FoodSaver V3880 Vacuum Sealer - The Master Chef Kit Logo
A
Anonymous Posted on Feb 07, 2013
The botton on the v3880 says that tray is full and its not, I have turned the foodsaver and on and off and it still is on?
My FoodSaver will not activate when I insert a bag. The accessory unit works fine.
It sounds like you are having some issues with your FoodSaver vacuum sealer. Here are a few things you can try to troubleshoot the problem:
  1. Make sure that the FoodSaver is plugged in and turned on.
  2. Check the sealing strip on the vacuum sealer to make sure it is clean and free of debris. A dirty or damaged sealing strip can prevent the vacuum sealer from working properly.
  3. Check the vacuum bag to make sure it is properly positioned in the vacuum sealer. The bag should be inserted with the open end facing the sealing strip.
  4. Make sure that the bag is not too full. Overfilling the bag can prevent the vacuum sealer from working properly.
  5. If the problem persists, you may need to take the FoodSaver to a repair center for further diagnosis and repair.
Sep 21, 2022 • Vacuums
Foodsaver v3825
I am having the same problem.. any answers??
2answers
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
FOODSAVER V3880 DOESNT GET GOOD VACUUM IN BAG
Sounds like the foam seals are leaking. Go to their website to get replacement parts.
V3835 tray full light won't go out after both trays have been emptied and cleaned.
Hair dryer. Remove both tray inserts and dry thoroughly, paying special attention to the sensor area in the center of the upper tray.
1helpful
2answers
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Foodsaver
Here is the link to your foodsaver manual.
http://www.foodsaver.com/Support.aspx?id=spma&mgid=1
Sep 09, 2009 • Vacuums
Top FoodSaver Vacuums Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Curt mueller
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
