Question about HP - HP Photosmart 8250 printer
HP 8250 Prints wierd stuff on computer boot up
The printer starts printing out when the computer is booted up, there is only 1 line of text that it prints at the top, it always starts with:
USB then has a bunch of letters & symbols for example: USBCUQNI$C(SPADE SYMBOL)(UP & DOWN ARROWS)$USBCSDOM(C or USB RUT
  • ssaaward Feb 16, 2009
    Printer always feeds three sheets with code printed at the top on startup. I have always assumed that it was caused by my not disconnecting the printer when I re-installed the software in the PC.
Used HP's chat, they helped walk me through it. NO CHARGE! You push the 'on' button for 45 seconds after you disconnect all the cables. Plug in the power cable only. Then print a test page. If that works, plug in the USB. Should fix the problem. I'd recommend working with HP, as they can check the internals on your machine while you chat with them.
Posted on Feb 16, 2009
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Printer printing blured images and text. It looks as if the printer prints a line then about 1/8 to 1/16 if an inch it prints the same line again.
You need to run a new alignment on the machine, Assuming you have the software installed open up the hp help center and print an alignment page after that look at the numbers and letters and line up the marks by selecting the numbers closet to the perfect alignment that you can see after you have finished click on the front of the printers OK button.to finish they try printing a new page. If this does not help try updating your software at http://www.hp.com.
Dec 24, 2009 | HP PSC 1210 All-In-One InkJet Printer
I can print from Word on my HP 5150, but it prints multiples
sounds like a problem with the printer software, try uninstalling & then re-install the printer driver
Aug 03, 2009 | HP DeskJet 5150 InkJet Printer
Photosmart 8250 won't print, says computer is off-line
Make sure printer is connected to computer.
Go to Start ,Control Panel ,Printers and make sure it does not say offline.
If it does right click it and select the option online.
If it does not then remove it and reboot the system.
Jul 28, 2009 | HP - HP Photosmart 8250 printer
My HP LaserJet 1100 prints a line of @'s
This is either a bad driver, which you can reinstall from your PC or the formatter is no good.
Mar 18, 2009 | HP LaserJet 1100 Printer
Slow start
Go out to hp.com support - downloads and check what they have for your 8250, there will probably be one to correct your problem, I use hp exclusively and have updated all my software and drivers recently.
Aug 12, 2008 | HP Photosmart 8250 InkJet Printer
Photosmart 8250 printing computer codes
my printer photosmart 8250 is printing does not print it says ink system failure when i try to replace it the yellow ink jet so please please help i'm in third world country my email address is abrbw@yahoo.com please help again
Jul 17, 2008 | HP Photosmart 8250 InkJet Printer
Printing from e-mail
The problem you are having is caused because you are printing from a web based email and just clicking print prints the email, the frame and all the advertising on the page.
to avoid this try the following:
1. Doubleclick the email to open it, not just use a preview pane.
2. Highlight just the text that you want to print. (You can click the cursor at the beginning of the text, hold down the CNTL Key and then press down arrow till all lines of text you want are highlighted)
3. Click FILE, PRINT on the browser menu (DO NOT CLICK THE PRINT ICON)
4. A Print window should appear, in the PRINT RANGE section, click SELECTION, then click OK. At this time, only the text you selected should print.
May 16, 2008 | HP Computers & Internet
Every other line prints only bottom half of text.
I have a psc 2355 printer which only prints half of text then the next lines are ok then it repeats only printing half text. I removed my ink cartridge and wiped the ink ports with a tissue heavily moisten with water. Repeated this several times and then gently dried with a tissue. The problem was fixed!!
May 08, 2008 | HP PSC 1610v All-in-One Printer
303 people viewed this question
Ben Johnson
