Question about Roper REX4634KQ Electric Dryer
Dryer takes longer and longer to dry
I have a Roper Rex4635ew1 dryer and it worked great untill a couple of weeks ago and now it takes longer and longer to dry,. It is putting out heat nothing seems to be clogged. Can any one help
  • Anonymous Feb 25, 2009
    Dryer puts out heat, vent pipes not clogged, just cleaned them out. Is there a blower or fan that pushed the air thru the tumbler and out the vent? If so does it include a motor or just a belt of some sort to spin the fan blades.
  • 10,865 Answers
The dryer vent may be partially blocked. First of all check the outdoor end of the vent to make sure it is not covered with something, in the north snow is often the culprit. If that end is clear, pull out the dryer and disconnect the vent pipe from the dryer then check inside with a flashlight to make sure it is clear. Remove any built up lint. that should do it.
Posted on Feb 05, 2009
TAKES 2 TO 3 CYCLES TO DRY. gETS BARELY WARM
If your dryer is still heating, but you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Mar 08, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Our dryer is working fine until it trips the switch.
If tripping of the switch means the circuit breaker is tripping, then yes, the problem may be in the heater box, or may be the motor. It could also be some faulty wiring though, and a good tech could easily determine what is causing the failures.
Jan 24, 2009 | Roper REX4634KQ Electric Dryer
Dryer takes longer
check the humidity sensor not working
Mar 09, 2008 | Dryers
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Roper dryer by whirlpool- gas dryer
You have a severly blocked vent, its not removing the moisture to the outide but instead getting trapped in vent.reccomned reventing unit with solid duct pipe, not the vynyl flex tubing and mke sure the outside exhaust port is totally free of obstruction a well
Feb 24, 2008 | Dryers
Drying time is longer than usual.
Check if you have a reasonable amount of airflow when it is operating. You may have a broken connection in the joint or a problem with the dryer fan,
May 17, 2017 | GE Dryers
Roper REX4634KQ Electric Dryer Logo
158 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
