Question about Konica Minolta DiALTA Di200 Copier
Frequent paper jams with my Konica 2223 photocopier
Whenever i photocopy a document with my Konica 2223 model, the paper jams and the printout are black all over..
  • sam gerban
    sam gerban May 11, 2010
    is the exposure lamp comes on when you copy?
    do you see any image at all?
    what is the copy count on it?
  • 3 Answers
I believe u have cleaned all the optics right? if yes then,check if ur dev. is over toned run a few copies with flat top cover open
if not then change the dev and see if it works
Posted on Nov 07, 2009
    Sergeant:
  • 210 Answers
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Posted on Aug 10, 2009
  • Herminio Halili, Jr.
    Herminio Halili, Jr. Aug 11, 2009
    Give us a feed back. Also there might be a paper wrap around the recycling unit and that is required to pull the drum carriage unit. Open the right front cover and locate two black screws you have to loosen to remove the drum carriage.
How do i fix toner stain on printout and photocopies? please what might be the cause of the dot stains?
There are several reasons for stains on a Laser printer or photocopier
1. Clean all rollers. Fuser; transfer and pickup.
2. Ensure the toner is clean from outside.
3. Hope the Toner is not refilled and Is not leaking.
4. Clean paper path.
Mar 08, 2016 | Office Equipment & Supplies
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
Canon Pixma mx300 printer has paper jam message.
Canon Pixma MX300
- new cartrige for Black ink
- can scan
- can photocopy documents
BUT can't print documents from my MacBook eventhough the paper feeds and goes out at the other side
Aug 10, 2009 | Canon PIXMA MX300 All-in-One Printer
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
Data light flashes , documents won't print.
this is not a network problem.because machine is receiving documents thats why light is blinking. check the paper in the tray whether they are of correct size, change the paper size from computer, or call your tech service rep it may be due to usb cable or faulty network cable, or it may be the problem of main communication board of photocopier machine.
Feb 10, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
Error code 27
The error code p27 the toner density sensor unplugged/dirty/faulty
Any problems please get back to me
thank you
Feb 19, 2008 | Office Equipment & Supplies
Photocopy problem
try to check the flatbed area there's a small parts that will missing.
Feb 15, 2008 | HP LaserJet 3030 All-In-One Printer
Konica Minolta DiALTA Di200 Copier Logo
359 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
