Question about Acer Aspire 5040-3947 Notebook
I have a acer 5040 the monitor will not display on the start up
    Sergeant:
    Champion:
  • 289 Answers
Hi..make sure that u have turned on the
display button.once u have turned off the
display button ur monitor will not show
u the display.This display button is available
on the top next to the power button.
check it out.
thank u..
rate me..
Posted on Feb 05, 2009
    Sergeant:
    Champion:
  • 271 Answers
Check the wiring.
Hello, I still have a laptop "Acer Travelmate
no reason why it shouldn't
run this adviser there is also one for window 8 if you look for it
http://windows.microsoft.com/en-GB/windows/downloads/upgrade-advisor
Aug 08, 2013 | Acer TravelMate Computers & Internet
Hi.I have a problem with my acer aspire 5040-3810 bluetooth.I installed the driver from the site and when I turn on the bluetooth button from the front it says "No device"....What it`s the...
There may not be a problem. 'No Device' usually just means that nothing has been paired with your laptop. Open up your Bluetooth settings and click 'Add Device' or 'Setup Device' or whatever, and follow the instructions.
Mar 26, 2011 | Acer Aspire 5040-3947 Notebook
I have a Acer Apsire 5040 and my wireless is working. It say Wireless network interface disable and I am using Atheros AR5005G Wireless Network and I run some troubleshooting and it says that my radio...
First of all,check if the wireless network system properties for Acer Aspire 5030 series laptop are set correctly.Generally speaking,it won't be a hareware problem related to the Wireless device of your laptops,it maybe also the tansfer device for the signals.
Feb 10, 2011 | Acer Aspire 5040-3810 Notebook
Sound device not working
Acer Aspire 5040-3947 PC Notebook(Sound/Audio driver)
Please first uninstall the sound driver in your Notebook and then install this one by just clinking on this Link: http://support.acer-euro.com/drivers/notebook/as_5040.html for windows XP.
Just click under Drivers and Utilities either XP or Vista.
The file is zipped but you can unzip it before installing/Running it onto your Laptop.
Good Luck and Rgds
Dec 15, 2010 | Acer Aspire 5040-3947 Notebook
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Need to remove the cd/dvd drive in my acer aspire 5040. can anyone help with a link to a service manual or video etc...
Normally there is one screw (at the back of the cd drive) that has to be removed either from the bottom of the laptop or in some cases it is under the keyboard.
Then open the cd drive using a paper clip and pull the drive all the way out. Grab the side rails and gently wiggle back and forth while pulling on the drive.
Hope this helps
Apr 25, 2009 | Acer Aspire 5040-3810 Notebook
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 07, 2009 | Acer Aspire 5040 Notebook
ACER X193 MONITOR DISPLAY ISSUE
Windows doesn't know your display is broken as it see's your display adapter for the laptop. By adding the monitor windows is adding a second display to the one you don't actually have, your icons and start bar are still on display 1
sorry
Sep 28, 2008 | Computers & Internet
Acer Aspire 5040
You did not excersize your cells so they died. When you get a new battery remember to either leave it plugged in for only an hour or two to charge and then unplug it. You fried your brain cells dude!
Jul 05, 2008 | Computers & Internet
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer Aspire 5040-3947 Notebook Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
