Titan TI-7700 Massage Chair Logo
A
Anonymous Posted on Feb 07, 2013
MY TI-7700 NAMES 5 PROGRAMS: COMFORT, STRETCH, HEALTHCARE, RELAX, AND FULL AIR. PLEASE TELL ME THE FEATURES AND FUNCTIONS EACH OF THE 5 PROGRAMS PROVIDES
WHAT FUNCTIONS ARE GROUPED INTO "COMFORT" ? WHAT FUNCTIONS ARE GROUPED INTO "STRETCH" ? WHAT FUNCTIONS ARE GROUPED INTO "HEALTHCARE ? WHAT FUNCTIONS ARE GROUPED INTO "RELAX" ? WHAT FUNCTIONS ARE GROUPED INTO "FULL AIR" ?
Why my CPU is so slow in any progress, My Desktop Sets are: Motherboard- GIGABYTE GA-B75M-D3H. RAM- DDR3 HyperX Blu 8GB. Graphic Card ASUS GT710-2GB. Please Help, what should I do to IMPROVE. PLEASE
NO OS stated, just mobo. (and GPU card) windows what?
all PCs are slower than better PCs,
no CPU stated,
what are you doing, when its slow?
are you playing games, tell what you do when it slow.
I have Asus z270 with i5-7700 and it screams, with M.2 fast. SM961.
no idea what you have there, or are attempting.
computers can do 1000000000000 things, name one please.
is the CPU overheating, 90c it halts just before that all CPU slow down to save themselves from damage.
the heat sink must match the wattage of your CPU,
the fan on top must run and blow, or the CPU will overeheat.
your mobo only can run 3rd generation intel CPUs, like i5-3xxx
2012 processor it is.
you didnt put a slow crippled Celeron in it did you?
Core i7-3770 (this CPU tops out here) full features. and speed.
tell more get more, what OS, and what runs slow , name something please, and tell what heatsink fan you used.
the top processor needs at least 77watt fan/HS or it will overheat.
I borrowed a portable a/c unit Comfort -Aire model number PD121-5 cant get it 2 stay on cool it has timer & changes temp all the time. can anyone tell me how to reset this thing? No remote
some ac units portable or other wise use a program where it starts on full cool and as the humidity is removed from the room the program changes to less cool or switches off for periods ( called comfort mode on some units and is used for sleeping where the room temp is maintained and does't get colder as the night goes on)
try and down load a operators manual from the net
How to fix an invalid dim error on an ti 83 calculator
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't fix it, please reply to this post and tell us what you're trying to do when you get this error.
Invalid dim
If you're trying something else when you get this error, please tell us exactly what you are trying.
Invalid dim
If this doesn't fix it then please tell us exactly what you're trying to do.
How do I fix invalid dimensions
If you're not trying to graph a function, please tell us exactly what you are trying to do when you get this error.
I would like to do some stretching to help counter my back pain. Any tips how to get started?
A program of stretching won't produce immediate results but can make a bit difference in the long term and help protect your back from further injuries. Make sure that you wear comfortable clothing and don't force your body into any position that actually hurts.
Hold the stretches for long enough (20-30 seconds) to be effective and then repeat the stretch 5-10 times.
Good luck
1helpful
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
2helpful
I am attempting to program the atomic masses of the elements into my Ti-86 using the Store feature and Capital and lowercase letters, (ie. 54.938>Mn) and I got all the way to Lu, when it gave me an...
There is a built-in function called LU (for LU-decomposition of a matrix). You cannot have a variable with the same name as a function, regardless of case. You'll have to find a different name to use.
5helpful
2answers
How do you plot two liner equations on a ti-84?
I use one of the graphing APPS or do through a program. I have a users manual for TI 84 silver Edition that shows you how to archive\ unarchive to run programs here at this site. Usually, I tell people to just forget about the programs and use the simple concepts so, that they could operate their calculator better. But, if you notice in those program are actually more powerful than the programs you get on the web, because I wrote them to be flawless, or I only used programs that I knew would not clash and were very well written. Won't y1=(2/5)x-(11/5) and -3x+8 work?
Top Titan Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Titan Furniture Expert? Answer questions, earn points and help others
