Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Rear wheel/rim craftsman 16.5 model#917.271121 rear wheel
Rear wheel will not come off mower.trying to put new tires on mower.10 yrs old.tried everything but a torch.it is stuck.any ideas
  • 23 Answers
This is normal it take ALOT of force. I end up using a large hammer and a solid 2x4 to cusion the rim. Smacking it once good from the outside of the mower too. all this take place the the next morning after spraying in some pb blaster or similar anti seize spray into the axel.. and tilting the mower slightly. Dont use a torch it wont help. It only makes things hot and you will ruin the tranny seals.
I know its frustrating. expect that key way to be part of the problem in there to.
Posted on Feb 05, 2009
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
Craftsman lawn mower model 917,376673
you could put some screws threw the wheel into the tire or glue them on with plastic epoxy put there must be a defect in the batch of wheels there getting
Aug 08, 2012 | Craftsman 22" Rear Bag Rear Propelled High...
2009 FLSTC. slight vibration and wheel wobble.
Hi Anonymous, and the usual suspects are:
1. Improperly loaded motorcycle. Non standard equipment on the front end such asheavy radio receivers, extra lightning equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tire(s) or improper front-rear tire combination
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. Shock absorber not functioning normally.
7. Loose wheel axle nuts.
8. Excessive wheel hub bearing play.
9. Improper vehicle alignment.
10.Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires out of round or eccentric with hub.
13. Rims and tires out-of-true sideways.
14. Shock absorber improperly adjusted.
15. Worn engine stabilizer links.
16. Damaged rear engine isolation mounts.
17. Swing arm pivot shaft nut improperly tightened or assembled.
Good luck and have nice day
Aug 01, 2012 | 2009 Harley Davidson FLSTC Heritage...
What are the wheel and tire sizes front and rear for my 99 883 sposter?
Tire sizes. Front 100/90-19
Rear 130/90-16
Wheel sizes front laced - 19 in.
rim width and contour - T19 X 2.5 TLA
Tube size - MJ90-19
Wheel size rear laced - 16 in.
rim width and contour - T16 X 3.00 D
Tube size - MJ90-16
Wheel diameter tubless rim front - 19 in
rim width and contour - T19 X 2.5 MT
Wheel diameter tubeless rim rear - 16 in.
May 26, 2010 | 1993 Harley Davidson XLH Sportster 883
LMC-10 cover doesn't totally cover
probbably so the idea is to cover the egine etc, but here is the problem everything left outside is going to ruin ,rot from the tires to rainwater splashing up from the ground moisture inside the cover? you dont know how many of mt customers spend $1,500 on a mower only to finfd out 2 years later it ruinedleaving it outside ? if i were you i would spend about $100 on 6 peices of plywood and some joint sealer and make a box for your mower put hinges on on end to get it out easy ? this will keep your mower like new mine is 10 yrs old and its like the day i bought it? just a suggestion just hate to see money wasted on new mowers do to whether
Aug 26, 2009 | Mtd Arnold Lmc - 10 Lawnmower Cover
Rear wheel removal from craftman riding mower
Do you have the rim and tire off and you want to remove the hub?
I believe every rider mower and tractor I've had and worked on had the rear tire attached to the hub as in a car, with lug nuts or lug bolts. Check to see if there are four or five lug bolts that hold the rim onto the hub.
Jul 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My John Deer L130 tractor needed a new tire so I bought one and put it on. Now it will not go into gear. It will not go forward or backwards. Why won't it go. Please help Tammy
This was a rear tire I assume. There's a square key about 2" long that fits in a groove in the axle and a slot in the rim. You probably pushed it out putting the wheel back on and didn't notice. Look where you took off/put tire on. It should be laying there.
Jun 10, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
I would like to change the front tires lawn mower
Remove the wheel from the mower.
Let all the air out
Lay the tire flat
Push on the tire to release the grasp on the diameter of the rim (use a malet if ou need to)
Apply soapy water to the tire and rim
Insert a standard screwdriver between the tire and rim and pry the tire over the rim in one spot
Then work the screwdriver around the rim, pulling the rest of the tire up and over as you
go
Repeat the last step for the other side of the tire, same side of the rim though!
Viola, there you have it. Shade tree mechanic at it best. And NO labor cost$$$!!!!!
Mar 22, 2009 | Swisher 52" 20 Hp Riding Lawnmower #Zt2052
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
254 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
