Question about ScanSoft Dragon NaturallySpeaking 8 Medical (A709AF0080) for PC
Probleme of compatibility
I have a Dragon Natural Speaking 8 , but i connot install it in my new computer , it is not compatible with Window Vista
    Problem Solver:
  • 11 Answers
You must have Dragon v9.5 and higher for Vista compatibility. You will need Dragon v10.1 and higer for Windows 7 compatibility.
Posted on Mar 19, 2010
  • 2,976 Answers
What compatability is listed on the box? If it doesn't have Vista listed, you'll probably have to swap it.
Posted on Feb 05, 2009
  • David Shaub Feb 13, 2009
    Rather than answer the question, you questioned my question. I was obviously right. ''
    Thank You
Hi Leonard May 11, 2014 Joel RodriguezAdd a CommentAfter doing some research on this dll error I found that it associated with a ActiveX conflict with corrupt or missing system files. May 11, 2014 Joel RodriguezThings that you can try: put your windows disk and run the system file checker in command prompt (here is a youtube link on how to run it ) fast forward video to 4:40 and follow. This will check the integrity of your systems files . Second you will do if that didnt work you would re-install the Dragon Naturally speaking software and drivers of any device that you are using with the dragon software. here is the hardware compatibility list from thier website . If still a no go . May 11, 2014 Joel Rodriguezinstall the dragon software to another computer if you dont get that error then its your windows then. Doing a clean reinstall of windows and updating new updates. then you will install dragon software.
May 11, 2014
May 07, 2014 | Computers & Internet
Have new computer gateway with windows vista says windows connot find driveon the disk the printer is lexmark x1185
vista , till now does not have all the drivers for all the additional accessories....
for only a few devices and models in printers or cameras are available
Apr 11, 2008 | Office Equipment & Supplies
Can Dragon 10 be installed on Windows 7, 64 Bit?
Apparently you need update 10.1 to work on a 64 bit system. Check this out:
Feb 03, 2013 | NRS Nuance Dragon Naturally Speaking 10...
I want driver of shro am-400 for win vista plz do needfull
Well sorrsy to say but there is no win vista driver's for this model, anyway there is a way to use windows xp drivers in windows vista, follow the below steps -
1. Click the "Start" menu in the lower left-hand corner of the Windows Vista screen.
2. Select "Run" from the Start menu.
3. Type "msconfic" in the Run box. Click "OK." A window will appear that lists all of the programs scheduled to run when Windows Vista is turned on. Uncheck all unessential software programs. Be sure to leave critical programs checked, such as antivirus and firewall programs. Click "OK."
4. Click the "Start" menu and select "Restart" to reboot the computer.
5. Open "My Computer" (located in the Start menu or on the Vista desktop).
6. Double-click the "C:\\" drive. Find the installation directory for the Windows XP program or device that you wish to run in Windows Vista. The installation directory is usually given the name of the program, the program's manufacturer, or a shortened version of either of these two options.
7. Right-click the program or driver. Select the "Properties" option in the pop-up menu that appears.
8. Click the "Compatibility" tab in the window that appears. Check the box next to the heading that reads, "Run this program in compatibility mode." In the drop-down menu, select "Windows XP." Click "OK" to close the window. The program or driver will now operate in Windows Vista in Windows XP compatibility mode, allowing the driver to function as it did in Windows XP. Note that the Windows XP driver will not be able to take advantage of any of the new features in Windows Vista while it is running in compatibility mode. You can also follow the below link for more help -
Good Luck!!
Jun 08, 2010 | Sharp AM-400 Digital Multifunction Printer
Voice recognition using Sony ICD-P320 and Naturally Speaking
I would run compatibility check. It sounds like not compatible with Vista.
May 16, 2010 | Sony ICDP620 Digital Voice Recorder
I am trying to install creatacard 8 on windows xp home. it freezes at 8% installing fonts. i have installed this before on my computer and this time it does not work.
I have the same problem when trying to install on Vista (Home version), except it freezes at 4% intalling fonts. Have tried to adjust setup.exe properties to compatible options, still doesn't work. Also used Windows Vista compatability wizard with no luck.
Aug 22, 2009 | Broderbund American Greetings Creatacard...
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
I have windows and Naturally Speaking installed on my Computer. I have installed Vista ! it is not permiting the change at thi time.
It might be that the software is not compatible with vista,try compatibility mode to fix the issue.
Jul 21, 2008 | Computers & Internet
Nero 7 Uninstall
Get clean tools here, it will take it out for you:
Let me know how you make out
Dec 28, 2007 | Microsoft Windows Vista Ultimate Edition
ScanSoft Dragon NaturallySpeaking 8 Medical (A709AF0080) for PC Logo
215 people viewed this question
Top ScanSoft Computers & Internet Experts
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
