Question about Sharp EL-501WBBL Calculator
Decimal position How do I reset the decimal position back to 2 places instead of 8 places?
  • Sharp Master
  • 7,993 Answers
Here is a screen capture to help you.
Posted on Jan 30, 2010
FX 82 es scientific calculator. How I get decimal expansion of numbers?
Meaning what, exactly?
If you want a decimal representation of an exact number, press the SD key to switch from exact to approximate (decimal). If you want to expand a decimal number in powers of 10, separate all the digits, multiply every digit by a power of 10 with exponent equal to its position as counted from the decimal mark -1. To the left of the decimal mark, the exponent is positive. To the right of the decimal mark, the exponent is negative. Sum everything
Example
345.678 =3*10^(3-1)+4*10^(2-1)+5*10^(1-1)+6*10(-1)+7*10^(-2)+8*10^(-3)
Jul 21, 2015 | Casio Office Equipment & Supplies
Decimal answers
There are no decimal digits in this number. You can put a decimal mark in 8 537 000. and append two zeros, or more. But I would not call that rounding 8 537 000.00
Feb 20, 2014 | Office Equipment & Supplies
Define algebra:decimal
Decimal is the base-10 notational system for representing real numbers. The expression of a number using the decimal system is called its decimal expansion, examples of which include 1, 13, 2028, 12.1, and 3.14159.
Each of the arabic numerals 0 to 9 is called a decimal digit, and the period placed to the right of the units place in a decimal number is called the decimal point (or, in the case that a comma is instead used for this purpose, the decimal comma).
The decimal is a way of managing numbers that has ten as a starting point, or base. It is sometimes called the base ten or denary numeral system. The word "decimal" is also used instead of the word "period" to point out the dot that is sometimes used separates the positions of the numbers in this system. Almost everyone uses this nowadays and prefers the convenience of it probably because it shows up most often in calculations in nature and has "one" as another starting point for the system. The number one is usually the easiest to work with in calculations.
You may go to the link below for decimal tutorial:
http://www.algebra1help.com/flash/noflash/3.html
Jun 16, 2011 | Computers & Internet
What is the default setting for the f cut 5/4 and the 4320 add 2 I don't know what to have these options set at thanks EW Seattle
The selector you are asking about is the "decimal selector". The result displayed/printed, will be in a format according to the position that you have selected as follows:
f = floating (the result will be in the number of decimal places that were entered on the keyboard
4= fixed 4 decimal places (x.0000)
3= fixed 3 decimal places (x.000)
2= fixed 2 decimal places (x.00)
0= fixed 0 decimal places (x)
add 2= (add mode*,fixed 2 places) ($.00)
Note* "ad mode" automatically enters the decimal place when entering the number on the keyboard. If you enter "123", the displayed ammount will be "1.23". If you enter "1", the display will read ".01". This is a useful setting when adding a list of numbers in a dollars/cents format, however, be careful, if entering a whole dollar ammount "three dollars" be sure to enter the decimal point, or enter the number as "300". If you don't, the result will be ".03", instead of the 3 dollars you intended.
May 20, 2011 | Royal 29307U Calculator
Change decimal placement on calculator
pressing the tab button displays the number of decimal places 0, 2, 3, 4, A, F on the bottom of the screen.
Jun 22, 2010 | Office Equipment & Supplies
When I divide the answer is in fraction form not decimal form how do i get it back
There are two options.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers.
For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
Nov 12, 2009 | Texas Instruments TI-89 Calculator
I lost my decimal point
You need to be in add mode, and have 2 decimal places selected for the result.
To change to add mode, make sure the 'K . A' switch is in the 'A' position. To get 2 decimal places in the answer, move the selector in the 'F 6 3 2 1 0' switch to the '2' position.
You can see the above described at
this Sharp.com page which shows the users manual. The manual shows examples.
Mar 19, 2008 | Sharp EL-1197P Calculator
My calculator has a funny format
Try pushing and releasing [f], then [4]. This will give you 4 decimal places. (It follows that if you want 5 decimal places, push 5 instead of 4, etc). If that doesn't work, you can try taking the batteries out and putting them back in which should reset it to 2 decimal places, then set it where you want it following the above.
If it continues to malfunction I suggest taking the batteries out for 24 hours to allow a static discharge. This will lose anything you stored in the calculator, setting it back to how it came from the factory.
Nov 29, 2007 | HP 12c Calculator
Sharp EL-501WBBL Calculator Logo
173 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
