Question about Vizio GV42L 42 in. LCD Television
Right half of the screen mostly green and red with vertical strip
My Vizio 42 inch LCD is not quite two years old. The screen is precisely divided in half with the right side having very low resolution and colors only remotely close to accurate with mostly red, green and dark hues. The problem has suddenly gone away a couple of times but has come back. I reset all the settings to factory with no change in the problem.
Appreciate any suggestions. Failing a solution, referral to a repair shop in Sacramento California would be useful.
Thanks.
  • 5 more comments
  • 61vette Feb 07, 2009
    only half the screen is working -any one know a common problem
  • 61vette Feb 17, 2009
    sounds like what mine is doing also-
    my model # p42hd
    thanks
  • Val Schmal Feb 17, 2009
    My Model is Vizio VU42L FHDTV10A
    Thanks.
    bayval99
    Vizio model VU42L FHCTV10A
  • Val Schmal Feb 18, 2009
    There seem to be two boards available for this model, part number 3642-0122-0395 and part number 3642-0112-0150 . Does it make any difference? they both seem to be the same price.
  • Val Schmal Feb 21, 2009
    A search indicates that there are two different mainboards for the Vizio VU42L FHDTV10A. Part number 3642-0172-0395 or part number 3642-0212-0150 . Any thoughts as to which one is the correct board? Does it matter?
    Thanks much for your help
    bayval
  • redfred42 May 26, 2009
    MY 32" TV IS HALF GREEN?
    New Friend:
  • 56 Answers
It sound like there is a problem with the mainboard. What is the model number of the TV?
Posted on Feb 16, 2009
  • phongnv
    phongnv Feb 17, 2009
    For "bayval99" VU42L TV. Replace Mainboard and LVDS cable will solve the problem.
  • phongnv
    phongnv Feb 18, 2009
    For "bayval99", the VU42L has to type of panel, LG and AOU. Each Mainboard part # is use for that specific panel use in the TV. Make sure you get the correct one.
1 inch red and green lines in a strip across top third of tv
Id start by replacing the tcon board, its the small board generally at the top of the set. sometimes under a metal cover
Nov 27, 2017 | Vizio Televison & Video
I have a Vizio SV47oxvt1a flat screen LCD TV with a video problem. Half the screen (right) half displays different colors then the (left) half. Picture is clear both sides, just divided in half.
Most likely the screen driver has failed, thay atached to the screen and not replable! ps I don't fix flat screens under 46'' any more because of price.
Aug 06, 2013 | Vizio Televison & Video
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
Thin vertical red & green lines in upper right of 42 in sanyo lcd
More than likely your control board. Available at www.partstore.com Cost could be between $130 and $200. Not that complicated to install if you can use a screwdriver and are careful. Let me know how this works out.
hardrocko
Feb 01, 2010 | Sanyo DP42848 LCD TV
My 52" Vizio LCD (2 yrs old) has power but blank screen
Looks your power supply quit. Get a new one from vizioparts.com might cost a buck and a half,plus an hour of labor, but 52"? deffinetly worth it! Vizio is good on parts. Make sure, have your serial# ready. some sets have been modified within a year, might get a wrong part without ser#.
Take care.
Jan 23, 2010 | Vizio GV52LF 52 in. LCD TV
Westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Jun 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
P2 42HD - Picture OK on right half ... vertical bars & black on left side
I just got quoted $705 from the Vizio certified repair partner. Nice. Nice and way too expensive. I may as well buy a new TV instead. It certainly won't be a Vizio. They told me a I needed a Y systainer, C systainer and a right-driver board.
Lame. I'm trying to find something local.
May 14, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
Oct 18, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio GV42L 42 in. LCD Television Logo
582 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
