Question about Sharp AR-5316 Advanced Digital Imager Copier
"d" display on AR-5316
When the unit is switch on "d" is displayed on the LED display and it seems to lock all keys and simulation can be entered.
Any solution to this problem?
  • michael_chak Feb 06, 2009
    What's the solution to this problem. I can not enter any simulation..
Ghgfh
Posted on Feb 06, 2009
My sharp copier AR-5316 E, is showing error message L4. How do I clear it and solve the problem. Please I need urgent assistance.
L4 is a motor lock if you hold down the start key it should give you a sub code 01 main motor, 11, Shift motor, Make sure all jams are cleared out of machine a jam in the fuser/heater section will cause a moter lock to clear code press key #/P-asterisk(*)-clear key(C) asterisk(*) machine will ask you to enter simulation enter (14) on 10 key pad press start,machine will reset or you may need to press CA key to make it reset. If problem comes back you will need to place a service call.
Aug 18, 2011 | Sharp AR-5316 Advanced Digital Imager...
When i put on the switch button for my sharp AR-5518 copier, it displays an error H4 on the zoom screen on the panel. What is the problem and how can i fix it.
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 14 and start key twice.
copier should restart normaly.
If not, then you have problems with the fuser, contact me to tell you what you have to do next.
Regards,
Adi
Nov 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
How i can enter in service mode of sharp AR 5316 copier
On the panel display, press #, interrupt,0, interrupt keys in that order. Display will go off then enter the desired number and press Print. If the command has subcode, enter it and press Print to execute.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
H4-00
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and rarely the temp sensor.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Feb 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
AR-5127 Counter Reset
Try these steps
1.Press continously #key then Interrupt key then CA key then # key
2.If the display turns off it means that you are inside the simulation but if not do again step 1.
3.Press 81 then press enter then press 1 then enter
Hope that this will help to reset .
Dec 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
ERROR CODE 4H ON AR-5316
There is a problem with the fuser unit ( exit where it gets hot), unfortunately you need to replace
either 1- thermofuse, 2- thermistor, 3- heater lamp
Sep 10, 2008 | Sharp AR-5316 Advanced Digital Imager...
H 2 FLASHING AND MACHINE WILL NOT START
You might have a dirty thermistor above the upper fuser roller check and clean the fuser unit then use simulation 14 to reset the machine.
You enter simulation by pressing #,interrupt,c,interrupt in sequence display goes off, then no. 14 then start key.
Hope that helps...
Lbcoaster
Jul 28, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5316
there might be some dirt on thermistor above the heater upper roller pls check and clean the fuser unit then use simulation 14 to reset the machine enter simulation by presssing #,interrupt,c,interrupt in sequence display is then off, then no. 14 then start key h2 disappears ok
Sep 04, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
66 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
