Question about Compaq Presario Notebook
Laptop i have a loptop PC and its windows has been currepted so it needs a fresh installation but i have very very very important DATA in Desktop and My documents and Windows is also install in C and i cant repair the windows bcz i dont have the same CD of windows which is orginal and install in that laptop and some people gave me advices to Take out its hard disk and attach it with other computer to copy the data from C drive but i cant do this bcz i am affraid of its damages, so now if you people gave me ideas what to do?
  • kamalkaker Feb 07, 2009
    Thanks alot from all of you, but i found another solution for it, i booted the laptop from Win98 and i copied all files from C to D from Dos and then i format the C drive and then installed windows in C when i installed i saw that all the files have copied in D so i am very happy.
    Thanks,,
    Scholar:
  • 152 Answers
Use the disc that you have to see if you can repair the installation of Windows. As long as it isn't an earlier version of what you have installed, you can use it. For example, if you are using XP with Service Pack 2 and your disk is XP with SP1, you won't be able to use it for repair. You can certainly take out the drive and attach it to another computer, however, you need some equipment to do this. A laptop hard drive is a lot smaller than a desktop one, so you can't just pop it into an empty slot. You will need to get a laptop hardrive enclosure. You put your laptop hard drive in there, make the connections (it is VERY easy) and then attach the laptop hard drive to another computer. You can then see if you can read the disk that way. Most likely, you will be able to since you aren't trying to boot from the drive. Then you can take off the important data and replace your laptop hard drive and start over with a clean install.
I would be wary of downloading an illegal copy of Windows from anywhere. Those copies are fraught with viri and other malware, not to mention that it is ILLEGAL and you will not be able to update the OS.
Please remember to rate my solutions! Thank you
Posted on Feb 05, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 53 Answers
To be honest your best option is to remove the drive and connect it to another computer.. other than that you can try and download a copy of your operating system using Bit Torrent and use the cd to attempt a recovery. What version of windows are you using?
I want to wipe my operating system
You would need a Windows Install Disc, not be confused with a Recovery Disc. Then, depending on how wanted to proceed, boot your computer with the disc in it, and follow the onscreen options to either create a fresh install, or overwrite the existing one and keep the data.
Dec 09, 2012 | Computers & Internet
I WANT TO FORMAT MY LOPTOP TOSHIBA NB100 MODEL NO.PLL10E-00K01TAR
First restart your Toshiba laptop. Press either "F1," "0," or "F8" to be taken to your computer's hard drive utility screen. The key command differs depending on the model Toshiba computer that you own.
Select "Restore Original Factory Image" from the list of options in System Recovery. Verify that you want to continue the process by clicking "Yes," then click "Next".
Restart the Toshiba laptop once the factory restore process has been completed. You will be prompted to enter information such as the date, time and language preferences.
Feel free to get the reliable technical help at http://www.vtechsquad.com/toshiba-support/ for troubleshoot all kind of Toshiba PCs(laptop/desktop).
Oct 29, 2011 | Toshiba Computers & Internet
The computer when you turn iot on it wont go to window s it says sum about a disk error
It might be that you have an operating system error. This is usually the result of not properly shutting down your computer. Some of the booting files are damaged or it needs reinstallation of new ones. Try install fresh windows copy to another drive to at least save some of your important files and documents. If the problems persist, eventho you installed fresh copy of windows, it might be that your harddisk has a problem. It might contain some bad sectors or bad blocks. In this case you better consult a qualified and competent technician to properly diagnose the problem and save some of your important documents. My best advise is to go to the brand service center for check up, if it is under warranty (within 1 year from purchase) then you will pay nothing. I just hope my info could help u.
Feb 01, 2011 | HP Compaq 6910p Notebook PC PC Notebook
How to unistall the laptop with more than one the same window xp?
if you want a clear and fresh copy of window, it's better to format all drive and re-install a new one. just back up first important data you have.
Apr 16, 2010 | Dell Latitude D610 Notebook
Windows xp is not logging in propely
if no important data inside, you can re install a fresh copy. to make your station work back.
Apr 13, 2010 | Intel Pentum 4 3.2Ghz System (SYP32) PC...
My Emachine T1150 keeps freezing up when it goes to load windows
When you start the system and you system goes to freez while loading window thats means there was a problem with OS,window is currept.you need to ghost means load the new fresh OS.
or if when you install a new window and thats loading time your system goes to freezing mode thats means there was a problem with your bootable CD or CD drive,change it vis a versa worked with another CD & drive and check it .
Thanks,
Jan 14, 2010 | E-Machines T1150 PC Desktop
Hi guys got a problem my compaq presario going to boot menu when i try to start windows normaly or safe mode or recovery date it just restarts & goes back to the reboot page please help.
Sounds like a hard drive problem. Try and boot from a windows instalation cd and select repair windows. If this do not work and you have very important info on your hard drive i would take it to be serviced and data saved. If it is not important data on the hard drive reinstall a fresh copy of windows.Good Luck
Nov 24, 2009 | Compaq Presario Sempron 2.0GHz Desktop...
Missing operating system
HELLO THERE:
First boot into bios and see if the harddrive is being recognised and if it is make sure that the drive is part of the boot sequence if it is you might have to reformat the drive or just reinstall the operating system ok? best regards mike
Aug 17, 2009 | Fujitsu Siemens Computers & Internet
I am on laptop with vista home prem,have completed backup restore from wd 320 usb 2.0 allof my data is corrupted error codes like 80245003 appear cannot fix my laptop
Hi Earlbanga, Do you have an original Windows disk? If you do, just insert it and do a fresh Install, not a repair. And if your in windows you need to back up your important files first, because they will be lost. Good Luck.
Nov 04, 2008 | Computers & Internet
About my loptop
Try right-clicking anywhere on the blackened area of your desktop, a menu might appear. Scroll down to Properties and click. In the Display Properties window click on the Settings Tab and see if you can re-adjust your screen resolution here, if not then read on...
Power off the laptop. Power on the laptop while holding the F8 key or both the SHIFT and F8 key together, if it boots to the Windows start up screen, power off and try again. This will bring up a menu, you will want the BOOT INTO SAFEMODE menu option.
After the safemode boot process, see if your laptop will display graphics (it should default to 640x480 mode and you should be able to view most of your desktop icons). Right click any where in a black area on your desktop, a menu will appear. Scroll to Properties and click. In the Display Properties window, click on the Settings tab and adjust your screen resolution from here.
Let me know if this works or not.
Jul 10, 2008 | IBM Computers & Internet
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
