Question about Toshiba Satellite A45-S150 Notebook
TOUCH PAD I PURCHASED A NEW TOUCH PAD. IS IT DIFFICULT TO INSTALL? IS IT "PLUG N PLAY" OR DOES IT HAVE TO SOLDERED?
  • 596 Answers
The install is fairly easy. You just need to be patient as you 'pop' the case cover to put the keyboard in. Average PC knowledge and you got it. Remember, be patien! If you are opening the case and it seems stuck, check to make sure all the screws are removed. Thier are some hidden screws in some models. Good luck.
Posted on Feb 05, 2009
Amilo MS2212 power input
If by power input you mean where you plug in the AC adpater. No, you will have to completely separate the top and bottom of the case. This means usually unplugging the cables for touch pad keyboard, be careful. Often they are on a dongle. but some are soldered to the main-board and difficult to replace.
Apr 05, 2014 | Fujitsu AMILO PC Laptops
Have switced on laptop 3 times but cursor not moving it's stuck everyting loading but can't do anything
connect a plug and play mouse to your pc if cursor works then pc is fine except for the touch pad that could be deactivated in the control panel settings or the sensitivity needs to adjusted.If this does not work the touch pad is faulty requires replacement advise 2nd hand part from your local pc repair shop new one expensive
Oct 18, 2010 | Computers & Internet
My Dell N4010 Laptop with Windows 7 software indicated a message of "touchpad disabled", and I can not manipulate the mouse.
You are confused. Your touch pad is disabled, but if you plug a mouse into the USB port, your PC will find it and install its software and you will be able to use the mouse To re-enable the touch pad, click on the Windows ball at lower left of desktop, Control Panel, Mouse, Touch Pad, Enable Touch Pad.
Touch pad faulty and cursor jumps and cannot read emails, or type replies, using external mouse, but cursor will wandering. Less tha one year old.
Clean your Pad with a moist wet tissue and dry.
In Control Panel -> Devices manager -> uninstall the mouse/pad driver and either use detect new plug-and-play hardware via the top of the tree in the device manager listing (eg. you Computer name) context menu or simply reboot to force a new re-install of the driver for your Pad and Mouse and see if it solves the problem.
If your Pad is the Synaptic type, install your Netbook driver for the Pad.
Hope that re-installing the driver and Pad utility solve your issue let me know how you go.
ps. Worst case, your Aspire One should still be under manufacturer warranty.
Sep 27, 2010 | Acer Aspire One PC Notebook
My touch pad is nery slow and difficult to use.
Step1: Try by installing Touch Pad Driver.
Step2: If it doesn't help change the Touch pad Grid.
Pharthiphan
Nov 06, 2009 | Dell F3534 Touchpad
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
Touch pad not working
If Windows service pack 1 - doesnot all recent drivers and will not recognize your touch pad and even keyboard.
Try to boot on Safemode.
Just press on F8 when your start your computer - and connect an usb mouse and try to install the touch pad drive manually.
Then boot on normal mode and install your other drivers..
It is recommended to update quickly your os to Service pack 2 or 3 for best performance of your computer.
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Touch Pad Problems
Check for new drivers for the touch pad out on Gateway's website and maybe check in BIOS to be sure that when you plug in an external mouse it doesn't disable the touch pad. Some laptops only let you do one or the other. Also if there is any software for the touchpad aside from drivers try reinstalling that also.
Sep 07, 2006 | Gateway CX2610 Notebook
Toshiba Satellite A45-S150 Notebook Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
