Question about Dell OptiPlex GX270 PC Desktop
Dell Desktop DX270 doesn't work with LG w2052TQ monitor...
I am trying to connect DX270 to an LG Flat monitor w2052TQ using a blue video connector. When I boost up the computer, the monitor does not even blink. Can anybody give me an advice?
  • Thuy Jinjin Feb 05, 2009
    Thank you for the quick reply! So helpful!
  • 54 Answers
Your resolution may be out of range. try plugging in a different monitor and then adjust the resolution.
Posted on Apr 09, 2009
  • 3,940 Answers
A Dell Optiplex GX270 can have either on on-board VGA integrated graphics controller or an expansion graphics controller. If an expansion card is installed, the onboard graphics is disabled.
So first, ensure that the VGA cable is connected to the correct graphics connection (If there is an expansion slot with a video connector, ten you must use that connection)
If connected to the correct port on the system, next ensure that the input select for the monitor is either set to autoselect or ANALOG
Last ensure that the display resolution of the graphics adapter will support the new monitor.
Posted on Feb 05, 2009
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Have a dell 8200 desktop with an LG tv monitor attached and when I try to boot keeps going to power save mode
You have the wrong cable from the pc to the monitor.Look in the back of monitor and you will see a cord with a blue connector and one with a white connector.
Try the one not in use.If that does not fix it your gpu does not support the monitor.
Aug 01, 2011 | Dell Dimension 8200 PC Desktop
How do I reset my flatron w2052tq monitor to factory settings? . I shipped my monitor to my new home and now I can't get my monitor and printer to agree on a color--I use a ColorMunki to calibrate,...
For the LG w2052tq, you can do a reset to factory settings through the OSD menu. Press Menu then go down to Setup. Press Auto/Set and go down to Factory Reset. Press Auto/Set and confirm the action. Then press Menu twice if needed to exist the menus.
Alternatively, press the Up and Down arrows together.
Remember that you can only adjust the white balance of the monitor when the incoming signal is Analog. Documentation for the monitor is available here: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=W2052TQ-TF&matchedModelCode=1000004018&searchEngineModelCode=W2052TQ&initialTab=documents&targetPage=support-product-profile .
I hope this helps.
Jun 24, 2011 | Computers & Internet
As soon as i switch my dell laptop on the page jumps like mad
it's very likely the vga adapter is simply loose! (connects PC to Monitor, the connectors are usually blue, white, or black-blue is most common) so make sure it's secured and screwed in tightly.
If that doesn't work, try adjusting the settings on your monitor (Menu> ....Default Settings)
Hope that helps!
Please remember to rate me! Thank You.
Apr 14, 2011 | Dell Dimension 3000 PC Desktop
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
When I turn boot up my gt5220 the monitor briefly flashes and then goes into power saving mode- desktop stays on, fans running and all, until turned off by holding power button down or unplugging it.... my...
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Dec 02, 2009 | Gateway GT5220 PC Desktop
When I hooked up the new Dell monitor my HP computer quit working.
What is the type of connector for the dell monitor? IS IT VGA or DVI. The HP computer is a notebook or desktop. Are you connecting to the onboard video or video card.Check if the monitor is passing self test feature. Then try connecting with HP computer. Good luck
Sep 17, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Dell monitor not working
just try running the Test on the monitor(monitor self test) ie disconnecting the video cable of the monitor & leaving the power cable connected & then see if u r getting the red,blue,green multicoloured bard moving on the screen or not,if yes then the monitor is fine otherwise the monitor is bad.
Apr 02, 2009 | Dell Dimension 8400 PC Desktop
My pc just bought will not work
if you computer has a graphics card you would find a connector on the bottom, there will be two places where you can connect you computer to, one would be on the middle and the other would be near the bottom the connector woudl look blue in colour, make sure if you have a video card installed, you would see a blue colour port near the bottom and it would be horizontal, connect the monitor video cable to that port and this issue would be resolved
Feb 05, 2009 | Dell OptiPlex GX260 PC Desktop
LG flat panel
Due to no model number I will assume it has bith digital and analogue inputs.
If possible, connect another cable the opposite of what you are using and try it again. (IE: if you are using a DVI cable now, use an analogue instead)
It is possible that the internal video card of the monitor has been shorted out and will not accept a signal any longer.
On the upside, if that is the case, the digital and analogue circuits are normally seperate to each other so losing one dosn't mean losing both. It could also be the output section of your PC's video card that has suffered the same fate so try the other video port (if you have 2 on the same card) or try another video card.
Sep 19, 2007 | Dell E177FP LCD Monitor
Dell OptiPlex GX270 PC Desktop Logo
421 people viewed this question
Alun Cox
