Question about Toshiba Televison & Video
Dvi to hdmi no picture on hdtv
Ive got great problem.im trying to connect my computer to my 65h84 hdmi tv.i have the right cable. computer dvi to tv hdmi,30 ft.i have radeon x1050 256 mb.im using catalyst software.iam using vista premium.i selected hdmi on tv.but the tv's blank/black.the catalyst software detects both monitor and tv at right resolution..but no picture on tv. why?does the tv have to be on a certin channel?and help would be great thanks in advance. mike
  • 25 Answers
If you to have a newer tower that has a dvi trapazoid female receceptor.Read the small print
they may say digital ,but never mention HD Bastards!
Posted on Feb 06, 2009
How do i set up multi screen on my 42" HDTV Insignia
You may use an HDMI / DVI cable to connect to your computer. Next if you have windows 7 hold your windows key and hit the letter "P" (for projector) this will allow you to bring on the multi-montior feature on your computer. Make sure to select the option that says EXTEND. Please note that when connecting a DVI device you must use the HDMI IN1 (dvi) jack on the back of your TV. you cannot use HDMI In 2.
1. Turn off your TV and all connected equipment.
2. Connect an HDMI/DVI cable or DI-HDMI adapter between the HDMI in 1 (dvi) jack on the back of your TV and DVI OUT jack on the DVI device.
3. Connect an audio cable between the DVI audio IN jacks on the back of your tv and the DVI audio jack on the dvi device.
turn on the tv then turn on the dvi device.
May 02, 2011 | Computers & Internet
What do I need to hook it up to an hdtv...what type of cables..DVI-D to HDMI?
Your laptop will need a HDMI output or a DVI output for HD video. If your laptop only has a VGA out the your tv will need a VGA or DVI input. You could use a vga to dvi adapter if your tv does not have a vga connector. They do have a DVI to HDMI adapter but there are a couple of problems with that. One you will not get the sound and the TV will only obtain sound from HDMI cable when connected that way and Two the TV will have problems processing the signal from the computer due to the HDMI will only process the HD signals at certain formats and the computer video can send out many different signals. I tried and I could not get my tv to process the signal so I got a video card that has a HDMI out and my blu-ray player works great.
Sep 24, 2009 | Acer Aspire 3680 Laptop
No picture
Try going into your display settings on your PC and reduce the resolution down to VGA or one higher and see what happens.......Let me know
Feb 03, 2009 | Toshiba Televison & Video
Hooked up a hdmi/dvi cable
try using the red- blue- green high def connections
Dec 08, 2008 | Hitachi 57F500 57" Rear Projection...
Samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
Connecting an LCD TV to a computer to use as TV and Comp. Monitor.
Im no expert on the subject, but I use my L37 for a monitor, and use just the vga adapter. It works good as a monitor, and both dvds and my hdtv wonder tuner card look great through the vga connection. They do make adapters for dvi to hdmi. Although, hdmi also carries sound, but you wont get that out of your dvi output from your card. So you might not have sound when using that connection, as your tv may not look to the headphone type jack used for sound imput from your computer when you select the hdmi source on it. If you have speakers already connected to your computer you may not care. Also if you have a 720 p Vizio, 1366x768 is the highest resolution you are going to get out of it anyway, if I'm not mistaken. I'm Not sure why you would need 2 connectios to the same monitor either. I posted 1 link below because they had several dvi to hdmi adapters. Hope that helps.
http://www.bizrate.com/computercables_adapters/products__keyword--hdmi+dvi+d+dual+link.html
Jul 18, 2008 | Vizio L37 Television
Hdmi and audio
It may be the top of set box.. Most times the sound and picture are auto detected by the set when HDMI is used. Both sound and video are carried in a HDMI cable but not with a S video cable. Try another HDMI cable *** dont buy the expensive one the tv don't care if they cost $125 or $25.
May 23, 2008 | Insignia 37" LCD Flat-Panel HDTV
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
What do i need to got sound out of my hdtv?im using a hdmi to dvi cable.
if you have no optional external speaker on the ps3 you may have an earphone socket which can be connected to your tv's pc sound input via a 3.5mm or 6.5mm jack plugs.
Aug 13, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
