Question about JVC LT-47X788 47 in. LCD HDTV
Can't connect XBOX 360 please help!
SO... I just upgraded from a 37 Visco to a 47 JVC. My DIRECTV is up and running, but my 360 is not showing sound or signal. I was able to connect it on my 37 inch no problem.
How can I connect my 360 to my new JVC 47 inch.
Thank you to whomever can help.
  • 48 Answers
How many video ports does it have? You may have to search through video 1, 2, 3, or switch the TV itself to component/HDMI depending, with the remote. Should be with an 'input' button.
My tv has a list with HDMI, SVIDEO, COMPONENT, PC, ect. and its a 1080p one, im just assuming all HDTV's have a list
Posted on Feb 05, 2009
Pano upgrade ang xbox 360,n gling japan..
Sounds like you would like to upgrade your Xbox 360. If you could be more specific on what exactly you would like to do with it, I could thoroughly help you out better. Incase it's about upgrading it, here's what options you have.
- You can upgrade the hard drive to one with more storage capacity.
- You can change the whole case; you can even get a clear case which would allow you to see everything inside the Xbox.
- You can add skins to your Xbox
Best of luck
Feb 02, 2011 | Microsoft Xbox 360 Console
My sounds works and so does my directtv but no picture will show up for my 360 i bought a new av cord and it still wont work how do i fix it
Are you on the correct channel or input for the xbox 360? Also check your av cable to see if it is on the hdtv or regular tv. You can move the switch to make the adjustment. It may be how you have set up your xbox 360 cables and the directv box cables to the tv so you should consult your tv manufactory for the correct guide on setup.
Dec 22, 2010 | Microsoft Xbox 360 Console
I tried connected my XBox 360 HDMI components to my Philips 32PT5441/37. When I did that and turned it to "CVI" it shows my screen but its not positioned right and it keeps moving up and down....
In many cases there is nothing wrong with the TV. You may need to reread the handbook for operating setup on picture centering in the Xbox instruction book. In some rare occasions you may need to upgrade the Xbox with a USB upgrade connection. Thanks for asking and show a few hands of support!
Nov 07, 2010 | Philips 32PT5441/37 32" TV
Xbox 360 hookup problem
Check the video cable coming out of the xbox, depending on which model xbox it is (arcade, pro, elite etc.) it will most likely have both component cables - green, blue and red or RCA cables - Yellow, red and white. It sounds as if your JVC would only be able to run RCA cables (due to its age) so use the yellow cable for video and white and red (or just white if you only have a yellow and white input) and then make sure the switch located on the cable is switched to "standard" and not "hi definition" hope it helps. -if you have any further problems
Jul 06, 2009 | JVC LT-47X788 47 in. LCD HDTV
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
Xbox 360 pro
Salutations LHmom,
Because your using laptop computers and a mobile carrier for your internet services this will be a little harder then normal but not imposable.
First what you would need is a ethernet switch or hub. This should allow you use the laptop with the Verizon card as a "Gateway". You would then connect the Xbox 360 to the hub and it would share the internet from the laptop.
Windows XP, and Vista have nice networking wizards that can walk you through the settings. But be aware you may need to change the settings back when you are not using the Xbox 360.
Hope this helps.
Go Ahead. Use Us.
May 08, 2008 | Microsoft Xbox 360 Console
XBox 360 and Other Game Connections
How are you connecting the XBOX 360?
Component? HDMI?
Make sure all connections are plugged in snug.
If you use HDMI then audio should work without seperate cable.
For component make sure red and white cables are also plugged into right spot on back of TV.
Hope this helps!
Mar 24, 2008 | Sony KDE-37XS955 37 in. Plasma HDTV
XBOX 360 to JVC RX 5060b
does your reciver have video ins and outs monitor out u have to send master video out from jvc to tv 1st u know im open for chat
Jan 06, 2008 | Audio Players & Recorders
HD Connections
try using the scart tht came with the xbox i had this prob first time but its quiet easy 2 fix
Dec 29, 2007 | Microsoft Xbox 360 Console
JVC LT-47X788 47 in. LCD HDTV Logo
887 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
