Question about Toshiba 56HM195 56" Projection HDTV
Picture distorted husband says it looks overexposed I say it has faint green and pink horizontal spaces/lines across the whole picture. When there is a close up of a face or a light background there is a pink & green iridescent effect. At Toshibas suggestion I replaced the lamp with no improvement
  • dukatnik Feb 05, 2009
    I didn't realize a TV had a motherboard. I called TV repair they said it cost $200 to look at it and it's possibly a light engine at $2000 or a module..also expensive. He suggested a new TV--not a DLP. This TV is only 3 years old and at a cost of $2600 I won't put a $2000 part in it.
    Sergeant:
    Champion:
  • 271 Answers
This a problem with the motherboard. not the lamp.
Posted on Feb 05, 2009
  • Roshan Vithanage
    Roshan Vithanage Feb 05, 2009
    motherboard is the main circuit board, and the charge your repairmen. &200 just to repair this?.he's trying to cheat on you.
I have sound but have a black screen with a horizontal line across it
your picture tube may be malfunctioning -- all of the information for the screen is being squished into that horizontal line. If this is the case, you can buy a new picture tube and install it, but that would be the only fix. the only other thing I can think of that might cause this issue would be if you have a large speaker next to your TX. The magnet from a large speaker can distort the television, but it usually gives you a funny green distortion near the magnet without killing your whole screen so it seems unlikely that this is your problem.
May 26, 2011 | Memorex MT2271 27" TV
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
Stripes printed on every picture
go through your printers software in your start menu and clean the heads.
Aug 21, 2009 | Canon PIXMA MX850 multifunction InkJet...
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Sep 24, 2007 | Toshiba 57H83 57" Rear Projection HDTV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Toshiba 56HM195 56" Projection HDTV Logo
300 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
