Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
No channels after scanning analog cable on Hauppauge 1600
I don't have a cable box. The cable goes directly into a cable-ready TV. So there's no need to use channel 3 or 4 as an RF source on my Hauppauge 1600, right? I've scanned in both cable & Cable HRC modes with no results. I've tested the cable line & it's OK. I've checked to see if I plugged into the correct input on the PCI board, that's OK--So what goes??? is there a setting I've missed?
Athlon 64 3200+, windows xp Service Pack 2
Thanks in advance!
  • beaglis Feb 09, 2009
    I have same problem. Have cablevision.
  • Francisco A
    Francisco A May 11, 2010
    Did you install the software with the tv tuner?
I have exactly the same problem with the very same equipment but I may have found a solution. Try scanning for DVB-T channels and you may find some success. I also recommend printing up the WinTV user manual and reading it. I'm not big on reading manuals but this one actually has a lot of useful info. I will try to fix my setup and let you know if it works. Today it is recording all 6 Star War episodes till 2 am plugged in through the set top box (can't interupt)
Posted on Apr 11, 2009
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
No channels scan in
you have to use an old fashioned set of tv top rabbit ears with a uhf loop just like the good old days if you have cable hooked up it will not work..
Nov 08, 2009 | Hauppauge WinTV-HVR-950Q TV Input
Windows media center can not find ir receiver
be sure you have installed the driver. If you are using windows 7 you still need to install the winTV driver. I know this because I had the same problem. It should work then. Just go to TV setting in the media center setup and it should scan for channels.
Jul 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Tv tuner
Basically what I can see from what I have read one had dual tuner capability and one is set up for PCI Express. Both look like great cards.
http://www.hauppauge.com/site/products/data_hvr1600.html
http://www.hauppauge.com/site/products/data_hvr1800.html
Thanks
Armymason
Feb 24, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No Audio with WinTV-HVR-1600 when tuning on S-Video
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
Nov 19, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
Nov 10, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
Oct 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Connection Hauppauge WinTV HVR-1250 tuner?
you are not going to get anything once you disconnected from the provider. It is the same thing as just pull the cable from the wall.
you can get TV signal (normal basic-brocasted) by using the roof top antenna, I don't know what kind of antenna will be require after 2/09. when the TV broadcast change to digital signal. but in the mean time, you need a converter box from analog to digital for the TV.
Nobody want to pay the monthly fee. if you have the equipment, you can set up the receiving station from the satellite. then you don't have to pay anything. As far as I know, no body have such equipment. cable company spend millions of dollars to set them up, so you have to pay for it.
Jul 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Wintv stuttering when watch channel, but is fine when record it
Further update: Have downloaded SageTV, and it works fine with the Hauppage card. Is definitely a software problem. Have also tried total uninstall, reinstall, with same results. Also downloaded GBPVR, and it also worked with the card.
Jan 03, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Open Questions:
See all Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / Questions
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
1,397 people viewed this question
Top Hauppauge Televison & Video Experts
Luc Francoeur
Luc Francoeur
Brian Sullivan
Brian Sullivan
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
