Question about Ricoh FW870 Black and White Copier
Error code e-12
What does this code refer to?
I don't know if you have solved this yet but it refers to your charge wire cleaning motor. It is probably bound up. Just need to take out drum unit assy. and move the cleaner back and forth.
Posted on Apr 27, 2009
P0014 on bmw 525i
Code P0014 "B" Camshaft Position - Timing Over-Advanced ...
www.obd-codes.com/p0014
Detailed information on troubleshooting and repairing a p0014 dtc diagnostic trouble code which refers to a camshaft position actuator circuit.Missing: 525i
Error Code P0014 - Bimmerfest - BMW Forums
www.bimmerfest.com > ... > 5 Series > E39 (1997 - 2003)
Jan 9, 2011 - 9 posts - ‎5 authors
Error Code P0014 E39 (1997 - 2003) ... Join Date: Nov 2010. Posts: 3. Mein Auto: X5,525i ... As an aside, I used BMW OEM parts. Thanks for ... 530i Error P0014
1 post
Sep 12, 2011
Code P0014 nightmare
Jan 7, 2011
2001 bmw 525i p0014
May 29, 2010
P0015, P0014 Codes: Intake cam sensor? Vanos ...
Jan 20, 2010
More results from www.bimmerfest.com
Dec 29, 2015 | BMW Cars & Trucks
I have codes 12, 21, 61, 55......on a 96 town an country. My van keeps stalling the radio and ac turn on an off an my transmission gets stuck in one gear until i turn the vehicle off an back on an then it...
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 21 Throttle Position sensor error (signal high
DTC - 61 A/C system performance
DTC - 55 Digital EGR Valve solenoid 3 error
Jun 28, 2011 | Chrysler Town and Country Cars & Trucks
I have 12 ready to print on my printer and want to clear them
Error 12 on most HP's refers to the fact the printer is Printer Open Can you provide your model number just to be sure of the correct solution for your error code.
May 14, 2011 | HP Office Equipment & Supplies
1997 breeze is shooting codes 12 46 43 55
OBD Code 12 - No Distributor Reference Pulse (Diagnostic Test Active) The Engine Control Module-ECM uses the distributor reference pulse to calculate the engine speed. On newer engines, the Crank Shaft Position Sensor performs this function.
Symptoms:
  • When flashing the Check Engine Light to read codes, code 12 will always display first, indicating the diagnostic system is active
  • The engine will not run with a "hard" code 12 set
Common Problems:
  • Chances are you will never need to diagnose a code 12. Rather, the problem would be a crank, no-start condition.
  • If code 12 does not flash, that would indicate a communication problem with the ECM.
  • Code 12 does not show when reading codes with a scan tool. If there is a communication problem, the scan tool will let you know.
OBD Code 46 - Pass-Key II System Error - Circuit out of Frequency Range The ECM receives a signal from the Pass-Key module. When the correct signal is received, the ECM will allow the engine to start and run. Please review the RepairPal article on the GM Pass-Key Anti-theft systems for more information.
Symptoms:
  • Engine may not start
Common Problems:
  • Faulty ignition lock cylinder
OBD Code 43 - Knock Sensor error The ECM receives a signal from the Knock Sensor based on the amount of engine ping detected. The ECM uses information from this sensor to help calculate fuel delivery and spark timing.
Symptoms:
  • Engine ping
  • Lack of power
Common Problems:
  • Faulty Knock sensor
  • Poor connection at Knock sensor
OBD Code 55 - End Test.
Hope ehit help (remember comment and rated this).
Jul 22, 2010 | 1997 Plymouth Breeze
Error code 12
The error code 12 normally refers to a flame failure/front flame rod did not sense any heat or ignition.
If you have turned off the heater and the message again pops up, it could be because of following things:
Flame rod couldd be bad
Could be possibilities of carbon being stuck.
A dirty burner or losse wire due to which the flame is not getting on burner quickly.
Overall you need to check for debris.
In addition please find additional information:
http://www.rinnai.us/documentation/downloads/Error_Codes-Tankless_Water_Heaters.pdf
Mar 22, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Tv says airflow restriction tv will turn off. there is no airlfow restriction
I did not find a reference to airflow restriction in the service manual.
I don't know if this will help, but here are the error codes:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
4. Error Codes
The Error Code designations are listed below:
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Oct 20, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
99 Saturn SC1 ''Service engine soon'' light is on.
Did you get the code that triggered the SEL? If you know that, it will be easier to diagnose your problem. You can do it without a tool on the old saturns. Just need a paperclip. :
Use a paper clip to jumper Terminal A and B of the ALDL *Assembly Line Diagnostic Link* which is above your left knee.
Terminal A is an interal ground and is the top right terminal in the connector. Terminal B is directly adjacent and to the left of Terminal A.
Turn the ignition to ON.
All codes are 2 digits between 11 and 99. Codes are displayed on the SES light by flashing the light with short and long pauses to distinguish digits of one code from digits of another. The short pause is used between digits of the same code, long pauses are between codes. Also, each code is flashed three times before going to the next code.
For example, the sequence of code 12 will be: flash, pause, flash-flash, long pause, then repeat 2 times. If Code 12 is not displayed, the self-diagnostic pogram i snot functioning properly.
If only Code 12 is displayed, no system malfunctions have been stored.
Any existing system fault codes are displayed in order from low to high, except for Code 11.
On vehicles with an automatic transaxle and on which exist stored transaxle codes, Code 11 will be displayed last, then the SHIFT TO D2 light will begin flashing transaxle codes of flags.
When all engine codes have been displayed, Code 12 will flash again.
Diagnostic Codes
11. Transaxle Codes present
12. Diagnostic System Check
13. Oxygen sensor, circuit open or not ready
14. CTS circuit, out of range high
15. CTS circuit, out of range low
17. PCM fault, pullup resistor
19. 6x signal fault, no 6x signal between reference pulses
21. TPS circuit, out of range high
22. TPS circuit, out of range low
23. ATS circuit, out range low
24. VSS circuit, no signal
25. ATS circuit, out or range high
26. Quad Driver output fault
32. EGR system fault
33. MAP sensor circuit, out of range high
34. MAP sensor circuit, out of range low
35. IAC valve, rpm out of range
41A EST circuit open
41B EST circuit shorted
42A Bypass circuit grounded
42B Bypass circuit open
42C Bypass circuit shorted
41. EST bypass, open or shorted
42. EST bypass, open or shorted
43. ECS (knock sensor) circuit open or shorted
44. Oxygen sensor indicates system lean
45. Oxygen sensor indicates system rich
46. Power steering pressure switch circuit, open
49. Idle rpm out of limit high (vacuum leak)
51. PCM memory error
55. A/D converter error in PCM
81. ABS message fault (1993 vehicles with TCS)
82 PCM internal communication fault
Diagnostic Flags
27. Quick quad driver output fault (1993 only)
48. Reference imput intermittent or noisy
52. Battery voltage out of range
53. ESC knock present
54. Five volt reference ground
58. Battery voltage unstable
61. 6x signal fault
63. Option check sum error
67. Handwheel sensor circuit fault
71. Cooling system temperature high
72. Coolinng system temeprature low
73. CTS sensor unstable
74. CTS/transaxle temperatuer sensor ratio error
76. ATS sensor unstable
83. Low coolant (1993 only)
Feb 24, 2009 | 1993 Saturn SC1
Error Code 9-357
Don't have the codes for that one BUT 09 --- codes always refer to drum/toner problems. Make sure the drum unit is plugged in properly, and cables/plugs etc secure
Jul 19, 2008 | Xerox DocuColor 12 Color Copier
Ricoh FW870 Black and White Copier Logo
212 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
