Question about HP Photosmart C4480 All-In-One InkJet Printer
HP C4480 3 in 1 set-up difficulties
Maingame123,
Thanks for trying to help. Did you see my comment? I'm not at all sure used the correct way to answer you.
pickwickpark
I ignored the installation info. being presented on the little screen, and proceeded with the installation as outlined in the directions. At one point in that procedure I again tried one of the buttons to the left of the screen (labeled Scan/Reprint, Start Copy Black, and Start Copy Color in the manual), and lo and behold, this time they worked as "arrow" keys. (They had not, earlier.) I am very annoyed at HP for neglecting to include this simple piece of info. in their manual, and thus wasting my time and that of the kind attempt at assistance by one of your volunteers.
Posted on Feb 05, 2009
I tried to update the firmware using the solution you sent to me but it never waorked ie. c:\>Documents and settings\Administrator "c:\Documents and settings\Administrator\Desktop\ljp3005fw_02_130...
Hi
Please post your message back into the previous question by clicking on " reply " or
" add a comment " so you can reach your original correspondent .
Thanks .
Best regards ,
fanaudi .
May 23, 2011 | HP LaserJet P3005dn Printer
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HEWLETT-PACKARD HP 6500 All In One Printer...
I have an HP photosmart 6380 and I cannot set the printer to accept a 6 x 9 invitation; keeps telling me printer mismatch!
You'll need to check the printer settings and make sure you've set it up correctly, and fed the paper correctly. See this article for help.
If that doesn't work, make sure you don't have a barcode on the back of the printed paper. (see here.)
If you get any further error messages, you may be able to answer them with help from your home support page here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Print Quality Poor - HP Photosmart 2575 All-in-One
You can download the manual from Software & Downloads here.
Then work through this article and see here to diagnose the printing problem. Make sure the print quality is set for photos in the print preferences or properties.
You might try cleaning the cartridge contacts as described here.
Make sure you are using a good quality paper, that it is feeding correctly,
Jul 30, 2009 | HP Photosmart 2575 All-In-One InkJet...
I have Windows Vista with an HP Deskjet F380 all in one. It will print but will not scan. I have downloaded from HP the drivers and all updates, but still nothing.
From your description, it's hard to say why it won't scan....Does it start to scan, or is there no response from the scanner at all?
Try resetting the machine, then try again. (instructions here) Make sure it is set up correctly and do not connect USB until prompted by software (see here).
If that doesn't work, see this article and this article and make sure you have a good power source for your computer and printer. Also make sure you use a usb port on the back of the computer.
Your home support page for HP is here,
Jul 10, 2009 | HP DeskJet F380 All-In-One Printer
HP L7780 wont copy from the glass
HP instructions for this operation here. See this article. and this article to change the default settings.
If these settings are correct and you still can't copy from the glass, try a partial reset as outlined here.
Jul 08, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I have the HP officejet 5610v all-in-one printer. It prints,scans,fax. It prints but the scanner will not work. It tells me It isn't connected to the computer. I don't know if its because I don't have the...
Go here to HP.com, enter your model number under support. Make sure you have installed and set up the printer correctly. (see here) You may have to uninstall and reinstall, and make sure you wait for the prompt to connect the usb cable.
Search solve a problem and look under scanning., or click here. and read through the solutions that apply or may apply to your situation.
Jun 15, 2009 | HP Officejet 5610 All-In-One InkJet...
I have Windows XP and want to use Canon Multipass F50 printer. I have downloaded the print drivers from the Canon website. My system is recognizing the Canon Inkjet BJ S630 . I was given instruction to...
Are you sure you downloaded the right drivers, and the one's needed for your OS? Please check the canon link here. I would try reinstalling them just because your system is seeing the wrong printer to begin with.
The error message in the print queue can be troubleshot by using the windows help & support print troubleshooter (available from control panel>printers & faxes> printing troubleshooter) or using the windows event viewer to see what error code is reported and tracing the cause of the error that way...
Frequently in such a case uninstalling the printer drivers and installing them again will correct the difficulty...also see this MS link.
May 13, 2009 | Canon MultiPASS F50 All-In-One InkJet...
I can turn on my HP but it doesnt function!!!
Please go to control panel> printers and faxes, and choose your printer and make sure it is set as default printer.
If it is set so already, please try to print from Word and note the exact error message you are getting and report back. Include your operating system info.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 09, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
I can't fax....HELP
Yes. But your fax machine must be hooked up with a standard phone line to the jack on the wall, or to a computer linked to a standard phone line. You can't simply hook the computer up to a dsl ethernet cable and hook the usb cable up to the printer and expect fax services to work.
Hp has an excellent support site for use with it's printers, available by clicking here Please take a look at this fax set up link by clicking here to make sure the fax is set up properly,and if it is and you're still having difficulty, take a look at the main site solutions section to troubleshoot your particular machine.
Apr 06, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
HP Photosmart C4480 All-In-One InkJet Printer Logo
143 people viewed this question
Seeker5211
Seeker5211
