Question about E-Machines eMachines Desktop PC
Emachine t6532 motherboard issue???
I was downloading xbox live update and in the middle of the download the computer just shut down. would not turn back on. checked power supply the fuse was roached. burnt. got new power supply nothing. how can i check the motherboard and what is the wire placement for the power, led, and other wire?
  • AUTIGER Feb 06, 2009
    I have two e-machines and after normal use, neither with power up. What do I do to find the problem?
    Scholar:
  • 127 Answers
Is your new SUP has the same specs with the old SUP? like voltage output, WATTS etc....
Usually motherboards have a led light in it that will light up when its connected on SUP.
regarding the wire placements for power and led connectors, you can view it in your users manual.
Posted on Feb 05, 2009
When I try to install SP3 on my eMachine T6532, I get a Blue screen error during installation. How can I fix this?
This could possibly be a driver issue. Please disconnect all devices connected to the computer other than the mouse, keyboard and monitor during installation. If installation completes successfully, then you may reconnect the devices.
Dec 23, 2010 | eMachines T6532 PC Desktop
T6532 emachine doesn't start up and fans run @ hyper speed
I suggest you open it up and check for bad capacitors. I have a T1742 right now that I am replacing capacitors on. They're round, a little bigger than a pencil, less than an inch tall and the ones you will be looking for are close to the microprocessor heat sink.
They are supposed to be perfectly flat on the top (you'll see plenty of others on the motherboard that are still good.) If they have bulged out or bulged out and leaked, they are bad.
Replacing these is not easy, you have to know where to get the parts and how to solder items connected to ground and voltage planes on a motherboard.
I'm sorry, but unless you can fix this yourself, or know someone that will fix it for you, your computer is now done. The cost of taking it into GeekSquad is more than a buying new cheap computer. And with WinXP you can't just take your hard drive out and put it into another old computer and make it run. Before you take it to recycling though, remove the hard drive, as you should be able to connect it to a computer and still get all your information off.
Sep 19, 2009 | E-Machines eMachines Desktop PC
Driver downloads
You need to go to:
control panel
-system
-hardware
-device manager
-network drivers
if there is an exclamation mark within a yellow sign .. this means your driver is not installed and your network card will not work untill you get the driver installed which will identify to your motherboard that the device is network card.
I would suggest going to google and search the motherboard model number for drivers and go to the e-machines website or actual manufactuer website for genuine drivers then install it. The device should work.
Sep 14, 2009 | ASUS P4XP-X Motherboard
Where can i get an emachines motherboard
Go to http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T Series&model=T6532 There you will find all specs and downloads for your machine. Then once you get the motherboard type you have you can go to tigerdirect to find motherboards.
Sep 02, 2009 | E-Machines eMachines Desktop PC
T6532 monitor screen faded
There are a lot of things that can cause this kind of problem. You might try swapping out the cable connecting the monitor if you have an extra, or if you're lucky and own another computer, you can try to use another monitor, or connect another tower to the monitor in question to see if another computer works better with it.
If you've determined that it's not the monitor or the cable, it's most likely going to be an issue with your graphics adapter. If you are not comfortable messing around with the interior of your machine, a shop could help you do further testing to see what needs to be done. Most likely, a new motherboard will be the solution, since your particular computer's graphics chipset resides on the motherboard itself.
As a final hint, I've seen a lot of Emachines with motherboard issues at my primary place of work. You might try contacting Emachines if the machine is less than a year old, since it would fall under manufacturer's warranty and you can get the board replaced for free.
Apr 09, 2008 | E-Machines eMachines Desktop PC
Xboxlive update
Xbox Live is having problems guys they are working on it and hope to have it fixed sometime this week the problem you guys are having is due to the xbox live being down. Although it isnt completely down they are having gameing issues as well as download issues and voicemail issues. If you want to find out more you can go to www.xboxlive.com and seach status to see if they have resolved the issue yet.
Dec 29, 2007 | Microsoft Xbox 360 Console
I cant connect to xbox live
From the dash;
1. Navigate to the System blade
2. Select 'Network Settings'
3. Select 'Test Xbox Live Connection'
4. Apply Autoupdate when prompted.
If you continue to experience issues downloading the update for the Xbox 360 dashboard, please contact Xbox Customer Support at 1-800-4MY-XBOX.
Dec 19, 2007 | Microsoft Xbox 360 Console
Emachines wont boot
Bad capacitor(s) on the motherboard can cause this problem, corrupted BIOS maybe... try flashing BIOS.
Probably the CPU if your not getting any error code beeps on startup.. NO Processor for the BIOS instructions thus no Beeps !
Nov 27, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
639 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
