Nov 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Unable to get the beaters on/off the mixer -
As you face your mixer with the bowl toward you, on the right side is a lever that will lock the top in place. Unlock the top and tilt the top back. This will give you access to your beaters. Then push up on the beater while turning it either right or left. It only turns one way and I can't remember which way it turns. Then pull it down once you get it to the point where it disengages. Do the reverse to get the beater ON the mixer. Now, here's another thing to consider. If the spring on the column to which the beater attaches is caked with gunk, it will not collapse to give you the flexibility to push the beater up. UNPLUG your mixer and with a stiff brush, clean the spring. A dry OLD toothbrush is excellent...I keep one at my sink at all times. I hope this helps and if it does, please let Fixya know my rating my solution. Good luck and happy mixing.
Nov 15, 2010 | KitchenAid K45SS Classic Stand Mixer
How to adjust bowl height on 20 qu hobart mixer.It is an old A200 1/3 hp Paddle is to high in bowl and will not mix dough on bottom and sides of bowl
you need to remove splash shield, tilt mixer back,with a long screwdriver adj. the set screwclockwise to decrease clearance for beater to bowl clearance,always use b beater when making adj. clearance should be .054" to .115".also make sure there are no deformities in btm of bowl which can cause you problems.dont forget to vote
Dec 12, 2009 | Hobart A200 Stand Mixer
Kitchen aid--heavy duty mixer
The beater is held in place by a pin and spring arrangement. Lift and twist the beater. If that doesn't work, the pin is trying to come out...and is wedging against the beater. Tap the pin back in a bit, and the beater should release.
Regards, --W/D--
Jul 25, 2009 | KitchenAid K45SS Classic Stand Mixer
Can't get the screw adjustment to change the height of the bowl
I had a similar problem with mine - the problem turned out to be that I hadn't clicked the bowl into place corectly. If you find the bowl is tilting forward slightly then you probably need to push it into the clip at the back.
May 17, 2009 | KitchenAid KP26M1X Stand Mixer
Beater doesn't turn
I think this link will help you understand what is needed to fix your mixer.
You will need to purchase a gear. Here is link MarBeck should have it.
You may need to replace some grease. Make sure to use a non-toxic food grade grease.
Dec 15, 2007 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K45SS Classic Stand Mixer Logo
392 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
