Monitor intermittently goes dark and will not come on
Having problems for about a week, monitor may jump or flash, once a white type light up the middle of the screen, then goes black. If i turn the pc off, unplug everything and wait 45 minutes or so, it may come back on. is the monitor going out? I've had about 3 years - do I need to update a driver or something? I have checked all the ''power source'' /connection problems and that's all ok.
  • Anonymous Mar 29, 2009
    I have the same problem, do you hear a whine? Anyway my guess is the backlight is dying.
    Sergeant:
    Champion:
  • 283 Answers
Check you monitor cable or replce it. tahnk you..
Posted on Feb 05, 2009
One of the two monitors will cease displaying screen image and begin rotating between a BLACK/WHITE/GRAY/Primary Color Bars every other second following a few minutes after start up. Have tried Restar
It might be the input from the graphics card. Try swapping the two monitors' feeds to see if the problem is with the monitor or the card. The monitor seems to be going into a screensaver mode since there's no signal. The flashing light could mean there's a power supply problem, or no signal.
Oct 15, 2017 | DoubleSight Displays Computers & Internet
My back light on my samsung impression went out so i cant see anything i need help fast
I am having a problem with my Samsung phone. When i go to voice mail and enter my code, the light goes out! The light flashes on and off...The answering service is asking you to put your code in but the phone goes dark! This is a new smart phone and i have only had the phone less that a week! outside of this problem, this a nice phone!
Sep 25, 2010 | Samsung SGH-A877 Impression Cell Phone
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Once the PC is booted up the monito screen goes dark
try another monitor to isolate if it is the monitor, if it is the LCD, the back light may be going out
Jul 07, 2009 | Computers & Internet
White flash/flicker on Powerbook G4 LCD monitor
There might be an internal device in your computer that is causing this, I have a 4 year old G4 myself, and a defect right hand side light sensor both caused purple stripes on the screen and made it go to sleep mode every time left hand side light sensor was covered.
You could run a hardware test on it: http://www.info.apple.com/support/aht.html
Maybe you could try to deactivate the light sensors in System Preferences?
These are more suggestions than a solution, but maybe you could start there. Good luck, I hope you get it solved!
Mar 23, 2009 | Apple PowerBook G4 Mac Notebook
Blinking Orange LED light on E151FP monitor
This monitor is know for a lot of parts that go bad, luckily they are usually the same ones.
If you are a technician or know one who can help you. Below is a list of part to repair/replace once the case is opened. (dont try this if your unfamilier with working on electronics.
1) F601= 2A Fuse
2) C605= 68uf 400v (must change)
3) R615= 0.68ohm 1watt
4) Q601= SSS6N60A
5) R613= 1Kohm 1/8watt (value changed to 2.3Kohm or higher)
6) R623= 4.7ohm 1/8watt (value changed to 7.2ohm or higher)
7) D604= 1N4148
8) IC601=UC3842B
9) C707 & C703= 1000uF 16V (must change, because of bad ESR value) secondary filter capacitor.
This problem of dell e151fp lcd monitor, you just need to resolder the inverter section (bad points or dry joint) and also check the capacitor value with ESR meter. It will solve your problems.
Sep 14, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Flashing
It could be a bad connection on the back with the cable try to tighten them up.
Jan 30, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Monitor goes Black off and on .....
I had the same problem for about a week and solved it yesterday by downloading the latest driver by NVDIA who makes my video card (NVDIA GeForce 6200).
I had previously updated the latest Sony driver for the monitor. It did not solve the problem but could be part of the solution in conjunction with the new video card driver.
Oct 31, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Open Questions:
Toshiba Support USA - Toshiba Online Customer Care Support USA Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
723 people viewed this question
David Payne
David Payne
