Question about JVC KD-AVX2 Car DVD Player
Help with subwoofer connection
I' have a car stereo and i' have two outputs for subwoofer
They are both RCA type. i' want to connect one 8" subwoofer do i' need a amplifier
My car stereo is soundstream Vir-7011NTB
  • 1,990 Answers
Yes, You will need an Amp for this Settup. Check the Rated Power of the Subwoofer and Get an Amp that will Supply this amount of Power. Please Rate My Response! Thanks!
Posted on Feb 05, 2009
How should i connect my subwoofer- is it directly to the speakers or amplifier?t
I'm assuming that you are using a standard amplifier with L and R speaker outputs if a stereo Amp.... or L and R and SUB standard RCA output jacks. If it is a more complicated setup, having surround sound speaker jacks, then look for a SUB OUT jack or plug.
Some Subwoofers are self-powered, having their own, built in amplifier especially designed for that model. Sometimes they require a SUB connection and a power supply to the 110V AC house power too. These sometimes need a connection to a standard 3.5 mm HEADPHONE jack output plug. If it's this type, then the front of your amplifier could have one. Either way, the musical signal from amplifier to the subwoofer must be available on your Amp AND be received by the type of subwoofer you are using.
Mar 04, 2015 | Audio Players & Recorders
How do I connect a DVC (4 ohms each) single subwoofer to a Profile California 2600 amp (2 ch. with bridging) for best match?
As long as you are using only one rca signal input, and physically splitting it with a splitter or even just leaving only one channel connected, and the other empty, wire each coil to each of the amp channels. There won't be stereo separation (of your woofer). It should be ok. Better than 2ohm bridged load, or 8 ohm. You will lose output at 8 ohms, but your amp will never overheat and your soeakers will last forever. Lol.
Feb 03, 2015 | Profile Car Audio & Video
How do hook up an amplifier and subwoofer to my car stereo?
If your stereo has preamp outputs, I would recommend connecting those to the input RCA connections on the amplifier. The connection from the amplifier to the subs is dependent on the capability of the amp and the impedance/power level of the sub.
Aug 31, 2014 | Car Audio & Video
Jvc KW-AV50 subwoofer amp hook up
very good ! there is nothig wrong with your system, buy a stereo to mono RCA jack (Rs10/-) and connect the subwoofer (if single coiled) L+ & R-- of your existing amplifier. NB: Please go through the manual of amplifier
Apr 08, 2012 | Car Audio & Video
How to install kicker amp to a 1995 f-150 new
nice radio bud. also want to say that the kicker amp will take the input from the stereos rca subwoffer out port on the back of the stereo, i have read about your radio before answering your questions to ensure acuracy.
Taken Directly from your manual
Press and hold the SEL button until LCD display “DSP OFF”. Press SEL button again and LCD display “WOOFER OFF’. Rotate volume to activate the subwoofer control function, then leave the unit idle for your desired setting to take effect. Make sure the unit is connected to an external amplifier.
RCA Line Out
The RCA Output Jack is on the back of the
unit on the right side. (See figure 1) This
output is for connecting an amplifier, equal-
izer, or other audio component that requires
a pre-amp out connection. (Red = Right,
White = Left) Follow the manufacturers in-
structions for the audio component that you
are connecting
The Subwoofer Output Jack is on the back
of the unit on the right side.
on page 8 of 22 on this ebook illustarted the proper wireing configurations for an aopmilifier. note: the remote wire must be conencted to the radio to the amp remote to allow radio to trun amp off and on good luck.
Aug 22, 2009 | Car Audio & Video
My amplifier has one pair of rca inputs. radio only has 1 output
Subwoofer signals should be MONO - not stereo (hence the single Component out on the radio)
Only use one RCA to send signal to your amplifier.
If you use a Y splitter - the signal voltage will be cut in half - deteriorating the quality, and therefore amplifying "dirty" signal.
If you require further help, simply reply to this thread.
Thanks for using FixYa - a FixYa rating is appreciated for answering your Question.
Apr 09, 2009 | Jensen Car Audio & Video
Dayton sub-100 connection
You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
Feb 27, 2009 | Bose 151SE Main / Stereo Speaker
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Subwoofer connection
    if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
    Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
    JVC KD-AVX2 Car DVD Player Logo
    262 people viewed this question
    Top JVC Car Audio & Video Experts
    xxxxxx xxx
    Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
