Question about Malber P28 Front Load All-in-One Washer / Dryer
Malber p28 on/off button doesn't work
I've had this washig machine for 6 months. Suddenly, the button won't stay pressed, and so the machine will not start. I'd have to keep my finger on it for 30 minutes to wash my clothes. Any ideas?
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason is your switch got damaged.
Pin that is inside the switch might have broken.
Replacing the switch will solve the problem.
try it out.
thank u..
rate me..
Posted on Feb 05, 2009
  • Hariharanath V Feb 09, 2009
    hi..replace it with a new switch.It is the best
    solution.
    check this out..
    thanks..
    Brigadier General:
  • 8,619 Answers
Hi!
What i would suggest is call Malber people and get it done for free as it is under warranty period.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Feb 05, 2009
    You can reach them at
    Address:
    2115 Byberry Rd
    Huntingdon Valley, PA,
    19006-3503
    Phone:
    215-672-7440
    Fax:
    215-364-8060
  • Rylee Smith
    They are also available at---
    Malber Usa Inc
    61 Commercial Ave, Garden City, NY 11530-6417
    Contact Phone:
    (516) 294-6660
    President:
  • 1,990 Answers
Welcome to Fixya! The Switch is Bad and will need to be Replaced. This is a Really Common repair. If you are not Mechanically Inclined though, It will take a Repair Man about 1 Hour to Repair and the Charge is Pretty Minimum on this Repair. Please Rate My Response! Thanks!
    Master:
  • 848 Answers
It is due to bad lid switch ..........replace the switch ........control board connection need to be checked for loose connections......
Malber P28 washer. On hot water cycle the drum is part filling with water then stopping wash cycle and door is unlocking. I was able to open the front loading door with the drum half full of water - gushed...
Sounds like a control pcb malfunction. Remember that you are dealing with MAINS Voltages which can be lethal.
Never continue to use a machine that floods or enables random water release for any reason. The end result might be Electrocution, and it is certainly not worth that risk
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 04, 2013 | Malber P28 Front Load All-in-One Washer /...
Broke the door handle on malber wd 1000? Do they sell the handle or door?
Sorry to see this 16 months too late.
You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Oct 30, 2012 | Malber WD1000 Front Load Washer/Dryer
LG WM2277HB start button won't start cycle
Either the button is damaged or the switch it operates is malfunctioning.
Suggest you get a Technician to pop in and check it out while there is still plenty of life left in the machine!
Poppa
Sep 23, 2012 | LG WM2277H Front Load Washer
Machine won't go in to spin and cloth stay wet
Hi alvism,
The drain pump may have something clogging it up, or obstructing the pump impeller, easy fix, see my Tip below:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards d')
* If you found this solution helpful, please rate it.
Jul 21, 2011 | Malber P21 Front Load Washer
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Press start button nothing happens - malber p28
If you've determined the unit has power, does it fill with water, or just nothing ?
Sep 29, 2009 | Washing Machines
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine.  This works for mine to get the dryer to run by itself.  It should begin about 30 seconds later, when the door locks.  Hope this helps.
May 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Snap-on spigot coupling won't stay connected
Sounds like too much water pressure or, more likely, the coupler has worn down. You can get a replacement at most hrdware stores.
Nov 03, 2006 | Malber WD1000 Front Load Washer/Dryer
Malber P28 Front Load All-in-One Washer / Dryer Logo
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
