Question about LG DLP Projector 1400Lum RD-JT30 Multimedia Projector
Lamp hours expired
Model DS125.How Do i reset the lamp hours?
  • 2,237 Answers
Unfortunately, lg won't tell anyone outside of their service center how to do this. they even recommend that you send it to them. it's their way of ensuring return business. sorry.
Posted on Jan 28, 2010
Hi, I have a Panasonic PT-Ae900e Lcd projector,the lamp has now expired, the unit just shut down. Reading the manual it requires a reset of lamp runtime hours,as it shutdown itself we missed the corridor...
Check for lamp if it's properly installed. You must have screen on yor tv in order to reset lamp time(make sense ?) or your lamp is ok but ballast is burnt?
Hope this will help You
Aug 15, 2011 | Office Equipment & Supplies
We use NEC MT1065 and just replace its lamp but it still won't switched on (lamp indicator led is red). How can I reset it ?
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, if your old lamp has only had the reflector replaced then it will make no differance because the chip tells the projector weather or not to power up depending on the hours its counted, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention, just as an added note, a solid red lamp indicator light means that the lamp has expired, if its flashing red this means its nearing the end of its life, if the status indicator light is flashing then there could be another issue, by counting the flashes you can reffer to the manual in the troubleshooting section to diagnose the fault, I know this is very late, but anyone else reading this may find it helpfull.
Nov 29, 2010 | NEC MultiSync MT1065 Multimedia Projector
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
A warning pops up on the screen of my Panasonic PT50LC13 That my lamp needs replacing and I need to reset the lamp timer, how do I reset the lamp timer?
After replacement of lamp, turn on TV, press and hold Volume Down button on TV front and press and hold Split/ Play button on TV remote at same time for 6 seconds.
That will reset lamp timer and confirmation display will come at TV screen.
Above info are also available in original Panasonic replacement Lamp box.
Aug 19, 2009 | Panasonic PT-50LC13 50" Rear Projection...
T V won,t come on and timer lamp on front panel stays lit.
Your lamp hours have expired. Try taking the lamp out then putting it back in. The TV will go to a reset menu for the "new" lamp it thinks that you have put in. From there you can reset the lamp hours from the menu. It it doesn't work, the lamp may be burnt, and you have to replace it.
Aug 13, 2009 | Samsung PCL542R 54" Rear Projection...
Need to reset lamp hours for KDF-E55A20
This model does not require lamp timer reset, put new lamp securely and power up TV for picture.
Jun 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
InFocus Sp500 lamp replaced after hour limit expired...Yet still not picture and red light blinks twice. Is the unit confused...How do I resolve?
On some infocus proj, the lamp door has a switch that usually has to be correctly positioned to reinstall lamp door, if it was working correctly befor lamp change check here first. if no pic at all check all connections to video equipment something may have come loose. If you get a picture try the factory reset/
Jan 06, 2009 | Televison & Video
Sony Wega, 60" LCD
I hope you know the light engine to these sets cost 1,900.00 up to 2,500.00 also did you reset lamp timer when you installed new lamp to tell set lamp has 0 hours on it?
Nov 27, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
256 people viewed this question
Top LG Office Equipment & Supplies Experts
Jaime Hernandez
J.D. Browning
J.D. Browning
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
