Question about Microsoft Computers & Internet
How to create a multiple access query and put altogether into 1 SQL Scrip(.sql file)
  • 9 Answers
Suggest using Union Query. Thus, you can add more queries from many table and the output will be in one (1) query. Bear in mind that all fields must have same Field Name.
For example:
tblOne contains dtDate1 fieldname. Your query will select [tblOne].[dtDate1] As myDate.
tblTwo contains dtDate2 fieldname. Your query will have the following SQL:
Select [tblOne].[dtDate1] As myDate
UNION Select [tblTwo].[dtDate2] as myDate
Thus the output will result dates from tblOne and tblTwo in a column called myDate.
Regards,
Maha
Posted on Feb 05, 2009
How do I recover data from .mdf file
Detach you database. Overwrite the mdf and ldf files you've restored from your backup with your files from the D: drive. Reattach the database.
There is no guarantee that this will work or if it works, that your database is in a state where you can continue to work with.
If that doesn't work then there is an option to try to restore database using SQL Server Recovery Toolbox. It is a powerful tool for data recovery. They have a demo version. So you can check it works in your situation or not.
http://www.oemailrecovery.com/sql_repair.html
Jan 19, 2016 | Microsoft SQL Server 2008 Enterprise Full...
Tip
How to Create and Remove SQL Server Password
SQL Server is a Microsoft product used to manage and storeinformation. It uses tables to contain large sets of records for thedatabase. Do you have a SQL server and have you ever used SQL server?Do you know how to create a SQL Server passwordto protect your data stored on SQL server? What to do if you forgetyour SQL password? Following it will introduce you how to create a SQLpassword. And it also tells you how to remove SQL Server password ifyou forget as password can be easily lost.
How to create a SQL Server password?
As we know, it is an important security measure to set a passwordfor user accounts and in particular the SA account. And it is very easyfor you to create a SQL Server password. Just follow the simpleinstructions.
1. Open the Microsoft SQL Server Management Studio program from the Start menu bar in Windows.
2. Click on the SQL Server instance on which the new user will be created.
3. Right-click the Security folder, point to New, and then click Login.
4. On the General page, enter a name for the new login in the Login name box.
5. Select SQL Server Authentication and enter a password for the login.
6. Select the password policy options that should be applied to the new login. In general, enforcing password policy is the more secure option.
7. Click the OK to complete the creation of the new user.
Sometimes it happens that you ignore or forget the systemadministrator password. What will you do if you forget SQL password andcannot access to SQL database? The effective way I know is to remove SQL Server passwordwith the help of SQL Server password remover software. MS SQL ServerPassword Unlocker is one of the good MS SQL password remover toolswhich can help you remove SQL password in a few seconds.
How to remove SQL password with Windows Password Unlocker?
MS SQL Server Password Unlocker is handy SQL Server password remover software for you to reset SQLpassword including reset SA password and other user passwords. It caneasily remove SQL Server password for Microsoft SQL Server2000/2005/2008 in a minute. You don’t need to install MS SQL Server onyour PC, and the file in master.mdf format is enough for you to removeSQL Server password and set a new one for it.
Step 1. Download and install MS SQL Server Password Unlocker, and run the application.
Step 2. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
Step 3. Select an SQL account, click Change password button.
Step 4. Type a new password, and then click OK.
This SQL account password has been reset. You can login with the newly set SQL password. Although it is easy for you to remove SQL Server passwordwith SQL password remover, it is better to keep your SQL password inheart. Or you can also write it down on a paper and keep in a safeplace.
on Sep 07, 2010 | Computers & Internet
Repariing 'Suspect' databases
Use SQL Server Repair Toolbox is efficient remedy against the corruption of MS SQL databases and it knows very well how to repair .MDF file in SQL.
For more: https://www.sqlserverrepairtoolbox.com/
Jun 21, 2015 | Microsoft Database Software A5K-02817 SQL...
How to fix mySQL corrupt databases?
you should follow two steps:
Create an appropriately named database on the target machine
Load the file using the mysql command:
$ mysql -u [uname] -p[pass] [db_to_restore] < [backupfile.sql]
Have a look how you can restore your tut_backup.sql file to the Tutorials database.
$ mysql -u root -p Tutorials < tut_backup.sql
To restore compressed backup files you can do the following:
gunzip < [backupfile.sql.gz] ' mysql -u [uname] -p[pass] [dbname]
If you need to restore a database that already exists, you'll need to use mysqlimport
command. The syntax for mysqlimport is as follows:
mysqlimport -u [uname] -p[pass] [dbname] [backupfile.sql]
Or make use of Repair Toolbox for MySQL
Demo version is here-: http://www.sql.repairtoolbox.com/
Feb 08, 2015 | Microsoft SQL Server 2000 Standard Edition...
What is SQL?
It is a special purpose programing language. Computer language you will never use, unless you are into servers or programing type software
Jan 27, 2015 | Oracle 10g Database Standard (ODBSEONUPP0)
How to Change SQL Server 2005/2008 User Password
There is one SQL password recovery tool, SQL Password Genius, which would help you to successfully change SQL Server 2005/2008/2012 user password instantly, especially when you couldn't think of other ways for it.
1. Open SQL Server Configuration Management and stop SQL Server Services.
2. Install SQL Password Genius full version and run it on computer.
3. Click "Open File" button to import master.mdf database file into this recovery tool.
4. Select user in list and click "Reset" button.
Instantly, new user password would be available for SQL Server logon after you type new password for user.
Now, SQL Server user password has been changed and you can login into SAL server now. But please remember to restart SQL Server Services before you access to SQL Server with user password.
Jul 04, 2014 | Microsoft SQL Server 2008 Enterprise Full...
I want to programaticaly modify an SQL statement in VB6
If I remember correctly you need to call ExecuteQuery or something similar otherwise it does not update the database.
Regards
GeWiz.
Jun 16, 2009 | Microsoft Visual Basic Enterprise Edition...
SQL server won't work on my laptop
Two ways to access your server. First, make sure the SQL Server Service is running. Start | Run | Services.msc | Enter. Look for Microsoft SQL Server Service and that it's running. Or Look for the SQL Service Broker icon by the clock and see that it's running. The default instance of SQL Server uses the Hostname. Start | Run | Cmd | Enter. The type hostname. This will be the name to access to server. Then type IPCONFIG, this is then the IP address that you could also use to access it.
SQL Server runs on port 1433, so any firewall has to have it open.
Open Query Analyzer, type in the hostname or ip of the local box, type in "sa" and the password for sa (if setup in mixed mode) or Windows Authentication.
Once you login in, you should now see the databases in the Tree on the left side under the Server | Databases node.
Your description though states "SQL Server won't work on my laptop". TO answer this, the only two SQL Editions that work on anything other than "SERVER" software is SQL Professional and SQL Developer. All others have to be on a "SERVER" platform.
Aug 30, 2007 | Microsoft SQL Server 2000 Standard Edition...
Viewing ms Sql Server database on Access
Are you familiar with "Linking" tables in Access? In Access: File --> Get External Data --> Link Tables. This will bring up a dialog box which allows you to browse to your SQL server and select the table you want.
Aug 23, 2007 | Microsoft SQL Server Standard Edition for...
Running SQL queries on Excel
Another way to do it is to use the SQL Drill freeware Excel addin (http://www.sqldrill.com)
hth
Aug 14, 2007 | Microsoft Office 2003 Basic Edition...
Computers & Internet Logo
109 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
