Question about Sony Televison & Video
NO SOUND OR PIX
SONY KP-61V35 REAR PROJECTOR WHEN TURNED ON LIGHT FLASHES ONCE AND SHUTS BACK OFF, THEN YOU HAVE TO HIT POWER TO SHUT DOWN BEFORE TRYING AGAIN AND SAME THING HAPPENS. SOMETIMES LIGHT MAY BLINK TWICE BEFORE SHUTTING DOWN.
  • thielectronick
    thielectronick May 11, 2010
    # of blinks = error code
    if it doesnt repeat the blinking.. suspect G board
  • 4,234 Answers
A single blink of the standby light is not used as an internal diagnostic count. If that is all you see, then there is likely a fairly major problem with the main power supply. Because of the lack of diagnositc information, this is not likely to be resolved remotely. These sets are decent sets and are worth additional diagnostic investigation. I would suggest you invest in a detailed repair estimate. Post the results here and we should be able to walk you through the actual repair.
Dan
Posted on Feb 05, 2009
Sony kp 51hw40 rear projector turn off problem .
T8005 etc is NOT the issue.
This set was prone to bad picture tubes (has 3) and can flash bright blue (most common) and set when this happens detects too much current being drawn and shuts down.
There is a fairly easy way to try to deal with this and return set operation to fairly normal.
Not technical and no parts are needed.
Let me know if you want to know with a comment here and I will explain.
Apr 17, 2012 | Sony KP-51HW40 51" Rear Projection...
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
I have a 2002 Sony KP-57WS500 that occasionly (randomly?) flashes red lines and then goes to a full screen red while giving an electrical "cracking" sound before shutting down. Once shut down,...
Seems like your RED CRT is shorting out or failing. Do you notice any other colors besides just red having problems? The blinking of the red light eight times is a High voltage error. It could be your D board but I'm thinking it is more likely the red crt is probably shorting out.
Mar 08, 2011 | Sony KP-57WS500 57" Rear Projection...
TV Turns Off On Its Own
Standby light flashing is error sign and shows tv got problem some where in its circuit boards.
You will notice 3 seconds long pause between red standby light flashing so count pause to pause and post how many times it flashing to diagnose problem of tv.
Thanks.
Jul 01, 2010 | Sony KP-65WS500 65" Rear Projection...
Sony rear projector TV problem, KP-61v35
This is a problem with the vertical circuit. This can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Let me know if you wish to attempt the repair and I will supply additional details and instructions.
Dan
Feb 26, 2009 | Sony KP-61V35 61 in. Rear Projection...
5 flashing light code,unplug CR board,now 8 flashing light code
If you put the "CR" board back on, the error code will once again be 5 blinks. Your problem is likely the TV's IK blanking circuit. The Kine driver ICs on the CRT sockets boards CR, CB, and CG need replacement along with a few components in the 200 volt supply to the circuit.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony tv blinks 30+ times or once, no picture/no sound, then shuts off
sounds like a problem in the stand by power supply as the Set is not blinking any code indicating its in protective shut down. I would assume its one of the low voltage regulators that has shorted. You would need a service manual to actually troubleshoot the start up and stanby voltages. Let me know if you would like a link where to purchase the manual. I will post a link that provide free tech assistance to help diagnose and repair your set when you get a manual.
Mar 27, 2008 | Televison & Video
Sony kp-61v35
Unless you can do tv repair your set has more wrong with it then something minor,it more then likely has a shorted Hori out put transistor NTE2973 and maybe open pico fuses.Take set to repair shop. ThankYou for using FixYa. Have a Nice Day.
Feb 08, 2008 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
