Question about Xerox WorkCentre PRO-215 All-In-One Laser Printer
One side of mirror assembly sticks during copying
One side of the mirror assembly is sticking midway through the imaging process, but the other side continues normally. the result is a copy with a "st r e t c h" on one side.
how do i remove the glass to get to the assembly? i'm assuming it's a lubrication or debris problem.
  • danwayn Feb 16, 2009
    i only had to remove the two screws on the right side, removed the right cover (the service manual only indicates to remove one screw) and gently lifted the glass out.
    one of the clips which attaches the moving assembly to the wires had cracked and broken off, i used super glue and then duct tape to reinforce the repair.
    that seemed to work fine, but now i have a new problem: L6 (with 10?)
    i switched it on and off a few times, and now the printer is stuck in some kind of warm up loop. i will be posting another problem for this copier.
    President:
  • 2,072 Answers
Those covers are sort of a pain to get off, but not impossible. You easiest way it to remove the screws form the left and right side covers, and pop them off. then also lift the feeder off, if you have a document feeder and take out the 2 smaller screws in the rear cover, because they over lap the glass covers . Then remove the glass. Just take your time, not hard at all. Most likely you will find something has slippped into the scan lamp path .
Posted on Feb 05, 2009
C0210 minolta di 450
Directly below the drum section is an assemble called the transfer/separation assy. the purpose of this unit is twofold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevents the paper from sticking to the drum during the transfer process. The code you have been getting means either wires might be broken, or has to cleaned (because of all the toner on it from the drum assy. which needs to be removed and cleaned. Or two white end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process to leak to ground. Open and close the front door to clear. If it comes back have a qualified tech look at it.
try this site for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 13, 2014 | Konica Minolta Office Equipment & Supplies
Error code 2307 konika minolta bizhub 600
Sir/Mam
Directly below the drum section is assemble called the transfer/separation assy. (Pull out the middle section will see assy with black grids across it under the grids are some very fine wires) the purpose of this unit is twofold. (It houses several very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevents the paper from sticking to the drum during the transfer process. The code you have been getting means either wires might be broken, or has to be cleaned (because of all the toner on it from the drum assy. which needs to be removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process to leak to ground. have a qualified tech look at it.
Dec 26, 2013 | Konica Minolta Office Equipment & Supplies
Bizhub 600 has an error c-2703 what is the reset
Sir/Mam,
Sep 20, 2013 | Konica Minolta bizhub C250 All-In-One...
Bagaimana mengartikan kode error c0200
Sir/Mam, Below the drum is an assemble that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first wire transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
Aug 09, 2013 | Minolta EP4000/5000 CS/PRO Copier
Di550 light printing
Directly below the drum section is assemble called the transfer/separation assy. the purpose of this unit is twofold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. use a eraser end gentle I mean gentle clean them. release front lever then push down and pull out transfer/separation assy. remove the guides clean wires, again be gentle, has the drum been replaced, does this happen with printing or copying if only copying clean the mirrors below the big glass, be gentle can use Windex, use of paper towel don't leave any little paper particles
Jun 24, 2012 | Minolta Di550 B&W Laser Printer
Minolta di552 copier error message c0210
Directly below the drum section is a assemble called the transfer/separation assy. the purpose of this unit is twofold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. The code you have been getting means either wire might be broke, or has to cleaned (because of all the toner on it from the drum assy. which need to removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process are breaking down allowing the high voltage to ground. Open close the front door to clear. If it comes back have qualified tech look at it. Try web site below for place to start for parts
Feb 16, 2012 | Minolta Office Equipment & Supplies
How do I change from internal memory to external memory on my camera?
You can copy all the images from the Internal Memory to a Memory Stick Duo media using the COPY option in the Memory Stick Tool Menu option.
Please insert the Memory Stick Duo media with sufficient free capacity into the Camera.
Select MENU--> Settings-->Memory Stick Tool-->COPY-->OK.
The original images in the Internal memory retain after copying. You may have to delete the contents of the internal Memory. Remove the Memory Stick media after copying, then format the internal memory. FORMAT in Internal Memory Tool.
You can only copy the images to the new folder created on the Memory Stick Duo which is created automatically. You cannot copy the images to a specific folder.
Thanks for using FixYa.
May 09, 2011 | Sony Cyber-shot W290 Digital Camera
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
I need to replace passenger side mirror on 97 ford expedition
Both above answers are not right... I just replaced the Pass side power mirror assembly on my 97 Expedition. No heat, no directional.
The inside door panel must come off.
1. pry off interior triangular plastic trim piece inside of door at mirror area. Remove door panel screw at this area.
2. Pry off power window switch panel and remove door panel screw at this area.
3.Remove interior door light cover and remove screw at this area.
4. Remove plastic cover at door handle.
5. The interior door panel can now be lifted up to release it from it's fasteners.
6. Disconnect light and push power window switch assembly through the door panel and it can be set aside.
7. Disconnect mirror power at coupler.
8 Loosen three mirror mounting screws with 7/16 socket. DO NOT unscrew completely.. the will fall down the door cavity. Use a round magnet on holder to remove the screws completely.
9.Thread electrical connection into door panel and install mirror.
10. Smile when mirror works and drink a beer!
rayman
Dec 27, 2008 | 1997 Ford Expedition
Rear brake diagram
Look at other side rear brake, if you can't transpose it in your mind, then stick a big mirror in front of the other side and take a photo of the brake image in the mirror ... hmmm,  you may end up thinking like this after a while.  I don;t know that that is a good thing;~).
good luck, ..ajm
please rate all solutions
Nov 06, 2008 | 1997 Volkswagen Golf
Xerox WorkCentre PRO-215 All-In-One Laser Printer Logo
43 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
