Question about PreSonus FIREPOD (673454000539) Audio Input
Firepod control panel reads 'no device'
I have my Firepod connected to my computer with a firewire cable, yet the control panel of the Firepod still shows there is no device. I use it with Reaper recording software and have had no problems until I just disconnected everything to move it to a different location. Now I am getting this error message when I open Reaper to work on projects.
Any ideas?
  • Anonymous Mar 02, 2009
    The computer will not recognize the firepod at all. It was working before just fine, but it was on a different machine with Windows Vista. Now the computer won't recognize ANYTHING at all. Tried it on several different computers running XP.
    I updated the firmware of the firepod with v2.46 (I think), and from what I could tell it was supposed to work with both Vista and XP.
2 Suggested Answers
KiledeMuerte
  • 70 Answers
SOURCE: My Firepod connection seems to be broken. I
No. I would pay the $80 to get it serviced.
Posted on Jan 10, 2011
Loud hum / all tracks crosstalk each other
If the noise does not depends on cables and connections, or interference from devices, then It looks like there is some blown component inside.
Sep 29, 2008 | PreSonus FIREPOD (673454000539) Audio...
Tip
Problems with your USB port? How to solve it
If you have problem with your USB device or if you try to connect your USB to your laptop or desktop computer here is the solution, just read carefuly and follow my rules down here:
First of all turn on your computer and plug in the USB and keep following these instructions by numbers:
1. Go where START and open control panel.
2. In control panel look where say "device manager" (if you don't see device manager option don't worry, then look for computer decive and then look for device manager or device hardware)
3. Click on device manager
4. click on universal serial bus or USB devices
have a good luck!!
on Sep 14, 2010 | Computers & Internet
Can't conect through my firewire
try connecting the camera to the computer through your firewire then go to if you have windows xp click start then click on control panel, then click on printers and other hardware, then click on scanners and cameras, then below the back icon will be add an imaging device and with the camera hooked up to the computer through the fire wire and the camera turned on click the add an imaging device. then follow the prompts in the installation wizard. if this dont get your camera back on line then you will need to find the drivers and program for the camera. you might find it at the panasonic web site just check for down loads for the camera.
Dec 12, 2007 | Panasonic PV-GS39 Mini DV Digital...
I am using a presonus firepod into Logic pro 8 and it wont recognize the audio I am trying to record into it. I recognizes the Firepod which is chosen for input and output (output works fine). However when...
Have you been able to successfully do this in the past? What software are you using to try to record with? Does it seem to recognize the guitar in the software, just will not react, or does it not appear to see it at all?
Thanks, let me know and I can help!
Tim
Sep 16, 2010 | PreSonus FIREPOD (673454000539) Audio...
Ipod touch 32G 3rd gen is not recognised by windows when i plug it in windows gives message, USB Device Not Recognized
Its a little lengthy but worth the read:
First, make sure your iPod is fully charged and then toggle the Hold switch on and off.
Reset, Retry, Restart, Reinstall, Restore
Go through the 5 R's of iPod troubleshooting, which will often solve your issue. If you're still experiencing the issue after going through each of the steps, then continue for more suggestions.
To determine if your iPod syncs via USB or FireWire, check the table in the Additional Information section below.
Tip: If you are using Windows XP and have recently installed a Service Pack, check the Device Manager. Click the Start menu and click Run. Type “devmgmt.msc” and click OK. If no devices appear in the Windows Device Manager, go here.
Still can't see your iPod?
Several things could keep iPod from appearing in iTunes or Windows Explorer. The most likely causes are listed below—you'll find information for both USB and FireWire (IEEE 1394) iPod connections. Check each one starting from the top of the list to see if that is what's keeping iPod from appearing.
Make sure your computer meets the iPod system requirements
Make sure that your computer meets the system requirements to use iPod with Windows.
If your iPod displays an exclamation point folder or sad iPod icon
If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue.
Charge the iPod and make sure it is getting power
Your iPod must have enough of a charge for your computer to recognize it. Connect your iPod to its power adapter or to a high-power port on your computer to charge your iPod if the battery is depleted. If your iPod is connected through FireWire but isn't getting power from the FireWire bus, your computer may not recognize it.
Secure the iPod's connections
Make sure that there is nothing physically inside or blocking your computer's USB (or FireWire) port, and that the cable connections to your iPod and computer are secure.
Note: If you're using an iPod shuffle (Second Generation), make sure the iPod is inserted securely in the iPod shuffle Dock.
Restart your computer
Sometimes simply restarting your computer can resolve issues.
Connect iPod to a high-powered USB port
If you're connecting an iPod, iPod mini, or iPod shuffle to your Windows computer, make sure that you're connecting it to a high-power USB 2.0 port on your computer.
If you're connecting the iPod to a Windows laptop computer through USB, connect the laptop to a power outlet before connecting your iPod. Also, see iPod not recognized when connected to Windows laptop over USB to be sure that your USB ports are supplying enough power.
Typically, USB 2.0 high-power ports are located directly on your computer. Try connecting your iPod to another USB port on the computer.
Avoid connecting the iPod to a USB hub. Connect the iPod directly to a USB 2.0 port on the computer. If a hub must be used, make sure the hub is USB 2.0, and that it has its own power supply. Also, make sure the hub is connected to a high-power USB 2.0 port on your computer.
If the issue persists, try disconnecting other USB devices from the computer such as printers, cameras, scanners, external hard drives, and USB hubs to determine if there is a conflict in the USB chain.
Check whether your iPod's cable functions properly
Make sure that you are using the cable that came with your iPod. Some third-party cables may not work properly with iPod.
Make sure that nothing is in or blocking your computer's USB or FireWire port.
Check the connections to make sure that the cable is completely plugged in.
Try another known-good FireWire or USB through Dock Connector cable if available.
If swapping out your old cable for another resolves the issue, then your original cable should be replaced.
Place the iPod into Disk Mode
Try placing the iPod into disk mode to see if it is recognized by iTunes, or My Computer.
Check which format iPod is in
iTunes for Windows only recognizes Windows-formatted iPods. You cannot use a Macintosh-formatted iPod with a Windows PC. To learn for which platform your iPod is formatted, follow these instructions.
Check whether your computer's port functions properly
If another FireWire or USB port is available on your computer, try connecting your iPod to it.
If your computer recognizes your iPod after trying a different port, the original port could be faulty.
Note: iPod will not automatically wake up if you connect it to a 4-pin FireWire port. You must press the Select button (the wheel's center button) on the iPod to wake it from sleep.
Check if Windows confuses iPod with network drive
If the drive letter after iPod ("E" in most cases) is mapped to a network drive, both Windows Explorer and iTunes may exhibit strange behavior in relation to the iPod (including preventing iPod from appearing. See "Windows confuses iPod with network drive and may keep iPod from mounting or songs may seem to disappear" for more information.
Your USB or FireWire card isn't recognized by Windows
Make sure that Windows recognizes your USB or FireWire card. Follow these steps to find out if Windows sees your card.
Third-party software may be causing conflicts
Some third-party software (such as security software) may prevent your computer from recognizing your iPod.
Try adjusting the settings of such software, or temporarily disabling it, to see if that resolves the issue.
Also, try booting Windows to Selective Startup mode to disable any third-party startup programs and services, and isolate which software may be causing the issue.
Install or reinstall iTunes
Download and install the latest version of iTunes.
In some cases, you may need to completely uninstall and reinstall iTunes.
Make sure FireWire card is a WHQL-certified IEEE 1394 card
Only certain iPod models sync via FireWire. Refer to the table in the Additional Information section to make sure your iPod can sync via FireWire.
If you have a FireWire (IEEE 1394) card installed in your computer and are using it to connect your iPod, make sure that the card is Windows Hardware Quality Labs (WHQL) certified. If it isn't, your iPod may not be recognized, or you may not be able to send music to the iPod.
If you're not sure about your card's WHQL certification, check the inbox material that came with your FireWire card or contact the card's manufacturer. You can view a list of WHQL-certified cards on the Windows Hardware Compatibility List website. To view this:
Go to the Windows Hardware Compatibility List website.
Click on the link that corresponds with your Windows Operating System to view the compatibility list.
Select your Operating System build, and then from the Product Categories pop-up menu, choose 1394 Controller.
Click the Search Now button.
You can also check the list of recommended FireWire and USB cards that have been tested by Apple with iPod and Windows XP (Apple sells FireWire cards that are compatible with iPod at the Apple Store.).
To rule out an issue with your FireWire card, try connecting a different FireWire device to the card to see if your computer recognizes it.
Check for a conflict in the FireWire chain
Your computer may not recognize your iPod if there's a device conflict in the FireWire chain. To see if this is the case:
Disconnect all devices from your computer's FireWire ports.
Connect your iPod to your computer's FireWire port.
If your computer recognizes your iPod, you should troubleshoot for FireWire device conflicts.
There may be an issue with your computer
If another computer is available, verify that the same issues happen with the other computer. If the other computer recognizes your iPod, you may want to troubleshoot for issues with your original computer.
Your iPod needs service
If after following these steps your computer still doesn't recognize iPod, see the iPod Service website to arrange for service.
Please Rate Me
May 22, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
How do i get my FA-66 to work via firewire?? please help!!!!!!!
u're probably trying to connect it with a 4 to 6 pins firewire cable to your laptop right?
if so, the laptop firewire connection is usually the small type (4 pins). this kind
of connection does not give Power to the firewire device.
u can buy a pcmcia card with 6pin firewire connections and usa a 6 to 6 firewire cable
and that will work. i hope. :)
Oct 06, 2008 | Edirol FA-66 Sound Card
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
May 05, 2008 | Audio Players & Recorders
M-Audio FireWire 410 External Distorted Playback...
Hello have you disabled all the built on sound cards on your computers? This is a known problem. If you are going to use a great product like M-audio disable any onboard audio card. Then try to use the 410 system. If you still have the problem try changing the latency to 4-5
Dec 27, 2007 | M-Audio FireWire 410 External Sound System
Not syncing
Could be a bad cable, bad firewire card in computer, or the unit is damaged.  Might want to connect the unit to someone else's computer with a new Firewire cable.  If this doesn't work, chances are that the unit is defective.  I have the same problem right now and I'm having to send the unit back to Presonus.  They charge $85 for parts labor and the return shipping.  The replace the entire board, so it's like getting a new unit.  Hope that helps.
Jackie
Oct 17, 2006 | PreSonus FIREPOD (673454000539) Audio...
Open Questions:
See all PreSonus FIREPOD (673454000539) Audio Input Questions
PreSonus FIREPOD (673454000539) Audio Input Logo
948 people viewed this question
Top PreSonus Televison & Video Experts
Electro Med Services...
Are you a PreSonus Televison and Video Expert? Answer questions, earn points and help others
