Question about Canon PIXMA MX850 Multifunction Printer
FRONT PAPER FEED
JUST PURCHASED A CANON MX 850 MULTIFUNCTION & DO NOT UNDERSTAND HOW THE PAPER FEEDS INTO THIS MACHINE FROM THE FRONT TRAY? THERE IS NO TYPE OF SPECIAL TRAY THAT POPS OUT OR ANY OTHER DEVICE WHERE IT WOULD TAKE THE PAPER TO FEED INTO FROM THE FRONT. AM I MISSING A PART OR IS THERE SOMETHING THAT I COULD NOT FIND ON THE DIRECTIONS?
  • Anonymous Feb 05, 2009
    kjlj
  • 1,812 Answers
Go to this site. In the search window in the center of the screen, type "paper tray" and click on the Search button. Select the link "How do I load the paper". When the document comes up, select the link "Cassette" near the top. You will see illustrated step-by-step instructions. If you are missing the cassette tray, contact Canon.
Posted on Feb 05, 2009
Paper tray in my image class MF8350 won't close
There's probably a piece of paper wadded up in the feed mechanism. Carefully remove the paper tray and look in the feed rollers. Also be sure all the "guides" are in their proper orientation.
May 19, 2014 | Canon Imageclass Mf-8350cdn Color Laser...
I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
If you do not have a manual it can be downloaded from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
Issue: More than one sheet of paper feeds while printing
Solution: Clean the paper feed rollers using the MX300 operator panel
sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
2. Clean the paper feed roller.
(1) Press the Menu button repeatedly until MAINTENANCE appears.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
The paper feed roller will rotate as it is cleaned.
3. Repeat step 2 twice.
4. Open the Paper Output Tray.
(1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
(2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
Set the Paper Thickness Lever to the left.
6. Repeat step 2 three times.
The paper cleans the paper feed roller as it feeds through the machine.
If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
Dec 25, 2010 | Canon MX300 Office All-In-One Printer
Cant get it to feed in the front tray
Your paper feed is in the back. You are trying to feed paper into the EXIT door. Open the paper access door on the top of the machine, and install your paper so that it is facing you, laying against the door. Paper should feed properly.
Nov 16, 2010 | Canon PIXMA iP3500 Printer
Mx 850 gives error code 6A00 . We have purchased
6A00 means the purge unit is not cycling properly. If the printhead can come out of the right corner, you check there for paper scraps. If it's stuck on the right with this error you will need a shop to take apart and see if you need a new purge assembly. The part cost is only around $20.00
Feb 22, 2010 | Canon PIXMA MX850 Multifunction Printer
Mx 850 canon with reoccurring error of 6010 or 6000
if it's 6A00 then theres a problem with the cleaning unit where the printhead parks. Look for any paper scraps in that area, 6000 is a paper feed error saying something may have fallen in stopping the paper transport roller.
Jul 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon Pixma MX850 says it's out of paper when there is paper
The feed switch changes the paper feed from rear feed to tray feed (paper tray is under the output bin). If you have paper in the rear feed, the green light should be on top of the printer icon left of the feed switch. If you have paper in the tray, the light should be on the bottom of the printer icon.
Apr 14, 2009 | Canon PIXMA MX850 multifunction InkJet...
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
Canon PIXMA MX850 Multifunction Printer Logo
369 people viewed this question
old marine
old marine
Corne Viljoen
