Question about Dell Inspiron 1501 Notebook
Laptop will not restart
Insperion will not restart or vopen normally.
The screen is blank. I have to kill power to try starting it again.
What the heck is going on?
  • 1 more comment
  • covingtonsno Feb 06, 2009
    How do I reinstall os? thanks
    The bios screen does come up when the start up option comes up. I have to try safe mode or even last configutration.
    I took the battery out because it has been a dud from day one. Oh, I am the lap top question.
    Tahnks so much!
  • mriver7432 May 11, 2010
    does your main bios screen come up where you have the option to go into setup
    Scholar:
  • 127 Answers
First thing is to check your power supply if its giving a correct voltage for your notebook. if its ok...try to remove your battery and unplug it in then press the power button for about 60 secs. then try to start your notebook in AC (without battery)
If the problem persist, remove the RAM inside your laptop and clean it from dust (also clean your fan and heatsink from dust) then return it back and also check for loose wirings and cable connections.
If everything fails...then you have a bad motherboard (overheated).
Posted on Feb 05, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..Any one of your window file might
have got corrupted.so the best choice
is to re-install the os.
try it out.
thank u..
rate me..
Why am I getting a blank screen after login?
In case you are using Win OS try to start in save mode. First the Bios is activated after pushing the power button. If you see the screen from the Bios start pushing F8 which brings you to the save mode start up. When your PC starts you can shut it properly by leaving the save mode. Try to start up the pc again in normal mode. I hope it will fix you problem
Aug 26, 2014 | Toshiba Satellite Computers & Internet
Dell insperion windows 7 turns off and beeps will not turn on for a while
This normally happens when the laptop overheats as it seems to have an inherent heat problem with the Insperion. Normally needs to cool off before poweron attempt is done again
Jan 10, 2014 | Radio Communications
Dell insperion 530 screen is black with amber power light
Seems like you had a hardware issue.Try first to reset the memory sticks and the other is the HD.Is the HD is burn try a used one or buy a new one and reinstall the OS.
Dec 05, 2012 | Dell Computers & Internet
Laptop is run and start but no display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
Laptop not starting properly
follow these steps & ur issue might get resolved(80% chances):
turn off ur notebook-->take out the laptop battery(not the cmos battery)-->disconnect the charger if its connected to the notebook-->now press & hold the power key for atleast 20 seconds, remember that u have to press & hold the power key & dont release the power key till 20 seconds are over--> & ensure that the notebook is not connected to any power source while u r performing this step niether the battery nor the charger--> also there shouldn't be any peripherals connected to the notebook-->once 20 seconds are over & u have released the power key-->connect the battery & the charger back to the notebook & now try to turn on the notebook-->u might not get a blank screen & ur issue might get resolved, turn off ur notebook again & restart to ensure that its not reoccuring....(This whole step is known as power drain & it is done to remove the extra static electricity which sometimes get stored in the notebook & gives a blank screen in return.)
Jul 11, 2010 | Computers & Internet
Yesterday I reinstalled my windows on my laptop which has 20 gb hard disk, i created two partition drive c (5 gb) and drive d (15 gb) and installed successfully. after that i put my pen drive and copied...
you killed the laptop with out a UPS and you get a power surge with a dead battery them laptop takes the surge and kills the computer. You can remove the battery and unplug the power supply and hold the power button down for a minute then plug the power back in without the battery and try pushing the power button to see if it comes on if it does your lucky. IF it does not put the battery back in and try again. if There is still no power you have killed the power converter or killed the computer.
Feb 05, 2010 | IBM ThinkPad A31 Notebook
Hang up
Possibly due to corrupted graphics driver, or resolution changed to one unsupported by your laptop. Try restarting in safe mode by tapping F8 key on boot and select "safe mode" press enter then enter again. If it gets to windows in safe mode log on as an administrator and go to "display" in control panel, select adapter and change the driver by rolling back to a previous version or simply uninstall, which is what i did! Then restart the computer, it should now boot to windows but the resolution will be naff, get on the internet find the latest driver from your laptop manufacturer download this to the desktop and install from there. Worked for me, hope it does the same for you.
Jul 05, 2009 | HP Compaq for Presario V3000 Motherboard
Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
Jun 23, 2009 | ASUS Eee PC 901 XP Notebook
Won't power up
I can't help you with the first problem, but as far as the wireless card, if you reinstalled Windows, you have to reinstall the wireless card driver.
Sep 10, 2008 | HP Pavilion dv9000z Notebook
Starting up
press the power button for some seconds
Jan 29, 2008 | Computers & Internet
Dell Inspiron 1501 Notebook Logo
29 people viewed this question
Alun Cox
