Question about Kodak EasyShare SV811 (8858946) Digital Picture Frame
Shuts down starts running slide show and after a few pictures shuts down. Previously ran continuously through all pictures.
  • 2 more comments
  • Anonymous Feb 18, 2009
    My frame will run through a few pictures then go back to the Kodak screen, then show a picture, then go back to the Kodak screen.
  • Anonymous Feb 22, 2009
    I have Kodak Easyshare SV1011 with the same problem
  • Anonymous Feb 25, 2009
    Same problem... hoping to get it fixed soon
  • sarah637 Apr 23, 2009
    Same problem, tried replacing ac cord, still having same problem
    Scholar:
  • 47 Answers
Try these troubleshooting steps:
1. Turn the frame off.
2. Unplug the power cable from the wall outlet.
3. Remove any memory card or flash disk from the frame.
4. Connect the power cable directly to a wall outlet.
5. Turn the frame on.
6. Use a paper clip to press the button inside the pinhole on the back of the frame.
If after trying the above steps and the frame still have the same problem, then we need
to send the frame in for a repair as per warranty guidelines.
Your frame will be repaired per warranty guidelines. A product is warranted for 1 year from the date-of-purchase. For an In-Warranty repair, a “Proof-of-Purchase” is required. If the repair center finds any customer induced damaged, the warranty will be voided and you will receive a notification from the repair center in such cases.
Process the repair at www.kodak.com/go/itg
Posted on Jan 04, 2010
Maytag dryer stops after few minutes
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Feb 21, 2015 | Maytag Dryers
What Could Cause My Computer To Shut Down For No Reason?
What brand of pc is this? Download a diagnostic program to test internal functions. Sounds like maybe a motherboard or power supply issue.
Jul 28, 2014 | Dell Inspiron 530s Desktop Computer
My HP Pavilion a820n pc desktop fan runs constantly. I don't think it always ran this much. Previously ran then shut off then ran. We vacuumed the visible dust. Does this signal a problem? Thank you. ...
Fan is inteligent, has sensor when cooldown is reached auto slow down to fix needs to be replaced,will not hurt anything system running cooler is always a good thing i would run it till it dies unless noise is an issue
Jan 20, 2011 | HP Pavilion A820n (PP165AA) PC Desktop
Whenever I open Pinnacle Studio 12, a box appears, titled 'Abnormal Shut Down Detected'. It reads: The last time Pinnacle Studio Plus ran, it did not shut down correctly. What would you like to do?...
Continue. Continue working on the same project
New Start with an empty project
Open. Open an existing project
Sep 11, 2010 | Pinnacle Studio Version 12 for PC
Engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
1991 lesabre wont start after shutting down. If it sits a few hours starts up great again. changed plugs, plug wires, coil pack, and Ignition control module but still same problem. ran a little rough but...
Best to do a fuel pressure test, pump might be weak and dosent show up until it gets gets warm. Best to do the test after it quits again when pump is at its hottest. If you havent done it yet chg. fuel filter too.
Mar 26, 2009 | 1991 Buick LeSabre
Slide projector won't stop auto-advancing
The problem is "continuous cycle", a fairly simple adjustment to the cycle switch lever. Remove the lamp module & unplug the projector. Turn it upside down. Remove the 6 T-15 TORX screws from the bottom cover. The lever is a "J" shaped wire near the center of the projector. Refer to the attached diagram for help locating. You will have to carefully(!) bend the wire down - a very little at a time. After each bend, plug the projector in and cycle it a few times. If it continues to cycle, shut it off - unplug it - and bend a little more (too much is bad: the wire can break or "trap" the cycle mechanism. You want to get it in the center of the pad, as the picture illustrates. Good Luck !!
Sep 12, 2008 | Kodak Carousel 4600 Slide Projector
Cannot open file
Sir, I was working in a PM file. Computer shut down before closing the file. While opening the file Showing " Cannot open file. closing publication, some work may be lost. open the previously saved publication (8009:20551) "Continue" While clicking continue not opening the previously saved file.
Jul 24, 2008 | Adobe PageMaker V7.0.2 for PC
Kodak EasyShare SV811 (8858946) Digital Picture Frame Logo
286 people viewed this question
Top Kodak Photography Experts
paul
paul
Are you a Kodak Photography Expert? Answer questions, earn points and help others
