Question about Samsung DLP HL-P5663W 56" TV
Samsung HLR4667 DLP picture problems
I have the 46 DLP from Samsung and it has been making a weird whining noise when I turn it on and then after about 3-4 rounds of that noise, it shuts off and the front lights blink as if the bulb were bad. I've replaced the bulb and it didn't help. Now, the picture is pixelated in the black areas and on actors skin and some colors. Can anyone tell me what may be wrong with this unit since its apparently not the lamp.
Thanks in advance for any help.
Patrick
  • Anonymous Feb 05, 2009
    Okay. First things first. Intermittently, when I turn it on I will hear a whining noise like a motor is spinning up, then down, then up, then down again. After about 3-4 tries, the unit shuts off and the lights on the on/off switch blink as if to indicate there is a lamp problem. However, I changed the lamp recently and it didn't fix the proble.
    Now, while that problem hasn't happened in a little while, I am seeing pixelation or maybe its just real bad contrast in the light and dark areas of the screen. You see really well on people's faces, on white areas, and in black or shadowed areas or the screen. This has gotten worse and if I change to some other mode besides "dynamic", the colors turn to **** altogether.
    I hope this explains it a little better. Thank you very much for your help so far.
  • Jim London
    Jim London May 11, 2010
    Hi, First you say it shuts off then you say the picture is pixelated. Can you explain your problem exactly. Thanks
    Top Expert:
  • Samsung Master
  • 74,198 Answers
Color wheel problem. replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Jun 04, 2017
SOURCE: dlp tv will not "fire up"
Hi there, your instruction manual should have a trouble shooting section, and will tell you what various warning lights are indicating (ie the Lamp/Temp lights will flash in a particular sequence), and will give you the probable cause. In some cases, it could be blocked vents (dust causing overheating/shutdown), or just the lamp failure or faulty switch (indicating loose cover).
Posted on Jul 01, 2007
ctf1800
  • 4402 Answers
SOURCE: Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Posted on Jan 16, 2008
SOURCE: PROBLEM WITH SAMSUNG DLP TV
disconnect the power and hold in the power button for 30 seconds to reset it.
Posted on Mar 03, 2008
SOURCE: samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Posted on Apr 10, 2009
SOURCE: Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Posted on Aug 31, 2009
My Samsung DLP HD 46" TV just went Black &
Defective Color Wheel- Encompass parts Distribution 1-800-638-3328
Mar 06, 2011 | Samsung HLP4674W 46" Rear Projection HDTV
My Samsung DLP hlr4667 turns itself off multiple time a night. Otherwise the picture quality is fine and no warning of a problem.
it may be faulty wiring or a bad dust buildup if its still under warning i would have it replaced otherwise it may be to risky to do it yourself
Dec 23, 2010 | Samsung DLP HL-P5663W 56" TV
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Whining noise
Color wheel is going or gone out. New colorwheels are air bearing and not mechanical.
Jun 27, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Jan 24, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
No Picture no sound
The color wheel will make a high pitched sound or even a clicking sound if it is bad. Also the ballast will make a clicking sound also if it is not seated to the lamp properly or if the ballast need replaced.
Mar 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung 46 DLP buzzing noise dark picture flashing lamp did not turn off unpluged from wall outlet)
Sounds like you have a bad color wheel assembly which is located in your light engine assembly.
pt#BP96-00250A
Nov 26, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung DLP R-4664_W
stll have picture?....is colors distored.. sound like a color wheel problem.. the colorwheel is a motor anything that moves eventally wears out.
Nov 17, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Whining Noise - hardrive or fan?
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Jan 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
134 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
