Question about Whirlpool GR460 Electric Kitchen Range
Whirlpool oven door won't unlock after cleaning
I tried to cancel and got E1 F5 error code hit cancel again and then any dey for i minute and got F2 E0 error. Tried to start clean again and got F4 E441 then 0309. The oven will go on but the door will not unlock. The clock and stovetop both work. How do I get the door open? Any idea what all those codes mean? Thanks
  • njbriggs May 15, 2009
    exactly the same issue
  • psbunch Jan 08, 2010
    Hi
    We have the same problem, what did you do to get it fixed?
The motor that controls the door lock was bad. Go online and order a new motor based on range model number. User can fix if reasonably handy with tools.
Posted on Jan 08, 2010
E1 f5
What is the model number?
  • Disconnect power from unit.
  • Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors.
  • Replace door switch.
  • Re-apply power.
  • Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
  • Nov 29, 2012 | Kitchen Ranges
    Tip
    Troubleshooting KitchenAid oven, range and microwave error codes
    Here list of Kitchen Aid range and oven codes.
    4 Digit Failure Codes
    F1 - E0 EEPROM communication error
    F1 - E1 EEPROM checksum error
    F1 - E2 UL A/D error
    F1 - E4 Model ID error
    F1 - E5 Calibration shifted
    F1 - E6 Latch signal mismatch error
    F1 - E9 Stack overflow
    F1 - E3 Wiring harness cavity size does not match stored value
    F2 - E0 Shorted touch pad
    F2 - E1 Keypad cable connection error
    F2 - E5 Cancel key drive line open
    F2 - E6 Cancel key drive line open
    F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
    F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
    F3 - E2 Oven temperature is too high (Cook mode)
    F3 - E3 Oven temperature is too high (Clean mode)
    F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
    F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
    F3 - E6 Drawer sensor open
    F3 - E7 Warming drawer sensor shorted
    F4 - E1 Meat probe malfunction - shorted
    F5 - E0 Door Switch
    F5 - E1 Self clean latch will not lock
    F5 - E2 Latch during CLEAN error
    F5 - E5 Self clean temperature not reached within 45 minutes.
    F5 - E6 Door is open, but latch is locked
    F5 - E7 Self clean latch will not unlock
    F6 - E0 Return line not connected
    F7 - E1 Common switch wire defective
    Two digit codes:
    F0 ERC Board failure
    F1 ERC Board failure
    F2 Oven temperature is too high
    F3 Oven temperature sensor open
    F4 Oven temperature sensor shorted
    F5 ERC Board failure
    F7 Function key stuck on ERC
    F8 ERC Board failure
    F9 Oven door lock failure
    Microwave and Microwave combo error codes:
    F1 - E3 or F1 - E4 Electronic control malfunction
    F2 - E0 or F2 - E1 Keypad connection error
    F2 - E3 Keypad held down too long, or keypad is shorted.
    If you get an error code, try first resetting the code:
    1. Disconnect power for about two minutes.
    2. Connect back power.
    3. If code re-appears, test and eventually replace faulty part.
    on Apr 24, 2015 | Kitchen Ranges
    I have a electric whirlpool self cleaning oven, after the cleaning process the door is still locked. It's beeping and error message E1 F5
    Assuming the door is still locked after cooling, then either the door switch is bad or the wiring from the control panel to the door switch has a problem. First disconnect the power from the oven. Then check the wiring and connectors (from the control to the switch and back). If those are fine, you need to replace the door switch. After replacing the switch or fixing any bad wiring/connections, reconnect the oven to power. Press and hold any key on the panel for at least one minute to clear the error. You should see F2 on the LCD panel. Press Cancel to clear the error then check to see if any new error (or the old one) message occurs. (Usually a new error message will come up within a minute.)
    Which model Whirlpool oven do you have? If you add a comment with the model number, I may be able to provide a parts list and diagram of the unit.
    I hope this helps.
    Nov 22, 2011 | Whirlpool Kitchen Ranges
    Why won't the oven door lock to start the self cleaning? The door appears to be shut all the way. After hit start, this code appears E1 F5
    According to the Whirlpool website, the self-cleaning latch may be interfering with the door, though this would be indicated by an "E0 F5" error code. If that's the case, Whirlpool recommends the following:
    1) Press "Stop/Clear" to clear your display.
    2) According to Whirlpool, there should be a door switch plunger in the upper right corner of the oven front. Press and hold this so that the door latch will unlock.
    However, if it is indeed "E1 F5" (or any other number with those letters in the code), Whirlpool recommends calling an appliance technician.
    http://whirlpool.custhelp.com/app/answers/detail/a_id/319/kw/error%20code
    Feb 28, 2011 | Whirlpool Kitchen Ranges
    Trying to self clean oven, error code F5 E1 alarm set off in the first few minutes of the cleaning cycle
    F5
    lock
    1.
    If door latched:
    1. Disconnect power from unit.
    2. Check wires and connectors from control to door switch, then from door
      switch to control. If no damage to wires and all connectors okay, proceed to
      step C.
    3. Replace door switch.
    4. Re-apply power.
    5. Press and hold any key down for 1 minute to clear F5 failure code from
    2. If door not latched:
    2. Check wires and connectors from control to latch switch, then from latch
      step C.
    3. Repeat steps A and B for door switch.
    3. Measure door switch (door open = switch open small low voltage terminals).
    Replace switch if defective.
    4. Measure latch switch (unlatch = switch open,
    CAUTION - oven light contacts are closed). Replace switch if defective.
    5. If
    corrections are made in any step, reconnect power to control. Press and hold any
    key for 1 minute to clear R failure code from memory. F2 will appear. Press
    6. If failure
    remains, disconnect power and replace control.
    Note:
    Applies to all F5-E... codes.
    Dec 31, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
    When trying to use self cleaning on the oven we are getting an E1 F5 code....
    F5 - E1 Self clean latch will not lock 1. If door latched:
    2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
    4. Re-apply power.
    5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
    2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
    3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
    4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
    5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
    6. If failure remains, disconnect power and replace control.
    Sep 18, 2010 | Whirlpool Kitchen Ranges
    Self cleaning F5 error
    The E1- F5 error is a door lock error.
    The control (TIMER) has likely failed in this instance - BUT...
    Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
    You should disconnect power again for 15 seconds and reconnect and see if that helps.
    If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
    Sometimes these work, but if the control has failed it won't make any difference.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$TRE
    Feb 23, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
    F5E1 error
    Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
    >>Exception Note:<<
    Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
    F0-E0 Analog to Digital failure
    Disconnect panel for 30 seconds
    Should the above error re-appear, replacement of the control is required.
    F1-E1 Defective ERC Replace ERC
    F2-E0 Shorted Keypad Replace Keypad
    F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
    F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
    F3-E2 Oven over heat Replace Sensor
    F3-E3 Cleaning Temp over heat Replace Sensor
    F5-E0 Door Error Check Door
    F5-E1 Door Latch Check Latch
    F5-E2 Door Switch Check Switch
    May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
    Whilrpool Self Cleaning Range Door won't unlock
    try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
    Momentarily (less than 5 sec.) press CANCEL key again to remove error code
    display.
    2. Press and hold any key for 1 minute until F2 E0 code is displayed.
    3. Cancel F2 E0 error code.
    4. Program and start the clean mode. Observe to see if door locks. If it does not,
    inspect the locking mechanism from the solenoid to the latch pawl and door to
    find the cause of the problem. If the door is not locking, then 1 minute from the
    start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
    have to be repeated before another clean can be started.
    5. Once any mechanical problems with the latch mechanism have been corrected,
    program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
    to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
    Feb 10, 2008 | Kitchen Ranges
    Whirlpool RF196LX Smooth Top Range
    4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
    Oct 21, 2007 | Kitchen Ranges
    Whirlpool GR460 Electric Kitchen Range Logo
    1,185 people viewed this question
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
