I am working with AutoCAD and other graphics programs and just came up with an HP monitor large enough to keep me from going blind from using the smaller laptop screen. I have yet to hook up the two and I am hoping this exercise is not going to present problems or prove to be a non-workable deal. Any experience positive or negative with this configuration. Connection cables???
The Dell Latitude D630 has a 15 pin VGA port that can connect to an external monitor or projector. For detailed information go to www.support.dell.com and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to "drivers and downloads" and enter the "service tag"(serial number) of the laptop. Confirm this is the model you have and select “manuals” on the left side column. Select “Get manual” and select the language option. You can view or download the “User’s Guide” in different formats. After you choose the format you want, select “Using the Display” for info. Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience. Thank You.
monitor takes several minutes to wake up after being in sleep mode. Use to wake up after moving the...
(More)
monitor takes several minutes to wake up after being in sleep mode. Use to wake up after moving the mouse or tapping the keys in a few seconds now it takes several minutes to wake up.
On startup when it's cold it comes on for a half second, then turns off. I must cycle it on and off...
(More)
On startup when it's cold it comes on for a half second, then turns off. I must cycle it on and off for a half dozen times before it comes on and stays on... I suspect I need a new on/off switch (button). What say you? Where around Seattle can one get repair service?
