Question about Eiki PowerHouse LC-X4LA Multimedia Projector
Eiki projector daed
I have one EIKI LC-X4 projector which have no power. I isolated the problem in the main power board. Power comes to the capacitors after the bridge. STR IC is ok. all transistors and diodes are ok. resistors also. we replaced photo couplers also. anybody can help? pls..... I appreciate your kind responze
    Problem Solver:
  • 6 Answers
Check first the fuse
Posted on Feb 05, 2009
Eiki LC X1100 - the unit is loosing all power [no standby leds] when switching on after being off for 5 minutes or more. I've found that if power is disconnected and Reset switch is engaged it will come...
in primary power-supply circuit there are 2 smd capicitors,1uF and 2.2uF, replace them both by standard radial 105 C electrolytic, also replace the 220uF capacitor that is located beside these 2.
Oct 16, 2013 | Eiki LC-X1100 Multimedia Projector
Have Eiki LC-X1000 projector. Recently had a power outage and since then it has not come back on. Have tried the reset, 230 AC ok and 300 DC volt ok, No standby light, nothing,then what can i do
dried out smd capacitors in primary part of power supply , common problem with this and similar models. 1uf, 2.2 uF and 1 radial 220 uF
replace bij 105 oC type
Apr 05, 2012 | Eiki LC-XG250 LCD Projector
Eiki LC-SD10 Projector will not power on.
any led on ? if no, check thermal switch near lamp house or dried out capacitors in power supply
Aug 20, 2011 | Eiki LC-SD10 Projector Multimedia...
Eiki lc-sd15 has no power. The lights do not come on when plugged in and nothing works.
near the lamp door is a small hole with a resetable thermal fuse under it, try to push pin carefully
Jan 18, 2011 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
NO POWER
sounds like a heat sensor or fan problem. How old is the lamp, lamp hours etc.
http://www.youtube.com/watch?v=HvZ2DlVJ790
http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Sep 09, 2009 | Eiki PowerHouse LC-X4LA Multimedia...
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
EIKI LC-XNB3 Projector - Does not recognize any Video Inputs
there might be a bad connection between the input board and the main board. There are different connectors ( white) between them, that might be damaged during portable use
May 24, 2009 | Eiki LC XNB3 Multimedia Projector
Eiki PowerHouse LC-X4LA Multimedia Projector Logo
331 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
