Question about HP Compaq Evo D510 e-PC PC Desktop
Problem with recognizing 2nd hard drive in Compaq EVO D510
I purchased a WD 500 GB WD5000AAKB hard drive for my EVO D510. I installed it as a secondary with the Cable Select Jumper settings. When booting up, I checked the setup and the system recognized the hard drive in the setup. I saved the settings and booted up to XP. I could only see the C drive and not the new drive. I went to the Add Hardware menu and saw the device and it said the "device is working properly". I tried changing the jumper settings to master/slave but the system wouldn't even recognize the drive at that pont. I changed it back to Cable Select and the system recognized the drive but I couldn't see it in My Computer.
Any ideas on what to do?
  • mhdhlh Feb 06, 2009
    Problem solved. Thank you very much!!!!
  • Anonymous Mar 31, 2009
    hey i had the same problem thanks for the help....thanks
  • 3,940 Answers
You need to initialize the newly added drive in disk management, then format the drive once disk management assigns a drive letter.
CONTROL PANEL, ADMIINSTRATIVE TOOLS, COMPUTER MANAGEMENT, DISK MANAGEMENT
There you should be able to see the 2nd drive, Right click and INITALISE it, once it is initialized, it will be assigned a drive letter and you can format the drive
Posted on Feb 05, 2009
I am attempting to run a compaq EVO d510 with a recently imaged 160 GB hard drive. It flashes blue screen of death and reboots after loading agpcpq.sys. I think that the most advanced hard drive mode is...
If the image on your hard drive doesn't have all the right drivers for your system, it won't work, and you will get BSOD. can you boot into safe mode? If so, you may be able to uninstall a driver or two...it usually the last driver/file that successfully installed, not the one that doesn't finish loading, so see what the file "before" agpcpq.sys is. If you have a windows XP cd, you can try to get into the recovery console and then the command prompt, and typing "fixboot" ...or you can run the system file checker "sfc /scannow" ...but without more information, you may end up wiping it. Do you know what drivers are on the hardd rive?
Jan 12, 2010 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Can compaq evo D51s support 500 GB hardisk
Yes this can support the 500 GB or hard drive that you want to put on the system.......
Jan 05, 2010 | HP Compaq Evo D510 e-PC PC Desktop
Hello i have compaq evo d510 and
You need to partition your Hard drive to however much you want reserved for the Linux OS. You need to get a live CD of the Linux distribution you want and after you have partitioned your Hard drive, you need to boot from the live CD and install Linux onto the Partitioned part of the hard drive. DO NOT install Linux onto the regular partition, this will mess up your current operating system
Dec 14, 2009 | Compaq Evo D510 PC Desktop
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
Compaq D51S/P2 can somebody help me drives for this ?
Drivers for this model can be found below
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=97129&taskId=135&prodTypeId=12454&prodSeriesId=96300&lang=en&cc=us
Compaq Evo D510 Models with Intel 845G Chipset All D510's come with: Integrated Intel Extreme graphics Integrated Intel PRO/100 VM NIC Integrated Intel PRO/100 VE NIC (e-pc only) Integrated Intel Audio Model Key
Example: D5S/P1.5/20j/2/128c/vn
D51S
D510 Small Form Factor
D51C
D510 Convertible Minitower
D51U
D510 Ultra-Slim Desktop D51E
D510 e-pc P2.0
P4 2.0Ghz processor (c = Celeron) 20
20-GB hard drive K
XP Professional X
XP Home P
XP Pro/2K dual install 2
Win 2K 256
Memory amount
C
CD ROM
R CD-RW
N NIC
Jan 27, 2009 | Computers & Internet
Creepy 'USB' issues...
check you USB wire end, if that center piece ( that white piece inside the connection) is missing that the problem. that white piece separates electrical connection, it it not there it causes a shorts curcuit and the pc shuts down
Aug 02, 2008 | Compaq Evo D510 Minitower (Open Box)...
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
XP doesn't recognize my external 500 GB WD My book essential edition hard drive
Dear karroll.
Im having same as you're problem. but there is solution that might help you, but didnt work for me for some reason..
enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
restart your computer.
trying to connect your ext. Harddisk again
Best regards
-evo
Nov 27, 2007 | Western Digital My Book Essential Edition...
HP Compaq Evo D510 e-PC PC Desktop Logo
361 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
