Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker model # jvm16505ho1 won't stay running
I reprogramed clock/date, put some chicken in, and hit express cook for 1 min, after it ran for aprox. 3 to 4 sec. it would shut off, then I kept repeteing the proceedure, with no sucess.
I have the same problem. It was/is a wiring issue behind the key pad. I unplugged the microwave and took the vent and key pad covers off - heed all warnings. Using leather gloves and needle-noze pliers, I removed the wire ties and reposition the wires. I also checked the plastic connectors for looseness. It's currently working, but for how long who knows. Mine is 3+ years old. I will never by another GE product.
I suggest you don't tackle yourself as the capacitor can hold thousands of volts even w/ the unit unplugged. Be careful.
Posted on Feb 06, 2009
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I need the specs (size, height, width etc) for the GE Spacemaker XL Model#JVM1631WB 004
Specs are:
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWave™ Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5 speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9 Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6 codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto & Time
Delay Start: Yes
Display On/Off: sub-pad w/ zero
Express Cook: Instant-on 1-6
Reminder (24 hr): Yes
Time Cook: I & II
Time Preference: Control Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire Oven Rack
Sound Volume Control: 4 levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless Steel
Door Color: Black/Stainless Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63 lb
Overall Depth: 15 5/8"
Overall Height: 16 3/16"
Overall Width: 29 7/8"
Cavity (W x H x D): 20 31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table does not work. How do you fix it? I have a GE Spacemaker XL 1800, Model # JVM1842BD. Thank You
i have a ge 1800 model and it cooks fine but after awhile it shuts down and in about a hour it comes back on and ask you to set the clock.....
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Is not cooking
sounds like the magtron is gone out.
Call GE answer center 1-800-626-2000 ask for tech help. Have you model # off the data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Model JVM1860CD002 The oven comes on all by itself, starts in the express cook mode. This could be dangerous Rob
Beelow statmwent is refering to you appliance manual with also contains the wiring diagram. I woudl speculate that the clock/ timer wil turn out to be the problem since you said that you cannot set it.
Microwaves: Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel
http://www.geappliances.com/service_and_support/faqs/
Dec 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave comes on all by itself, starts the express cook mode
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
GE spacemaker xl microwave oven JVM1440 Two weeks ago after I press 6-express cook stopped and all the lights and clock went blank. In a 10-15 minutes it came back on and the clock would have to be...
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cuts off after 2 seconds
Just a hunch; plug it in to a different outlet.
AC outlets are only marginal when new and that unit can draw well over 10 amps.
If the contacts are failing, the unit will think it has been disconnected, killing off the clock setting too.
If that doesn't help, try plugging another high power appliance, an iron, toaster or coffee maker, into the same outlet used for the GE to see if they behave normally.
Jul 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
54 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
