Question about Kenmore 24032\24036 Top Load Washer
Oil leaked out of the washer transmission
The washer was laid on its side when it was moved and oil leaked out of the transmission. How do I refill the transmission and what kind of oil do I use?
  • 31 Answers
This may be a bit above your skills but first unplug the machine. You will need to purchase a special tool to do this job. It is called a spanner wrench, and it removes the drive block nut securing the inner basket. Remove the agitator, by removing the cap, and loosening the bolt on the inside. Loosen (using the tool), the nut securing the drive block to the basket drive. Locate and remove the 2 screws that secure the console to the cabinet. Tilt the console backwards, and remove the 2 gold clips, and disconnect the lid switch connector. Tilt the entire cabinet forward, and off of the base. Remove the inner tub, and remove the basket drive block. Remove the clips securing the pump to the motor, but do not remove the hoses. Remove the motor clips, motor and unplug the motor wiring plug, and take the wiring clip out of the transmission. Gently, tilt the entire machine to a 45 degree angle, so that you can access the underside of the machine. Remove the 3 bolts that secure the transmission (1/2 inch). Carefully, pull the transmission out of the machine. You must remove the transmission and open the top of it and fill it with 85 or 90 weight gear oil. I suggest that you replace the clutch at the same time. The clutch is the round thing sitting no top of the transmission. The basket drive is the thing sticking out of center of the machine, with the plastic tab hanging down. Pull the basket drive out of the tube. Inspect the basket drive hub, to make sure that there is no oil on the hub. If so, make sure you clean it very well. Be as quick as possible, because oil will start leaking out of the shaft bearings since the machine is tilted, and you cannot stop it. Make sure that you use the proper spring for the brake and clutch, and then the re-assembly is the reverse of what you have done.
You may want to call a repair man!
Posted on Feb 05, 2009
I replaced the tub/motor coupling on my Kenmore model # 110.26912690 washer. I laid the machine on its back, while waiting for the parts, which came 3 days later. I noticed some thick oil had leaked...
Your oil is more than likely from the washer's "transmission". like your car, the washer employs a similar set up in order to change from "agitate' to "spin", etc. the oil is necessary to the operation, and the extended time (3days) on its side allowed some to leak out. Unfortunately, the only sure-fire way to tell if you still have enough oil will be to have a repair tech look it over and add if necessary. for future reference, if you ever think you need to tip your unit over, you'll have to be very quick about it, and if it needs parts, stand it back upright while you wait.
Jan 18, 2012 | Kenmore Washing Machines
Gear oil leaking out
I have or thought I have posted you a solution. Here goes again. Unfortunately you cannot refill it unless you remove transmission from the washer and then you'll have to open it up to refill it. It's very doable if you are somewhat mechanicaly inclined. Good Luck
Jun 01, 2009 | Washing Machines
Transmission oil
this unit uses grease if it is leaking out the grease has broken and needs replacing
Sep 09, 2008 | Hobart D300 Stand Mixer
Washing machine leaking oil
your washer has a transmission and this is what is probably leaking. You might simply need a new seal or the a new transmission. You need a good handyman or contact a repairman.
Jul 29, 2008 | Washing Machines
Gearcase oil leak by laying on its side - Problem?
There is a breather hole in the top of the gearcase. Yoy probably had some leak out through there when you laid the washer over. If it was not over to long you will probably be ok. there is no way to replenish the oil it would require replacing the gearcase.
Apr 07, 2008 | Washing Machines
Kenmore Elite Catalyst Mod. 22052
Oil is no problem. The door switch/interlock is faulty. Replace door interlock. Try closing the door firmly with an extra little shove on the door handle. Sometimes this works.
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Oil leak
A small amount is not serious. There is no good way of adding oil to the transmission unless you want to take the top off the transmission.
Jan 21, 2007 | Whirlpool LTG5243D Top Load Stacked Washer...
Kenmore 24032\24036 Top Load Washer Logo
301 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
