Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Discharging water to fast.
My washer is discharging the water to fast.it keeps spilling over the drain pipe.and the drain is not pluged
  • Whirlpool Master
  • 8,220 Answers
You drain may not be blocked but it could be slow. Get some drain crystals from walmart. Go by package directions.
Posted on Feb 05, 2009
Water wants to drain and keeps trying
Sounds like anti flood system has triggered (polystireen float and micro switch) that puts the washer in pump out mode only and shuts the inlet water off. You need to look at the bottom of the washer and check that water leak / spill is not causing the float to activate. Clear the water and fix leak (pipe or pipe clamp) and this should fix the problem.
May 18, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Drain pump keeps running and F2 error
This is caused by the "anti flood" system being activated. Consists of a polystireen float and micro switch at the base of the washer. Once water leaks / spills are detected it activates and puts the washer in pump out mode only. You need to dry the base / check for leaks / rectify leaks (normaly a small hole in pipe or pipe clamp).
Apr 03, 2010 | Asko 24 in. D3350 Dishwasher
Flooding when spinning
Your drain may have a root growing into the drain and the water pump is simply too powerful for the drain to keep up.
Here is a cheap, fast and easy solution.
Buy some pvc pipe equal to the inner diameter of your drain hose and clamp it on with a reducing clamp to restrict the flow, then reduce more until the overflow condition stops. Sure beats calling rotorooter.
Mar 18, 2010 | Hoover H120M Front Load Washer / Dryer
Washer water spills from the wall drain
No valves on drains - it's a clog. Easy fix though - go to your hardware store and tell them the problem. They'll hook you up with an appropriate snake.
Nov 30, 2009 | Tecnik TKL9260 Front Load Washer
Waste drain does not take in water, spills out.
Replace the clogged drain pipe. You need a plumber. Washer is ok.
Jul 05, 2009 | Maytag Centennial MTW5807TQ
My washer drain pipe overflows when draining. i've tried smaller loads, cleaning drain pipe & vent, and raising the drain pipe. seems like the washer is draining the water too fast.
no you have a drain problem .... i would recommend calling a plumber the only thing it could be is drain problem there is no such thing as draining to fast.
Apr 30, 2009 | Washing Machines
Washer will only fill halfway
hello, 1 possable problem a pretty common problem and the solution is blindingly simple. It’s caused by the drain hose siphoning water out of the washer tub. There are two common causes for siphoning and I’ll explain both of them below.
drain-min.jpgOne cause for siphoning is simply that the drain hose discharge is below the fill level of the washer tub. This picture shows the minimum drain height needed to avoid siphoning.
Another common cause for siphoning is not having an air break between the drain hose and the drain stand pipe. Usually, this isn’t a problem since the drain hose diameter is usually much smaller than the diameter of the drain stand pipe. But sometimes folks will inadvertently remove the air break by duct taping the drain hose to the stand pipe. They might do this because the drain hose keeps popping out of the stand pipe when the washer pumps out the tub. Other times, the drain hose might fit into the stand pipe with a tight interference fit.also check your water inlet valve filter/screen make sure its not clogged.
Apr 09, 2009 | Kenmore Washing Machines
Water won't drain thru
you need to clean the drain pipe, maybe draino or call a plumber to snake it out.
Aug 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer discharges water so forcefully, it is backing up. Hose has been changed, and there is air around the standpipe. The drain appears clear as a water flows with a hose at full force. The clean out...
if the home drain pipe is larger than the washer drain pipe and water is backing up the house stand pipe, the issue is in the house not the washe, you cannot cut down the amount of water that the washer discharges during the pump out cycle, doing so will void your warranty and cause problems with the pump, whitch now are mostly electric and can not stand any backpressure on them
Apr 09, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
